2005 4.7 Transmission Lag and hard shift - JeepForum.com
post #1 of 9 Old 09-27-2013, 02:40 PM Thread Starter
CT05WK
Occasionally when going from P to D I will get a minor lag and noticeable clunk when it engages.
Also from P to R it will engage but not move until I hit the accelerator at which point it feels like I'm in a low gear
In both circumstances I will go back to D and then shift to appropriate gear and it's fine.
To top it off I get a noticeable hard shift from 2-3 from time to time
Thoughts? I have 104,000 miles. Do not know maintenance history.
CT05WK is offline
post #2 of 9 Old 09-27-2013, 06:08 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
I'd start with drain/refill of the tranny along with new tranny filters. See where that gets ya.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #3 of 9 Old 09-27-2013, 09:43 PM Thread Starter
CT05WK
thanks.... Sometimes I feel like things can't just be that easy and assume the worst.
CT05WK is offline
post #4 of 9 Old 10-06-2013, 10:09 PM Thread Starter
CT05WK
UPDATE: DTC Codes P0869 and P0932... HELP!
CT05WK is offline
post #5 of 9 Old 10-06-2013, 10:15 PM
sickchilly
2010 WK
If you don't know the maintenance history, I would replace fluid and filters ASAP.
But I'm gonna bet your problem is the solenoid pack. It's about 2 bills and a pretty fast swap.
2010 Brilliant Black Crystal Pearl Coat Grand Cherokee S-Limited with various bits 'n pieces... broken in but not even finished!
sickchilly is offline
post #6 of 9 Old 10-06-2013, 10:20 PM Thread Starter
CT05WK
I don't know the history for sure... Fluid looks very clean, smells fine. I'd have to drop the pan..?
CT05WK is offline
post #7 of 9 Old 10-06-2013, 10:55 PM
sickchilly
2010 WK
Yes. Drain, drop pan, remove filter and valve body. Unplug solenoid pack, remove and replace. Then reassemble in reverse with new filter and ATF.
post #8 of 9 Old 10-06-2013, 11:00 PM Thread Starter
CT05WK
Sounds simple enough... Pretty common problem? Others have speculated speed sensors for the 3rd gear feeling when starting issue. Some have speculated TCM/PCM or even a new tranny!! How likely are those?
CT05WK is offline
post #9 of 9 Old 10-06-2013, 11:42 PM
sickchilly
2010 WK
Could be anything really. There's only so much keyboard/Google speculation I can do from here. But those two codes seem to point to a high pressure problem usually caused by a bad solenoid pack if you search around and read the threads on various forums.
