2005 Grand Cherokee idles rough and stalls when im at red or stop light.Help anyone?? - JeepForum.com
post #1 of 31 Old 01-03-2011, 08:57 PM Thread Starter
hex312
2005 FSJ Cherokee
i have a 2005 grand cherokee laredo 4x4 4.7 liter v8 with 88,000 miles and has stalled before when id come to a stop but was every now and then , but now its doing it all the time and its getting really frustrating real fast. ive read that its a common problem but nobody seems to know a fix? what is one to do , i used to love my jeep before it started doing this, help please
hex312 is offline
post #2 of 31 Old 01-03-2011, 09:02 PM
lll2for3lll
2005 WK
Not a big deal at all. You just need a fuel system service. You need it like every 15,000 miles or so. That's all.
lll2for3lll is offline
post #3 of 31 Old 01-03-2011, 09:10 PM Thread Starter
hex312
2005 FSJ Cherokee
i hope youre right thank you!
hex312 is offline
post #4 of 31 Old 01-03-2011, 09:18 PM Thread Starter
hex312
2005 FSJ Cherokee
something like what they do at jiffy lube or something better?
hex312 is offline
post #5 of 31 Old 01-03-2011, 09:49 PM
lll2for3lll
2005 WK
Yeah. I get mine done at Firestone.
post #6 of 31 Old 01-04-2011, 11:49 AM
Jeffs3232
2006 WK
How much should these treatments run? Reason I ask is my local garage wants to replace all 16 plugs in my Hemi and do a fuel service to the tune of about $400. I won't disagree that my WK needs it, but that sounds high to do maintenance every 15-30k.
I am not mechanically inclined so DIY is out of the question for me.
Jeffs3232 is offline
post #7 of 31 Old 01-04-2011, 11:55 AM
CmmdrDan
ive seen a number of things that people claim to be the problem. egr, throttle position sensor, etc. i just put a bottle of seafoam in my gas tank and i changed my plugs about 2 months ago. my idle has been rough since i bought it and the seafoam may have helped alittle. i dont feel that a fuel system service will fix the problem. i am also not saying that it wont.
CmmdrDan is offline
post #8 of 31 Old 01-04-2011, 12:45 PM
Jeffs3232
2006 WK
Where can I buy the seafoam treatment and is it safe for the Hemi? Is there anything special you need to do to add it, or just pour it in the tank after a fill up? How often do you put in?
Sorry, I am a newb
post #9 of 31 Old 01-04-2011, 12:49 PM
CmmdrDan
You can get Seafoam from any auto parts store. Just pour it in the tank. I have only used it once, I am do for an oil change so when i go get oil and everything ill get another bottle to put in.
CmmdrDan is offline
post #10 of 31 Old 01-04-2011, 05:12 PM
lll2for3lll
2005 WK
Look at the simple solution first. Get a fuel system service. Mine starts to idle rough every 15,000 to 25,000 miles or so (starts to idle even rougher if I drive even longer to the point where it sounds like it will shut off) and the fuel system service gets it right everytime.
post #11 of 31 Old 01-04-2011, 05:44 PM
Walt
2008 WK
Sorry, I am a newb
Another point of view: Many swear by Seafoam as a fuel treatment. I'm leary of using it.
My reasoning: I try to keep crud out of the injector / valves / O2 sensor / catalytic converter areas. Seafoam loosens all of that, burns some and sends the rest down the tailpipe. Lots of stories about the Jeep looking like a WWII destroyer putting down a smokescreen after using Seafoam. Always concerned about adversely impacting the four O2 sensors and 2 catalytic converters (they are s-o-o-o expensive).
Injector cleaner will work where the fuel goes, but my HEMI has the entire intake manifold to foul with crud before you come to the injectors at the intake valves. Unless you get into the throttle body area, the gas tank method doesn't address that area.
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #12 of 31 Old 01-04-2011, 05:55 PM
lll2for3lll
2005 WK
I don't mess with stuff that goes in the gas tank neither.
post #13 of 31 Old 01-04-2011, 06:22 PM
Munch520
2015 WK
You might need a software reflash too, I had mine done and it was covered under a recall
2005 WK (sold)
2008 Liberty
2012 Rubicon (sold)
2015 GC Altitude
Munch520 is offline
post #14 of 31 Old 01-04-2011, 06:53 PM
I8AHUMR
I wouldn't do seafoam in my Hemi. Fuel service every 15-20k seems more like masking a problem rather than actually fixing it. I have 88k on my Hemi and have yet to do any of the above. Still runs great.
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #15 of 31 Old 01-04-2011, 08:00 PM
lll2for3lll
2005 WK
94 Grand 5.2L idles rough when cold. smoulding ZJ Grand Cherokee Forum 3 11-19-2009 10:25 PM
How-To: 2005-2009 Grand Cherokee (WK) Fog Light Install mjonesjr WK Grand Cherokee & XK Commander Forum 7 09-27-2009 06:26 AM
rough idle.....stalls when coming to stop? bmx_hb_guy ZJ Grand Cherokee Forum 5 07-20-2009 05:34 PM
96 Grand Cherokee stalls when coming to stop & reverse. HELP! barnettb99 ZJ Grand Cherokee Forum 0 06-04-2009 10:16 AM
94 ZJ 4.0 stalls and idles rough in gear jnf91 ZJ Grand Cherokee Forum 7 04-17-2007 04:06 PM
