08 gc off road question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 08 gc off road question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winch sale-- Best deal you will find. and FREE SHIPPIFree Air Compressor with Purchase of ARB air locker
Unread 04-17-2008, 02:34 PM   #1
tbta02
i have the loaded 08 gc with the stock 18 inch wheels and stock fortera low profile tires with quadra drive II . on my old 4x4 i used to air down but these tires dont have much of a sidewall . can i drive this truck on soft sand at my beach ? and did anyone air done these tires ? i dont want to find out the hard way . is this set up as off road friendly as the 08 with the 17 in wheels ?
tbta02 is offline   Reply With Quote
Unread 04-17-2008, 02:58 PM   #2
RFisher
All I can say is, I took my 08 4x4 off road up to Grand Canyon West. It has 18 inch chrome wheels, with Fortera tires, I stayed in high 4 wheel mode the entire time, and never went over 40mph. I did not lower air pressure, they were at 35 psi cold all 42 miles off roading. Roads were mixed soft dirt / rocks. Driving on the beach however is a lot deeper and softer than soft dirt roads. I suppose you could try it without lowering pressure, and simply lower if you find it is needed. Some how I doubt it will make a difference. Take a emergency tire pump with you just in case. I got one for 20 dollars a few years ago, works great.
RFisher is offline   Reply With Quote
Unread 04-17-2008, 05:42 PM   #3
nick500ss
2006 WK
The Quadra-Drive II system has electronically controlled limited slip diffs front and rear. Traction in soft sand without airing down your tires should not be a problem.
nick500ss is offline   Reply With Quote
Unread 04-17-2008, 07:44 PM   #4
z_gilligan
2010 JK Wrangler
I live in the desert and sand and the only reason I have ever aired down was for a long washboard road. It helps to cut down on the bumps and makes a smoother ride. I have been in sand up to the axle and the Jeep just crawls through it. If you are starting to spin, stop and put it in 4 low.
HIS 2010 Jeep Unlimited Sahara Deep Water Blue
HERS 2006 Jeep Grand Cherokee White
z_gilligan is offline   Reply With Quote
Unread 04-17-2008, 10:52 PM   #5
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Do you have front and rear tow points? DO you have a tow strap? If not, get one. You'll probably either have the opportunity to pull someone else out or get stuck yourself. It is a learning process.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Unread 04-20-2008, 02:55 AM   #6
jeepheller98
yeah, learning the hard way is greatest way to never make a mistake again.. its alright but only if your prepared for any situation
98 ZJ 3" lift homemade snorkel. JKS quicker disco 5.2L 150,000, 31x10.5 pro comp muds
jeepheller98 is offline   Reply With Quote
Unread 04-20-2008, 09:59 AM   #7
greggblue
I don't know about desert sand, but if it's beach sand, I would take your tires down to 25 PSI at a minimum before going on the sand... I've make the mistake in the past thinking QD II would get me through the sand, only to get stuck. the 25 PSI should be ok to drive on the highway for short distances.
Gregg
98 Jeep 5.9 Limited w/ M1 Intake, Mike Leach Headers,Edlebrock Shocks,Carsound Cat,Flowmaster 70 muffler,Kolak Tailpipe,K&N drop in Filter,Full Kolak Ignition Kit, Mopar Peformance ECU, DEI Full alarm w/Remote Start,Clear Corner Markers
JUST INSTALLED: Alpine IDA-x305 Head Unit (Bluetooth, Sirius, AUX, iPod), Focal 130 components, JL 600 Coax
COMING SOON: Alpine PDX 5-channel, JL Stealthbox sub
2008 Grand Cherokee Overland (stock)
2002 Grand Cherokee Overland (stock)
greggblue is offline   Reply With Quote
Unread 04-20-2008, 04:32 PM   #8
tbta02
ive been on the beach alot with my 95 cherokee and always aired down . never had a problem . just looking at the sidewalls have me wondering . thanks for the advice .
Unread 06-23-2012, 11:59 PM   #9
NDSU_Bison
2008 WK
I finally got to break out the tow strap on the beach today. Someone in an F-250 was parked up high on the beach in the soft sand and forgot to put it in 4WD before parking.
He had started shoveling and it didn't look like he was going to get anywhere so I gave up my chance to get some good sunset photos and give him a tug. I was just hoping that I wouldn't dig myself into a hole and he finally made it out after about 30 seconds of me spinning my tires in the sand.
In this scenario, does it make any difference if your in 4-hi or 4-lo? I just left it in 4-hi since I figured I would just end up spinning all 4 wheels with the traction control turned off just like I would in 4-lo.
FWIW, I've driven an XJ, Durango, and my current WK on the ocean beaches without ever getting stuck although I usually stay out of the softer sand.
NDSU_Bison is offline   Reply With Quote
