18" Tire Size Options fo 05 WK - Page 4 - JeepForum.com
post #46 of 91 Old 11-04-2013, 09:21 PM
rheals
2008 WK
Originally Posted by Flyboys
They fit, needed 1/4" spacers to keep from rubbing up front. I also have Bilstein 5100 struts up front at 2" and Bilstein 5100 rear with 2" RC coil spacer in rear. https://lh4.googleusercontent.com/-X...40/beach3.jpeg
Oh man that looks fantastic! Well done. Glad to hear they fit. Did you have any issues with the tire pressure monitors? Do they communicate with your jeep? I have heard that they changed the frequency in 2011. Thanks for your reply. I'll have to pick those wheels up!
Rheals
2008 JGC 3.0L CRD QDII
GDE EcoTune, 2013 JK 18" Wheels
rheals is offline
post #47 of 91 Old 11-04-2013, 10:00 PM
rheals
2008 WK
Hey Flyboys after you put those tires on did you need to recalibrate your speedometer? Just curious.
rheals is offline
post #48 of 91 Old 11-05-2013, 08:18 AM
Flyboys
2015 JK Wrangler
yes, i used my FlashPaq to fix the speedometer. You are correct the TPMS does not communicate.
2015 Willys JKU
2014 Ram CC Sport
Flyboys is offline
post #49 of 91 Old 11-05-2013, 08:42 AM
Bigdlensch
2006 WK
The whole TPMS thing is bs, my shop said $6 a tire as long as everything goes perfect. If one breaks it's like $100 for a new one thru them. There is a member on here that sells them much cheaper tho.
And I agree with old smoke above, I don't need more dummy lights. I am able to take care of my tires without sensors. Would really like to b able to turn these off!
Super slowmo build, 2006 grand cherokee limited 4.7, flowmaster 40, k&n cai, superchips, shorty antennae, 08 Jk Sahara takeoffs w/stock duelers
Red wk club
Ohio jeep
Bigdlensch is offline
post #50 of 91 Old 11-05-2013, 08:53 AM
rheals
2008 WK
Originally Posted by Bigdlensch
The whole TPMS thing is bs, my shop said $6 a tire as long as everything goes perfect. If one breaks it's like $100 for a new one thru them. There is a member on here that sells them much cheaper tho. And I agree with old smoke above, I don't need more dummy lights. I am able to take care of my tires without sensors. Would really like to b able to turn these off! Sent from my iPad using JeepForum
Thanks Flyboys. I'll have to recalibrate my speedometer like you did. And Bigdlensch, it's not about depending on the TPMS, it's about keeping options working if possible. Just cause I don't use my CD changer, doesn't mean I'm just going to ignore it. My thoughts.
rheals is offline
post #51 of 91 Old 11-05-2013, 07:27 PM
REDLYNER
REDLYNER's Avatar
I'm running the 255/70 18's with RC spacers- no rubbing at all (also 2" lift). Love the new tires, but I did notice a slight decrease in acceleration.
REDLYNER Racing #4410
Rugged Radios * Raceline Wheels * DynoMax Exhaust * Motor Trenz * Polar Bear Coolers
Instagram/Facebook/Twitter: redlynerracing
REDLYNER is offline
post #52 of 91 Old 11-05-2013, 11:48 PM
rheals
2008 WK
Looks good. The lift makes a big difference.
rheals is offline
post #53 of 91 Old 11-06-2013, 10:28 AM
zc911
Originally Posted by phottomatt View Post
On second thought and further inspection I think it would be a very bad idea to cut that as I believe that is is used to hold the upper yolk bolt in place while removing the nut.
Anyone with this setup notice much of a drop in fuel economy?
I just did bilstein 5100s and i cut the bolt. With air tools it;s not needed, and i am in the rust belt.
If you put an air gun on the nut and it just spins, the ball joint is done for anyway so you can just cut it off and repalce it
zc911 is offline
post #54 of 91 Old 11-06-2013, 10:31 AM
zc911
I just put 2013 Rubicon rims on, and i used the rubber stem sensors that came with the rims and they communicate? Well 3 outta 4 do. All 4 worked for 2-3 days, then the front passanger side started working when it wants too.
Is there a sensor in the spare tire? i have an 07 CRD, and it tells me what the pressure is in 4 tires, nothing about the spare?
zc911 is offline
post #55 of 91 Old 11-06-2013, 05:58 PM
phottomatt
2010 JK Wrangler
Good to know, thanks I will cut it off then.
From what I understand as long as the JK rims are pre 2009 they are on 315MHz as of 2009 they went to 433MHz as for the WK "The TPM system operates on either a 315MHz radio frequency (2005-2007 Grand Cherokee) or a 433MHz frequency (2008-2009 Grand Cherokee)" from wkjeeps.com. So as long as you get wheels off the right year they should work.
2010 Flame Red Sahara, Rough Country stubby bumper/winch, Body Armor rock sliders, stiff spring mod and RC 2.5" series II spacer lift (~3.5" total lift), 33X12.5 Duratracs on 15" MB72s.
2007 Grand Cherokee Limited, Red Rock, 5.7L HEMI
phottomatt is offline
post #56 of 91 Old 11-07-2013, 08:34 AM
oldsmoke
2009 WK
Hey Redliner. My Jeep looks just like yours only I have the white letters to the outside. I am having a little bit of rubbing on the inside frame/fender area and just wondering what kind of RC spacers you are talking about. I guess I need them.
Diesel Ecotune-DPF, 32" tires, 2" lift. 4xGuard bib, tow hooks
oldsmoke is offline
post #57 of 91 Old 11-07-2013, 08:39 AM
REDLYNER
REDLYNER's Avatar
RC 1.5" spacers, I have ZERO rubbing.
REDLYNER is offline
post #58 of 91 Old 11-07-2013, 09:00 AM
oldsmoke
2009 WK
Wrangler or Grand Cherokee?
Redlyner, are you talking about your TJ or GC? The Grand Cherokee photo I am looking at in your post does not appear to have 1.5" spacers. I have a set of those that I tried on my Grand Cherokee but they caused the tires to rub on the pinch weld and stick out a little too far. I would need to add rubber fender flares on my Jeep. I was thinking something like a 3/8" or 10mm spacer might fix me up but I don't know.
oldsmoke is offline
post #59 of 91 Old 11-07-2013, 09:07 AM
tnadanzig
tnadanzig's Avatar
2007 WK
I do hate this two frequencies for the tire pressure sensors. I have a 07 and 08 and I wish I could swap tires between the two and keep the system working. I wonder how hard it would be to update to the 07 to 433MHz. The wife hates it when lights are up on the dash. I just ignore them.
Anyone running 275/70/18? I think that tire looks really good on these Jeeps.
CB Engineering
CB-engineer.com
2014 WK2 EcoDiesel - CBE Parts
2008 3.0L CRD WK LTD - GDE Tune 3.07 gears
2007 3.0L CRD WK LTD - Go Fast Parts
2005 KJ CRD - GDE Tune
tnadanzig is offline
post #60 of 91 Old 11-07-2013, 09:33 AM
REDLYNER
REDLYNER's Avatar
I don't run spacers on my TJ-
Pics of what is on the GC:
REDLYNER is offline
