18" rims - JeepForum.com
post #1 of 3 Old 12-04-2007, 06:22 AM Thread Starter
array
18" rims
hi folks,
i definitely decided to buy 18" rims as summer rims with tires.
but, i need a help or some kind of advice from you.
at http://www.rims-n-tires.com/rt_specs.jsp, you can arrange a stock wheel and the desired one. also there is mentioned following:
OEM tires: 245/65-17 (750x245mm). Bolt pattern: 5x127 (5x5). Offset: 30 to 55 mm. Tires up to 790x285mm. Rims up to 24x10.0".
i dont know exactly, because one thing is web program and another is reality.
i searched following rims suitable for WK, check them out:
i want go with 255/55-18 tires.
9Jx18, 5x5", offset 35
http://www.az-pneu.sk/index.php?goto...&zobrazit_x=77
8,5Jx18, 5x5, offset 45
8Jx18, 5x5, offset 40
8Jx18, 5x5, offset 35/40
when i set values of e.g. 9Jx18 ET35, at www.rims-n-tires.com in field clearance - fender is shown that package will stick out 1" farther.
for me it doesnt matter, which rims i ll buy from above linked, but i want to know if everything concerning them shown at rims-n-tires, will be in real life good for me - no rubbing, no touching with fenders, steering parts etc.
thanks guys
2006 WH Limited 3,0 CRD
LeBra front end cover, 275/45-20
array is offline
post #2 of 3 Old 12-07-2007, 03:18 AM Thread Starter
array
noone can help?
array is offline
post #3 of 3 Old 12-07-2007, 11:46 AM
CEPCNC
2005 WK
there shouldnt be any clearance issues...the only clearancing issues are when running bigger than the size you are looking at...i.e. the knucklebolt coming down sometimes needs to be trimmed. you'll be fine...18" rim is good with that tire width/height
CEPCNC is offline
OEM 18" rims,backspacing and "The Bolt" Robert J. yates WK Grand Cherokee & XK Commander Forum 8 10-24-2009 10:52 AM
Trade - my 17" cast alum. machine face rims for your Chrome Clad alum. rims coyote runner WK Grand Cherokee & XK Commander Forum 2 08-13-2007 06:03 AM
Anyone running stock 16" rims and 4.5" of lift? What size tires do you run? bjl95mustang ZJ Grand Cherokee Forum 5 02-12-2007 12:23 PM
Pics of WJ's on 15" rims 32+" size tires Clayton00grand ZJ Grand Cherokee Forum 1 02-22-2006 08:25 AM
3" lift, 285-75-16 stock limited rims, and 1"wheel spacer. Will it work? bjl95mustang ZJ Grand Cherokee Forum 1 01-26-2006 12:17 PM
