2" RC lift question/problem - JeepForum.com
post #1 of 22 Old 05-23-2013, 02:08 PM Thread Starter
EtherealPonx
Hello All,
A friend just finished lifting my '09 5.7 GC using a 2" RC BB. Bilstein HD shocks all round. He had some 'concerns' about the angle of some of the joints:
1) In the following pics, he has explained that the CV joint is at an 'extreme' angle. He also points out here that the sway link bushings seem like they will not handle this new hight. If so what do you guys recommend in length for a 2" lift kit for sway links?
2) In this pic, he explained that the 'cup' that holds the spring is touching on either side, is this normal?
He also claims the angle on the UCA joint is a bit extreme and that a bit of wheeling will cause issues. any advice?
These are just concerns at this stage, it has not been driven yet - will go for a test drive on Saturday.
Much appreciated!
EtherealPonx is offline
post #2 of 22 Old 05-23-2013, 02:23 PM
trax95008
2006 XK Commander
Of corse everything is at an extreme angle. You have the vehicle jacked up with everything else hanging. Once you throw the wheels on and drop it down, it will level out some. As for the lower spring perch, that does NOT look normal. I've had 4 different configurations of lift and NEVER had an issue with it touching like that
trax95008 is offline
post #3 of 22 Old 05-23-2013, 02:46 PM Thread Starter
EtherealPonx
Even with the vehicle lowered to the ground back on the wheels, the angles dont appear much less extreme.
As for the lower spring perch, this is concerning. Nothing has changed on the truck except for the shocks
(http://www.quadratec.com/products/16070_108.htm)
and the lift kit (http://www.roughcountry.com/jeep_wk_2.html)
What could be the cause of this?
post #4 of 22 Old 05-23-2013, 03:43 PM
ca07wk
2007 WK
For the sway bar links, you can remove the sway bar completely or pick up some JKS adjustable links.
You've installed a 2" lift without moving anything else, the CV axles and UCA's are going to be angled more. The angles aren't beyond what they should be with that lift. You can order a set of UCA for a lifted WK, but the CV angles your stuck with.
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #5 of 22 Old 05-23-2013, 03:51 PM Thread Starter
EtherealPonx
Thanks, I will look into the the UCA's. I know from memory that they are not cheap to replace.
I also believe the shocks are not compressing properly when lowered from the lift. someone on another forum had a similar issue where he was getting 4.5 inch lift out of the same setup. Apparently the shocks need to be compressed several times before fitting (I dont think this was done).
I did think the lift was more than what I would have expected from a 2" and bilsteins. apparently the other guy simply just lifted it and dropped it several times until the shocks started to compress, is this usual?
post #6 of 22 Old 05-25-2013, 02:18 PM Thread Starter
EtherealPonx
Ok, the issue seemed to contain an element of miscommunication, the 'touching' of the suspension perch to the knuckle ONLY occurs when the vehicle is lifted off the ground, so under normal driving conditions, this does not happen. Therefore, only under extreme off-road driving would this occur and I doubt it would be a significant issue.
Wheel alignment complete, car should be ready by tomorrow
post #7 of 22 Old 05-28-2013, 06:56 AM Thread Starter
EtherealPonx
Caster on the wheel alignment seems to be a bit off, does anyone have the tolerance levels for a WK wheel alignment?
I know the Camber can be adjusted using the LCA bolts, but more than certain caster cannot be changed easily ..
Apart from that, the front shocks seemed to have 'leveled' off the the car has dropped by nearly an inch since install
post #8 of 22 Old 05-28-2013, 02:31 PM
R4TCHET
2005 WK
one thing you will notice, is that the front is significantly higher than the rear with the RC lift. i would almost say there is about a 1' difference between the two. 2.5 in front, 1.5 in rear.
a bit of wheeling wont cause problems. i wheel like 2-3 times per week on some pretty intense trails and the lift hasnt caused problems. so long as you dont drive super fast off road you will be fine, but that is the case with most off road vehicles.
| (dark)KHAKI WK CLUB MEMBER 17 | 2005 4.7L QTII | JBA UCAs | Modified OME MD 3.5" lift | Rusty's Adj. track bar | 4XG Matrix | 285/70r17 Duratracs | 17" KMC Enduro Wheels | Rola Roof Rack | 21" Bean LED Light bar on Roof Rack | 2 12" Punch P3 Subs | Expanded Sheet Grille | SA Sliders |
R4TCHET is offline
post #9 of 22 Old 05-31-2013, 03:04 PM Thread Starter
EtherealPonx
Thanks Ratchet, that makes sense. Dont doubt the durability of the RC kit, as it definitely looks more rugged over the poly stuff. quick question, did you change the sway bar links to return the front sway bar back to the original stock setting?
Separate question about your shocks, are you using stock springs with the OME shocks? if that is the case, can OME springs be used with Bilstein shocks?
Like the sliders btw, will contact them to see if they ship internationally ..
post #10 of 22 Old 06-05-2013, 01:16 PM Thread Starter
EtherealPonx
Hey ca07WK
any advice on the length of Sway links that will put the way bar back to stock location with a 2" RC lift kit?
Thanks!
post #11 of 22 Old 06-05-2013, 01:30 PM
ca07wk
2007 WK
For the front they should be the stock length, for the rear I've heard 1"-2" longer. I have to retract my previous post, I wouldn't recommend the JKS links for the front, myself and a few others had the bottom pin snap off. I replace my broken bottom pin and snap ring and moved them to the back at 1" longer and just have the front sway bar disconnected.
ca07wk is offline
post #12 of 22 Old 06-05-2013, 03:30 PM Thread Starter
EtherealPonx
Thanks for that. I just ordered all stock length ones from BWoody, I spoke to their lead Jeep mechanic and he said for a 2" lift kit the links dont need to be any longer than stock. I would expect the links need extending when going to 3" and above in lift.
Besides, the cornering on the truck is now much better since I installed the lift and Bilstein HD shocks all round
BTW, I wouldn't drive on-road with a disconnected front sway bar. I would expect some serrious body rolling effect and instability while cornering on a highway. Isn't it technically illegal in many states too? just my 2c worth
post #13 of 22 Old 06-05-2013, 03:36 PM
ca07wk
2007 WK
The body roll isnt to bad with the front disconnected, the rear would be bad though. As soon as I get more time I need to drill and extract the rest of the broken JKS pin out of the front LCA, then I will reconnect the front sway bar.
ca07wk is offline
post #14 of 22 Old 06-14-2013, 04:04 PM Thread Starter
EtherealPonx
Just got a set of BWoody sway links, they will go in on Sunday
post #15 of 22 Old 06-15-2013, 02:58 PM
4thgradedropout
Your rc looks so much higher then my daystar, wish i would of done that
4thgradedropout is offline
