Which ~2-inch WK lift for daily driver - Page 2 - JeepForum.com
post #16 of 20 Old 10-06-2013, 08:19 AM Thread Starter
marcram
2008 WK
Ok. So rear bilstein hd offers 3/8 inch lift. What is stock rake? I thought .5ish inches. So maybe .75 would probably be closer, but not enough of a mod. I guess 1.5 or 2 inch sounds more attractive to me, so just need to find appropriate rear spacers. Thanks for the help Kolak, do you mind pming me a quote for front struts? Thanks.
marcram is offline
post #17 of 20 Old 10-06-2013, 12:29 PM Thread Starter
marcram
2008 WK
Installed my new AEV center caps, and measured the current wheel well spacing.
Here is the current rear wheel well spacing:
And the rear:
I may give the front 1.5" lift a try initially, then make rear adjustments as necessary.
marcram is offline
post #18 of 20 Old 10-13-2013, 03:19 PM
oldsmoke
2009 WK
Same here
Originally Posted by camber View Post
That labor seems REALLY high. The installation of the Rough Country lift is fairly easy to do yourself ... however if you are looking to have someone else do it, try going to a place like Pep Boys. They will put them on for about $150. If it was a full suspension system then I wouldn't want Pep Boys doing it, but simply putting spacers in is more than easy enough for them to do.
As for the lift itself - I can only speak on the Rough Country lift but I have had no issues whatsoever. The front does ride a little higher than the back. I'd say it's more like 1.5" lift in the back and 2.5" lift in the front. Here is my ride on 265/70/17 BFG TA KOs. You can see how the front sits higher...
I put in the Terra Flex 2" spacer lift by myself. A relaxing weekend project! My Jeep seems to sit much the same as stock except a good 2" higher. I like it being a little higher at the back because I load up with stuff and tow a trailer sometimes. MY Bridgestone 255 70 18s are rubbing a bit at full lock on the sway bar and the frame and I don't want to mess with the pinch weld and wheel spacers. I just bent in the sharp edge of the lower inside fender where it was rubbing a bit at full lock so it wouldn't nibble at the tire and the little bit of rubbing I still have I can live with. The Bridgstones are 32" in diameter so I get over an inch more ground clearance with them.
Diesel Ecotune-DPF, 32" tires, 2" lift. 4xGuard bib, tow hooks
oldsmoke is offline
post #19 of 20 Old 05-22-2014, 05:21 PM
JeepMedic89
2005 WK
That looks sick!!! What shocks/struts are you running with that. I am ready to order my RC but wanna make sure i have all my ducks in a row.
JeepMedic89 is offline
post #20 of 20 Old 06-01-2014, 01:08 PM
CommanderDuner1
I can only speak for the Daystar lift on my Commander, I've been very happy with it, aI suspect poly does make a difference in terms of ride quality.
CommanderDuner1 is offline
