2005 Grand Cherokee heat only works on max temp - Page 2 - JeepForum.com
post #16 of 34 Old 10-10-2013, 04:24 AM
Jasmin71
I was told that heater itself needs to be re- calibrated....... whatever that means....was told its a dealer only fix
Jasmin71 is offline
post #17 of 34 Old 12-12-2013, 09:10 PM
ChrisWK
2005 WK
Wow I have the same problem with my heater not working at different temps exact for max heat. This is on a 05 5.7 l with the auto a/c controls. Have any of you got a fix for this if so please let me know.
Thanks
Chriswk
Limited HEMI Dark Khaki Pearl SRT8 Full Body Kit, Roof Rails,SRT8 Engine Strut Bar, Lund Rear Spoiler, MYGIG INSTALLED with LOCKPICK, Kenwood Sub,AFE Intake, Taylor Spark Plug Wires,G2 Silver Painted Brake Calipers, Billet Tech Catch Can, Addco Sway Bars Front and Rear, Eibach Lowering Springs,Xenon Volt HID Lows 6k,Chrome SRT Reps
ChrisWK is offline
post #18 of 34 Old 12-15-2013, 04:20 PM
ChrisWK
2005 WK
If you had your ac heater worked on my dealership what did they do to fix it.
Thanks
ChrisWK is offline
post #19 of 34 Old 12-15-2013, 05:58 PM
lowpsi
2016 JK Wrangler
my 05 WK has the same issue, I did not notice it until it started getting real cold, but it blows cold air unless at the max settings, which then blows very hot. WHile it is great that the heat blows so hot it gets a bit uncomfortable when running in the auto settings.
Is it me or are there a LOT of electrical problems related to the 05 WK's? It seems most all have the flashing dash lights, faulty heat controls, random window motor problems, and door locks malfunctioning. Not to mention the weird codes which seem to be thrown. If I did not already have one, I would think it is something to avoid purchasing.
2016 JKUR, Mojave Sand, 4:10 gears 50x17 Toyo Open Country RT, Fuel Krank wheels, BDS 3" lift
lowpsi is offline
post #20 of 34 Old 01-01-2014, 10:02 AM
94jeepman
2005 WK
Have you figured out how to fix this? It really Sucks going on road trips and having to turn on and off every few minutes haha
94jeepman is offline
post #21 of 34 Old 01-05-2014, 07:48 PM
98jgc
2005 WK
98jgc is offline
post #22 of 34 Old 01-05-2014, 07:51 PM
98jgc
2005 WK
That is like checking blinker fluid
The above post will solve your problem of MAX only function, takes 15 minutes and a torx screwdriver. Part is cheap.
http://www.amazon.com/Dorman-973-028.../dp/B003YLMPZA
98jgc is offline
post #23 of 34 Old 01-05-2014, 08:50 PM
94jeepman
2005 WK
All I read on that was it fixing the blower problems and not the heat thing. Correct me dig I'm wrong
post #24 of 34 Old 02-01-2014, 02:36 PM
TRSonly1
Does anyone have a fix on this temperature issue? Same here, cold or hot only, nothing in between. Thanks
TRSonly1 is offline
post #25 of 34 Old 02-01-2014, 04:16 PM
johnniebravo
2008 WK
I believe on the WK jeeps site there is a tsb on recalibrating/reflashing to fix this exact issue. Has something to do with temps not rising evenly when the knob is rotated.
And yes, there are a lit of issues with the 05 as it was the first year for the WK.
2008 CRD GC
johnniebravo is offline
post #26 of 34 Old 02-02-2014, 09:44 PM
Joeyicu
Joeyicu's Avatar
so, is this the fix or not. Mine has had this problem for the better part of 2 years.
(2011 BMW X5 V8TT) {2005 WK Hemi } -1995 Ford Tbird- [1984 F250 6.9]
Joeyicu is offline
post #27 of 34 Old 02-07-2014, 03:22 PM
chey308
Have had the same thing going on. Recently found that if the dial is on a number not the red dot when I start the vehicle it seems to work ok and able to control the temp. Maybe something to try. Have also heard the blend doors can go bad and need to be replaced.
chey308 is offline
post #28 of 34 Old 02-08-2014, 07:11 AM
twss22
2005 WK
Had the same problem on a 2005 Cherokee, it was the blower motor resistor behind the glove box.
twss22 is offline
post #29 of 34 Old 02-13-2014, 01:05 AM
Joeyicu
Joeyicu's Avatar
the blower motor resistor? My blower motor will change speeds just fine, its just the temperature control/blend door related stuff. If I take her to work tomorrow in the truck I will try putting it on the middle and keeping it there and seeing how it goes, I am pretty sure mine will cycle to blowing cold like way to quickly. I need to take it to the dealer and have the new flash I think.
Joeyicu is offline
post #30 of 34 Old 04-29-2014, 04:03 AM
drupi
2005 WK
Anything new on this problem?? I have the same issue on my WK HEMI 05
drupi is offline
2005 , grand cherokee , heater control , jeep , maximum
