Quantcast 115V Power Outlet - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 115V Power Outlet
Old 04-29-2008, 10:16 PM   #16
jeepgaffer
2006 WK
Originally Posted by LJS8510 View Post
thanks for the replies, on the pump question.
I was hoping for an already made solution for those who have a power outage, but guess not.
Portable generator.
2006 Bright Silver Grand Cherokee Laredo
3.7L 4WD ("mostly" stock)
jeepgaffer is offline   Reply With Quote
Old 04-30-2008, 01:00 AM   #17
drysuitdiver
2007 XK Commander
Originally Posted by kmax View Post
Yes, in a perfect, frictionless world. Due to the inertial, frictional and efficiency losses from brushes, bearings, winding imperfections, etc., the real world load a 1hp, 115 volt AC motor will draw is 16 amps, or 1840 watts.
I'm not trying to hijack this thread, but I still believe plugging the sump pump into the Jeep's inverter outlet will cause the fuse to blow. Lets all try it and see!
i love it when people forget about Volt drop, copper losses and all the other things that skew real world calcs
we have somebody here who knows exactly whats gonna happen. you can do math all day floks but experience usually provides the best answers.
drysuitdiver is offline   Reply With Quote
Old 04-30-2008, 11:16 AM   #18
kmax
2006 XK Commander
I do have a correction to something I posted yesterday. The Jeep inverter is not a two-level, with a high and low setting. It is only one-level and good for only 150 watts. Not sure where I dreamed it up. To answer the question as to what can be plugged in - things like cell phone chargers, portable DVD players, portable video games, laptop computers, etc.
Those that want an inverter for things like power tools may want to forego the factory set up and buy something with some punch. I have a 750 watt inverter that clips to the battery terminals. It can be wired in permanently if one was clever enough to find a place for it but as drysuitdiver mentioned, the cooler you keep it, the longer it will live.
Ken
'06 Commander Ltd, Hemi, QDII, 4" Superlift, Deaver Coils, 285 KM2's on Moabs
kmax is offline   Reply With Quote
Old 04-30-2008, 11:49 PM   #19
bsteele
wow maybe i dont know what i am talking about. by grounded, I meant that the outlet accept three-pronged plugs instead of the two-pronged outlets ive seen in other chrysler vehicles.
bsteele is offline   Reply With Quote
Old 05-01-2008, 02:47 AM   #20
drysuitdiver
2007 XK Commander
still needs a physical connection to the 'ground' floor earth soil mud sand ( actually not sand as thats a real good non conductor) call it what you want.
otherwise its lulling you into a false sense of security that its going to give you protection against indirect contact
Old 06-07-2009, 04:43 PM   #21
Mickey_D
The Great White Ghost
Mickey_D's Avatar
Um, then how do Navy ships have safe grounding? If the outlets are using the same ground as the negative wire of the DC system, then it is grounded.
Don't forget, in the UK there are 3 separate connections for a grounded connection. In the US the grounding connector is physically connected together with the neutral at the junction box in houses. We only use a single phase 120V system over here, not the three phase 220/240V system you use. There is nothing compatible between the two. We don't even use the same terminology over here. To us ground = earth.
Using a US system, so long as the round connector at the socket reads zero resistance to the Jeep's negative chassis, it is grounded.
And to whomever said that the battery voltage system on our Jeeps is actually a 6V- and 6V+ system that makes up 12V has obviously never followed where the negative cable from the battery terminates at. The chassis is at 0V and the positive cable is at 12VDC. There is no arguing this. The negative cable is physically and electrically connected TO the chassis to ENSURE the chassis is at 0V.
[EDIT] Just realized YOU were the one stating both things I was talking about...
A big thank you to whomever sponsored my membership!!
1974 CJ-5 258 3spd SOA on 31's [Sold in 1991]
1995 ZJ Limited 5.2 on 31's [Sold in 2009]
1990 XJ Laredo 4.0, nothing special [Sold in 2010]
1955 Willys CJ-5 #12171 [Sold in 2011]
1997 ZJ Limited 5.2 The Great White Ghost
1953 Willys M100 trailer
Mickey_D is offline   Reply With Quote
Old 06-07-2009, 04:58 PM   #22
konarider94
2005 WK
well voltage only measures the difference in potential energy. both the positive and negative to a battery will have no voltage if they cant make a connection to each other. you have to use two leads on a multi-meter.
1994 XJ 2 Door SOLD =(
3"AAL 31x10.5 BFG AT AX-15 NP231
2005 WK Limited 5.7L
245/75-17 goodyear silent armors
no lift, spacers, or cutting required
konarider94 is offline   Reply With Quote
Old 06-07-2009, 05:04 PM   #23
Mickey_D
Mickey_D's Avatar
And it also just dawned on me that I dug this up from a year ago.
Old 06-07-2009, 07:18 PM   #24
chadhargis
2008 WK
Originally Posted by jeepgaffer View Post
Portable generator.
GREAT generator!
That's the one I use to run my tire warmers, fan, radio, cell charge, etc. at the track. It's small (only 45lbs) and will run about 8 hours on a gallon of gas. Pumps out 1800 watts continuous and 2000 peak. It's also quiet as a church mouse.
Chad Hargis
Nashville, TN
2008 Grand Cherokee CRD
chadhargis is offline   Reply With Quote
Glock Forum
