08 liftgate won't open at times - JeepForum.com
post #1 of 6 Old 04-13-2012, 11:42 AM Thread Starter
wk_hkie
2008 WK
I searched around and only saw threads on the liftgate glass problems and the senor problem but mine will just not open at all sometimes. It has happened several times now, the first was on a really cold day in winter so I shrugged it off but now it just decides to not open some days. Anyone have this problem? I think it may have something to do with the locking mechanism. Would appreciate any input. Thanks.
08 3.7L / Hypertech Programmer / RC 2" / Bilsteins / BFG MT 255/75R17 / JK Moabs / RC 1.5" Spacers / PIAA 510s in factory slots / Thule Moab Basket
wk_hkie is offline
post #2 of 6 Old 04-13-2012, 04:10 PM
Pyroman_28
2006 WK
Might be a good idea to hit the latch mechanism with some lubricant.
'06 WK 4.7 Limited - OME, Bilsteins, AFE, Magnaflow, Superchips, 32's
Pyroman_28 is offline
post #3 of 6 Old 04-13-2012, 11:53 PM
lavern23
I had to put a new lock/latch mech in ours. Took about 20 minutes and $80.00 later it has been fine ever since. Your lucky its working a little. Ours crapped out when the wife got home with a full load of groceries from Wallyworld.
lavern23 is offline
post #4 of 6 Old 04-14-2012, 06:31 AM
Budasac
2005 WK
Like pyroman said.. I would try to hit with some wd-40 to free it up and then a day or two later give it a good shot of white lithium grease to keep it from happening again.
If that doesn't work you need a new latch.
Budasac is offline
post #5 of 6 Old 04-14-2012, 09:39 AM Thread Starter
wk_hkie
2008 WK
Thanks for the input, that was the plan. Hope it won't need replacing
wk_hkie is offline
post #6 of 6 Old 04-14-2012, 10:18 AM
lavern23
I will tell ya it not for lack of lube on the latch. It has everything to do with the solenoid that goes bad that will not actuate when you try to unlock it. I hope for your sake the lube works but if it doesn't and decides to stop working altogether then it a barrel of monies setting in the back taking the interior panel off with the door latched. There is a small square panel that you can flip open and try to access the latch to flip unlocked with a screwdriver.
lavern23 is offline
liftgate
Help-Can't open rear liftgate! vendsit ZJ Grand Cherokee Forum 40 07-16-2013 09:57 PM
How to fix your liftgate when it won't open! MarxZies ZJ Grand Cherokee Forum 5 11-24-2012 02:19 PM
says liftgate is open when closed. i2Fast4U89 ZJ Grand Cherokee Forum 5 12-20-2009 06:48 PM
Liftgate won't open on my 5.9 VastoLorde ZJ Grand Cherokee Forum 29 12-10-2009 08:31 PM
WJ Liftgate Glass Won't Open CrazyWalnut13 ZJ Grand Cherokee Forum 3 03-22-2009 12:48 AM
