10th Ann. Rubicon wheels and tires test fit - JeepForum.com
post #1 of 10 Old 09-25-2013, 10:06 PM Thread Starter
zc911
i picked up a brand new set of 10th ann. rubicon rims and BF Goodrich KM2s 265/70-17. I have an 07 CRD stock, no lift.
i was hoping i could wedge them on with minimal effort, but it doesnt look like it
First off, the caliper bracket does contact the rims ever so slightly. So i busted out the old angle grinder and ran it up and down the bracket a few times. That gave me about 2mm of clearence which is good enough for me.
the upper ball joint bolt was pretty close, so i zipped that off while i was at it.
All looked good until i turned the wheel and found the pinch weld mod is needed, bah.
i dunno if i really want to cut and bash to fit these tires and rims on, i might sell em and get smaller tires, but it fills the wheel wells out so perfectly
zc911 is offline
post #2 of 10 Old 09-25-2013, 10:35 PM
sickchilly
2010 WK
I found the same things out last weekend. Was hoping I could pop them on before I got a lift. Nope. Why not get a small budget boost? All you need is maybe 1.5" in the front. Would level out the rig nicely too.
I wish I could've found the black 10th anniversary. Got a screaming deal on a set of 13 Rubi rims/tires with only 1400 miles on them (like yours, but dark gray).
2010 Brilliant Black Crystal Pearl Coat Grand Cherokee S-Limited with various bits 'n pieces... broken in but not even finished!
sickchilly is online now
post #3 of 10 Old 09-25-2013, 10:42 PM Thread Starter
zc911
i dunno if a lift will fix the issue, i still think it would need the pinch weld mod no?
I was acutally looking for a set of grey ones, but i got a great deal on these
zc911 is offline
post #4 of 10 Old 09-25-2013, 10:46 PM
sickchilly
2010 WK
Well if you were closer, I'd offer to swap! Lift should fix the issue. There are many on here running the 2" budget boost and clearing 255/75r17 (what we have) or 265/70r17 without pinch weld mods. It seems the 275/285 guys definitely have to do the pinch weld mod. Personally, I'm shooting for around 3" with the OME HD lift. If I have to do the PWM, so be it.
Either way, you're obviously handy with power tools having no reservations about zipping off the ball joint bolt or grinding your calipers. It's no more of stretch to whip out the BFH and whack those things down!
post #5 of 10 Old 09-26-2013, 06:10 AM Thread Starter
zc911
Glad I found the black ones I think they look great!
I think I'll do the pinch weld mod this weekend then. You are right doesn't seem like a huge deal. I am more worried about rust than anything else
zc911 is offline
post #6 of 10 Old 09-26-2013, 06:56 AM
paroxysym
2007 WK
get yourself a strut spacer from JBA or rustys and that will level the front with the rear, and if you have the funds get some bilstein HDs for a slight boost as well.
run a 1" spacer or at the very least a 1/4" spacer up front and you shouldnt hit the punch weld too bad. 1" would be ideal
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #7 of 10 Old 09-26-2013, 10:40 AM Thread Starter
zc911
called the local jeep shops and nobody has strut spacers or even a 2 inch lift in stock, boourns. i need to get these on soon as my stock tires are SHOT so i think i'll be doing some cutting.
zc911 is offline
post #8 of 10 Old 09-27-2013, 01:10 PM Thread Starter
zc911
bah i am going to sell em
if anyone local is interested let me know
zc911 is offline
post #9 of 10 Old 09-29-2013, 07:44 AM
AJeepZJ
2006 WK
Those wheels are hot man.. I've been trying to get my hands on those for a while now. I have a particular custom paint idea in mind for them, Wish you were in NC, I'd have definitely bought them off ya.
All Gear, No Skill.
AJeepZJ is offline
post #10 of 10 Old 09-30-2013, 10:27 AM Thread Starter
zc911
if you are going to repaint them, just get the regular rubicon wheels then, i've seen quite a few of those for sale.
I sold them in day, they are gone. Gonna go ST8 wheels instead
zc911 is offline
