2005 Grand Cherokee idles rough and stalls when im at red or stop light.Help anyone?? - Page 2 - JeepForum.com
post #16 of 31 Old 01-05-2011, 06:31 AM
GeeEssFore
I know that the "fuel service" we do at work also makes a smoke screen just like seafoam. It happens at the dealer also but you just dont see it before they give it to you. Most dealers will pull the o2s before hand but some will leave them in and do it.
GeeEssFore is offline
post #17 of 31 Old 01-05-2011, 07:58 AM
Munch520
2015 WK
I've had issues with seafoam loostening up deposits that were holding things together (ie gaskets) but if you use in the correct doage (1/2 can in gas, 1/4-1/8 can in pcv, 1/4 can in oil prior to change) it should never foul cats or o2 sensors
2005 WK (sold)
2008 Liberty
2012 Rubicon (sold)
2015 GC Altitude
Munch520 is offline
post #18 of 31 Old 01-05-2011, 07:59 AM
Munch520
2015 WK
Originally Posted by Jeffs3232 View Post
Where can I buy the seafoam treatment and is it safe for the Hemi? Is there anything special you need to do to add it, or just pour it in the tank after a fill up? How often do you put in?
Sorry, I am a newb
you can buy it at advance auto, autozone, napa, etc.
I have used it in my cars every year or so, or when I notice problems. There's insturctions on the can I think but see what I mentioned in the post above
2005 WK (sold)
2008 Liberty
2012 Rubicon (sold)
2015 GC Altitude
Munch520 is offline
post #19 of 31 Old 01-05-2011, 08:06 AM
lll2for3lll
2005 WK
Or you can do it the safer way and take it to have it serviced like the guy at the top of the page was talking about.
lll2for3lll is offline
post #20 of 31 Old 01-05-2011, 10:29 AM
CruiserClass
2005 WK
How much should these treatments run? Reason I ask is my local garage wants to replace all 16 plugs in my Hemi and do a fuel service to the tune of about $400. I won't disagree that my WK needs it, but that sounds high to do maintenance every 15-30k.
I am not mechanically inclined so DIY is out of the question for me.
If you can plug in a lamp and have mastered "left loosey, righty tighty" you can change your own plugs. It may take a couple hours the first time, but it really doesn't require any special knowledge or any tools beyond basic hand tools.
You need a basic socket set, simple bar style torque wrench, spark plug socket, spark plug gapper, a 4" extension, a 6" extension, a wobble joint, and a long extension, 10", 12" whatever. A stubby 10mm wrench will also make life easier.
Pull the spark plug boot off by hand. Put the spark plug socket on the short extension (either 4 or 6, depending on how much room at that cylinder) and turn left until the plug comes out. Gapping a plug is as simple as bending the little wire until the correct size feeler goes into the gap. Gap the plug, put it in the hole, turn until it feels tight, then put the torque wrench on it and push until the little needle points to the 14 on the ft/lb side. Use the 10 mm wrench and 10mm socket, remove the coil pack next to the spark plug boot, (2 bolts, one top and one bottom) lift it up, do the same thing under there to remove and replace the spark plug. Put the plug boot and coil pack back on, move to next cylinder.
The only remotely challenging thing is getting to the front 2 cylinders on the driver's side, and that's where the really short extension and wobble joint come in. Drop the short extension and socket in the hole, plug in the wobble and a long extension, and you're turning the wrench way above the tight mess.
You'll save yourself almost $300 and it really is that simple.
CruiserClass is offline
post #21 of 31 Old 01-05-2011, 05:14 PM Thread Starter
hex312
2005 FSJ Cherokee
2for3 was right!!!! That fixed the problem, thank you!!!
hex312 is offline
post #22 of 31 Old 01-05-2011, 05:38 PM
lll2for3lll
2005 WK
I've been trying to tell people this in so many threads. You are so welcome.
My uncle always said never to put stuff in the gas tank. I think that stuff is best for older cars with carburetors.
post #23 of 31 Old 01-05-2011, 07:41 PM
Munch520
2015 WK
Which really isn't much different than using an additive yourself
2005 WK (sold)
2008 Liberty
2012 Rubicon (sold)
2015 GC Altitude
Munch520 is offline
post #24 of 31 Old 01-06-2011, 05:10 PM Thread Starter
hex312
2005 FSJ Cherokee
just make sure you have the throttle body cleaned very important. jiffy lube doesnt touch it but very easy to DIY but maybe other places like firestone clean it for you as part of their service. Thanx again 2 for 3!
hex312 is offline
post #25 of 31 Old 01-13-2011, 06:51 PM Thread Starter
hex312
2005 FSJ Cherokee
okay didnt work. my jeep is still dying at red lights and i hate it more every day can anyone help me w this POS??????
hex312 is offline
post #26 of 31 Old 01-14-2011, 05:28 PM Thread Starter
hex312
2005 FSJ Cherokee
Problem solved. It was short on transmission fluid, about a quart to be exact and told torque coverter might of been sticking, but added the atf+4 and its back to normal, but runs smoother than before w the fuel system cleaning, it needed it but the reason for it dying was the trans being so low.... nuts, just glad its okay now, i love my jeep.
hex312 is offline
post #27 of 31 Old 11-07-2012, 05:11 PM
ben9560
Please let me know what worked, I have the same problem!
Please let me know what worked, I have the same EXACT problem! I would appreciate it soo much!
ben9560 is offline
post #28 of 31 Old 01-05-2015, 07:36 AM
stark_WK
2005 WK
Hey everyone, i have the same problem.. it started just one morning some days ago. The day before it was fine, now it shuts off at almost every stop. Sometimes i can see the computer trying to keep the idle because the tach oscillates between 200-1000 rpm.
My 2005 WK has 188 k miles. I haven't changed the plugs or serviced the fuel system.. oops!
I'll keep you posted.
stark_WK is offline
post #29 of 31 Old 01-05-2015, 09:26 AM
RCS1300
2005 WK
Servicing these vehicles is expensive and they do require service at least every 15,000 miles, 3,000 miles for oil changes. Below is a link to the recommended service intervals.
http://wkjeeps.com/wk_maintenance.htm
Find a mechanic you trust and build a relationship. S/he should be your primary source of service information. There are very few Jeep mechanics that read and respond on this message board.
RCS1300 is offline
post #30 of 31 Old 02-17-2015, 05:24 PM
stark_WK
2005 WK
I posted my results in another thread, but long story short, it was my IAC and possibly TPS that were bad.
I changed both WITHOUT disconnecting battery and idle was fine, but the Jeep would hesitate from a stop, and occasionally die as I would come to a red light.
500 miles later I disconnected the battery, waited a minute, reconnected and now it runs fine. I can tell the tranny needs service but that's a different issue.
stark_WK is offline
94 Grand 5.2L idles rough when cold. smoulding ZJ Grand Cherokee Forum 3 11-19-2009 10:25 PM
How-To: 2005-2009 Grand Cherokee (WK) Fog Light Install mjonesjr WK Grand Cherokee & XK Commander Forum 7 09-27-2009 06:26 AM
rough idle.....stalls when coming to stop? bmx_hb_guy ZJ Grand Cherokee Forum 5 07-20-2009 05:34 PM
96 Grand Cherokee stalls when coming to stop & reverse. HELP! barnettb99 ZJ Grand Cherokee Forum 0 06-04-2009 10:16 AM
94 ZJ 4.0 stalls and idles rough in gear jnf91 ZJ Grand Cherokee Forum 7 04-17-2007 04:06 PM
