12.5 Average MPG? - JeepForum.com
post #1 of 62 Old 06-27-2012, 09:01 PM Thread Starter
Shafer57
2006 WK
12.5 Average MPG?
06' Hemi. Mostly back roads 35 mph speeds stop and go every so often. But I still think 12.5 is a very low number, i've hit the reset button but still it goes right back to the 11.5-13.0 mark.
Currently have a K&N full intake, tires at 33-35 psi, 89 octane BP fuel, A/C rarely used.
What are some of the major things i should be doing? I'm somewhat new to the Hemi so not 100% sure what the immediate things to look for are. I bought the truck around 10 months ago certified pre-owned.
ALL opinions and suggestions are appreciated in advance
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
275/45R20 Nexen Roadian, Blacked out, 180 Stat _SOLD_
2008 335i Twin-Turbo
Shafer57 is offline
post #2 of 62 Old 06-27-2012, 09:06 PM
kllshadow
2006 WK
That is about what I get. You bought a HEMI its job is to dump fuel in and give you power. The lack of Aerodynamics doesn't help either.
Black WK Club Member #61
kllshadow is offline
post #3 of 62 Old 06-27-2012, 09:18 PM
90grandoneer
90grandoneer's Avatar
2006 WK
How many miles on it, and what is the maintenance status....spark plugs, filters, fluid changes, trans. service, etc.?
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, TruFlow Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, Transgo Shift Kit, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam w/6* advance/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, TEA ported/milled heads, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #4 of 62 Old 06-27-2012, 09:23 PM
S1L3NT_WH33L3R
2005 WK
I made 14when I first got mine then my mom got an 06 and she makes the same thing.
'05 WK Limited, QD-II, 5.7L HEMI, Volant Cold Air Intake, Aries Taillight Guards, Rola Roof Rack, Cobra CB, Firestik Antennas, Magnaflow Performance Exhaust, OME HD lift, 285/70-17 GY Duratracs, Spidertrax Spacers, Superchips Programmer, Steel Armadillo Super Sliders
~Jeep makes it HEMI shakes it~Ain't Nothing Humble about that HEMI Rumble~
S1L3NT_WH33L3R is offline
post #5 of 62 Old 06-27-2012, 09:36 PM
Static83
2014 JK Wrangler
better then my 11 on my 4.7
Stock for now
Static83 is offline
post #6 of 62 Old 06-28-2012, 08:18 AM
fourtrax450r
2007 WK
i have an 07 drops to 4 cyl running 93octane at 40psi. bad alignment and i like to play with the throttle a bit and get 16.5 mph. learn to feather that gas, get an alignment, and run 40psi in your tires, but thats only if you drop 4 cylinders.
fourtrax450r is offline
post #7 of 62 Old 06-28-2012, 08:32 AM Thread Starter
Shafer57
2006 WK
Not complaining about the MPG, just confirming that this is normal and there's no issues. My old Dakota with the 360 did worse
Spark plugs done 5K ago (standard copper tops) and injector cleaner ran every 6K. Oil changes every 3,500 semi-syn, I have some of the old maintenance records but nothing really more than brakes and oil changes.
Shafer57 is offline
post #8 of 62 Old 06-28-2012, 08:40 AM
fourtrax450r
2007 WK
i understand but im saying you can achieve much better. people who are okay with 12 mpg when they can achieve 16 are lazy. i was that guy and then a month ago i said no...i want better gas mileage lol
post #9 of 62 Old 06-28-2012, 08:47 AM
AJeepZJ
2006 WK
agree 100%. unless you are living in a high-altitude state, you are wasting money, gas, and can actually be ignoring a symptom of something more important. A lot of stuff effects the MPG, and the HEMI is a complex engine - it's not always as simple as checking spark plugs, air filter, and tire pressure.
All Gear, No Skill.
AJeepZJ is offline
post #10 of 62 Old 06-28-2012, 09:06 AM
fourtrax450r
2007 WK
also, check if your MDS even works. i have a guy who couldnt figure out why he was getting 10 mpg when he realized his motor was stuck in tow/haul mode. it changes the shift points and eliminated MDS PLUS maps the A/F ratio to something you dont even want to know.
post #11 of 62 Old 06-28-2012, 09:45 AM
andrew44
2005 WK
Spend some money and chip it. Wake that hemi up a little
05 WK GC Limited 4.7L Nitto trail grapplers 285/70/17 RR 2.25" Bilstien Shocks. RC 1.5" Wheel Spacers. deck and 10" sub. HID8000 Head lights. Superchips Flash Paq. 22" stainless Magnaflow muffler.
andrew44 is offline
post #12 of 62 Old 06-28-2012, 09:58 AM
06WKHEMI
2006 WK
I just ordered my flash paq from kolak yesterday what a deal I can't wait to install it
2006 Black wk overland HEMI QDII. OME HD bilstein struts with 58643 monroe load levelers RRO uca, afe cold air intake,hella 500FF behind grille, RC 1.5 wheel spacers s4xc cb antenna mount with 5ft firestik and midland 1001wx CB,265/70-17 falken rockymountain ats, pinch weld mod, door lock mod, Rola basket with 2 Hella 500 FF`s.
06WKHEMI is offline
post #13 of 62 Old 06-28-2012, 10:15 AM Thread Starter
Shafer57
2006 WK
Have a Diablosports Predator but I set it back to factory settings from the performance tune to see if that resolved my issue a bit.
But like most of you have said; I'm looking to figure out if there's an actual problem versus routine maint. issues.
What is an EGR, and does this effect my mileage? becuase no-where in the records does it say it's been replaced. It has 74,500K on it.
Your answers have been helpful so far
Shafer57 is offline
post #14 of 62 Old 06-28-2012, 10:23 AM
fourtrax450r
2007 WK
im looking for a good tune but im scared to get one to be honest. looking for something with a few different mappings, and maybe customizable. i want maximum fuel efficiency on one, and max horsepower on another as well as stock.
post #15 of 62 Old 06-28-2012, 10:28 AM
90grandoneer
2006 WK
The Exhaust Gas Recirculation Valve (EGR), is located on the front, passenger side head and has an insulated tube going to the intake manifold. If this valve malfunctions, some of the symptoms are, erratic, almost stalling idle, low speed surging, and poor performance and fuel economy. Mine went bad (with a code) at ~54K miles. When is the last time the plugs were changed? What type of plugs were installed? Has the backside of the throttle body butterfly been cleaned? Do you have a catch can? If not, IMO, it is a must on the Hemi. Take the air tube off at the throttle body and manually (with engine off) open the butterfly. Shine a light in and examine the backside of the butterfly and the intake plenum behind it. Look for caked on oil crap, and puddling in the plenum. Guaranteed you'll have it, and it will probably be real bad. This crap may affect the proper operation of the MAP Sensor, which in turn will tank the fuel economy. When's the last time the PCV Valve was changed? Once all of this is sorted out and repaired/replaced, reinstall the DS Tuner. It should work real well....it does on mine.
hemi , mpg
Average MPG??? TokenBlackJeep WK Grand Cherokee & XK Commander Forum 15 06-18-2012 03:20 PM
Average MPG is stuck... RingRingRing ZJ Grand Cherokee Forum 8 05-27-2009 08:21 PM
Average MPG on 08 WK? Xander WK Grand Cherokee & XK Commander Forum 26 02-20-2009 05:07 PM
Average MPG?!? jpgrl do n mud ZJ Grand Cherokee Forum 0 10-24-2005 06:08 PM
average wheeling randyszj94 ZJ Grand Cherokee Forum 15 10-06-2005 08:37 PM
