08 WK CRD clicking noise on accel and decel - JeepForum.com
post #1 of 2 Old 08-29-2012, 09:48 AM Thread Starter
gregk1090
2008 WK
I have a 2008 3.0L CRD and I have started to hear a faint clicking/knocking noise coming from underneath the car. It is usually a single click/knock. I first noticed a faint knock when I would start the car, but nothing as far as driving it. I now have started to notice that when I first go to accelerate from a full stop, i will hear the same noise coming from under the car. I also can hear this noise in reverse, and when I'm slowing down to a stop. I have never heard anything while going more than 10 mph. Performance hasn't been affected in anyway.
Has anyone had a similar problem is their WK?
gregk1090 is offline
post #2 of 2 Old 08-29-2012, 12:40 PM
suzieque
2008 WK
there is a TSB related to the front bearing, but I've not heard of this occuring on the 2008 models
http://www.wkjeeps.com/tsb/tsb_wk_0900108.pdf
DIAGNOSIS:
If the vehicle operator describes or the engine is making a tick, knock, rattle or tap noise,
verify the noise by checking the following:
1. Remove the accessory drive belt and listen for sound at 1,500 rpm.
2. Is sound still present?
a. Yes >>> This bulletin does not apply further diagnosis is required.
b. No >>> Proceed to repair procedure.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
click , crd , knock , wk
96 ZJ 242 roaring noise in part time upon decel indianajeep ZJ Grand Cherokee Forum 9 01-30-2010 01:03 PM
Clicking on hard accel... PeteZ28 ZJ Grand Cherokee Forum 0 01-04-2010 05:13 PM
Decel Noise from front - Help EVILUTION ZJ Grand Cherokee Forum 8 11-05-2009 09:27 PM
ZJ: DEAFENING bearing noise, but only on accel! help! aaron7 ZJ Grand Cherokee Forum 7 04-02-2009 04:26 PM
Clayton's Long-arm handling - sways on accel and decel. lbrty9 ZJ Grand Cherokee Forum 17 08-21-2006 02:45 PM
