2" Lift Options for WK - Page 2 - JeepForum.com
post #16 of 33 Old 09-13-2011, 08:22 AM
corswandtm
2007 WK
Originally Posted by Jvenrick
I have had my Rough County for a couple months now and love it. Kit itself was only $150, so if you install it yourself its a very cheap lift. Install will probably be around $300 unless you know someone. Im currently looking for some 245/75/17 tires which will make it the perfect height for me!
I have the same wheels. Will 245/75/17 tires fit better than 265/70/17? I don't want to use spacers or modify wheelwell if possible.
2007 WK Red Rock Limited - 5.7 HEMI w/QD-II - Stainless 22" Magnaflow muffler - AFE Stage 2 CAI - Bilstein HD shocks/struts - JBA Strut Spacers - 245-70/17 Firestone Destination AT
corswandtm is offline
post #17 of 33 Old 09-13-2011, 08:45 AM
sk8rcj
2005 WK
Originally Posted by jmags
Nice jeeps yall! Im jealous for sure. If i go through with lifting mine i sadly will need to save up some more money for bigger tires. Im running 245's right now. Any loss of mpg with the lifts?
I mean, I really haven't lost any mpg. I've always gotten 15-16 city and 17-18 highway. So no change for me.
--------- '05 Jeep WK, Dark Khaki Pearl, 3.7L V6 ----- Mods: Rough Country 2" BB, P265/70/17 Falken Rocky Mountian ATS Tires, Blacked out taillights, Blacked out front orange markers
sk8rcj is offline
post #18 of 33 Old 09-13-2011, 10:08 AM
sunrcr69
2005 WK
You wont experience any loss in MPG from a lift alone. A lift + tires will cause a loss in MPG. How much depends on your tire size and how agressive you drive.
2005 WK 5.7L Hemi, RC 2" BB + fabrication = 3.5" lift, JK Rubicon Tires & Wheels, 1.25" Spacers, Fabricated Skidplate, Fabricated Recovery Points, Airaid CAI, Superchips, HIDs RED WK Club #10
sunrcr69 is offline
post #19 of 33 Old 09-13-2011, 03:01 PM
DFWJeep
2006 WK
Interested in hearing an answer to this question. I'm in the same boat about to get a RC 2.25" spacer lift and am wondering what size tires will fit without using spacers or modifying anything.
DFWJeep is offline
post #20 of 33 Old 09-14-2011, 12:32 PM Thread Starter
jmags
2006 WK
Thats good news. I cant afford to lose any mpg's. Its bad enough because of Lexington traffic.
jmags is offline
post #21 of 33 Old 09-19-2011, 05:42 PM
Bama_WJ
Bama_WJ's Avatar
The stock shocks good with the RC BB? The Overland I just picked up will strickly be a mall crawler, so I'm thinking they may be alright for now.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #22 of 33 Old 09-19-2011, 10:41 PM
Jvenrick
2007 WK
Im not sure how well the 245/75/17 fits on a 2 in lift there are not to many people doing that size on 2 in lifts. Not sure if it will rub on the frame without spacers? When im ready to buy im gonna test fit wrangler duratracs in both 245/70/17 and 245/75/17, ill let you know what i learn.
Jvenrick is offline
post #23 of 33 Old 09-20-2011, 02:12 PM
DFWJeep
2006 WK
For those that have a 2" lift, is it possible to run a 255/75/17 with stock wheels without using wheel spacers? If not what size spacers are required for it to fit
DFWJeep is offline
post #24 of 33 Old 09-20-2011, 07:42 PM
Budasac
2005 WK
The stock shocks are fine if they have life left in them. The nice thing about the RC lift is that you don't have to break down the coil and strut to install it. No strut compressor required. So if you're not replacing the struts the install is much easier. Slightly longer shocks in the rear are nice for added travel but not necessary at all.
That's gonna be a tight fit. I had 265/70's on the stock rims with no spacers and they just fit. Had to take a hammer to the inner wheel well to eliminate the rub but that was all. Althought the 255 is about an inch narrower it's also about .5" taller. It may be a wash. I would definately reccomend a test fit. The fit will likely vary with the tire make and model, as specs are not uniform from one tire to the next.
If you look through the wheel and tire sticky you may find someone with the set-up you want and can contact them directly with ??
Budasac is online now
post #25 of 33 Old 09-22-2011, 01:49 PM Thread Starter
jmags
2006 WK
Just an update. I went to the 4x4/truck store here in Lexington today. I ordered the Rough Country 2" lift. Parts cost me $150 and they are going to charge me $125 for instillation, which i thought was reasonable. Im getting it installed next week so I'll post my thoughts once I get it put on and drive it around for a while
jmags is offline
post #26 of 33 Old 09-22-2011, 02:07 PM
DuncsJeeps
DuncsJeeps's Avatar
2006 XK Commander
Did you confirm that they were going to do an alignment for you when they're done? I've had suspension work done before and when I asked them what the hell, I was told "we don't do that here". Now it's a default question for me.
DuncsJeeps is offline
post #27 of 33 Old 09-22-2011, 03:43 PM
Budasac
2005 WK
^ that. Alignment will run you another $100. And you're gonna need it.
post #28 of 33 Old 04-25-2014, 07:56 AM
Mrvlu3
2008 WK
Rubbing Issues on 08 WK 265/70/17 w/2" lift
Hi Guys - I just put a RC 2" lift on my 08 Wk. I'm running wranglers 265/70/17 A/T's and having some rubbing issues on the sway bar and back wheelwell @ almost full lock turn. Looking to solve the problem with different backspacing rims if possible. Does anyone know which brand/backspacing for 17" 5x5 has worked for them??
Mrvlu3 is offline
post #29 of 33 Old 05-02-2014, 08:36 AM
oldsmoke
2009 WK
Yah, I had the same problem but when I tried wheel spacers I then got rubbing on the pinch weld. Didn't want to do the pinch weld mod.
Ended up just folding over the sharp edge of the steel at the bottom edge of the lower inside fender with a hammer and living with a wee bit of rub at full lock.
I think in my case I could cure it with a 1/2" wheel spacer. Maybe look into it next time I change tires.
Diesel Ecotune-DPF, 32" tires, 2" lift. 4xGuard bib, tow hooks
oldsmoke is offline
post #30 of 33 Old 08-17-2015, 03:55 PM
07Wk
2007 WK
What kind of shocks and struts do you need for the 2in lift??
07Wk is offline
2" , lift , wk
2" Daystar Lift - What Options for Shocks/Struts? cda322 WK Grand Cherokee & XK Commander Forum 6 02-15-2011 07:04 AM
small lift, less than 2".. options? paroxysym WK Grand Cherokee & XK Commander Forum 0 01-20-2011 08:34 AM
18" wheel options and OME lift Funtuzzi WK Grand Cherokee & XK Commander Forum 0 10-25-2009 10:31 PM
"Performance" options, ignition coil Petee ZJ Grand Cherokee Forum 4 06-10-2009 11:42 AM
ZJ trackbar options for 2 or 3" lift? aaron7 ZJ Grand Cherokee Forum 9 03-06-2009 05:53 AM
