Quantcast 2" Daystar lift questions - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 2" Daystar lift questions
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 08-09-2009, 02:56 PM   #16
RuffTJ
Thanks man. Im looking to trade my TJ in for a 05 WK real soon. its a 5.7 with 55k miles for under 13thousand. pretty good deal right? If i get it I am definitely going to be picking up a set of moabs and a 2" BB.
RuffTJ is online now   Reply With Quote
Old 08-09-2009, 03:10 PM   #17
Texas WJ
Texas WJ's Avatar
2005 WK
I haven't followed prices since I bought mine almost two years ago, but it does sound like a decent deal. If it's the 5.7 it's more than likely paired with the Quadra-Drive 4X4, check to make sure the fluids were properly changed at the required intervals and that the transfer case isn't binding in tight turns. It's a great system, but you got to keep on top of it maintenance wise.
The stock shocks won't last too terribly long once the BB is installed, so you might want to think about swapping them out while you're at it. Bilstein is a popular option, but they're stock length so you lose a little wheel travel where as OME offers a shock that's the proper length but doesn't ride as well.
Good luck.
Texas WJ is offline   Reply With Quote
Glock Forum
