08-10 Head Unit fit? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 08-10 Head Unit fit?
1989 Jeep Wrangler Clutch Kit with Slave Cylinder for L6 41987-1995 Jeep Wrangler Mirror Manual Folding Pair1987-1989 Jeep Wrangler Brake Pad & Rotor Kit Semi-Met
Unread 07-15-2015, 08:45 PM   #1
plunix
2008 WK
I finished wiring my old double din Kenwood DPX500. I forgot how much better factory can sound after a bit of HPF LPF tuning!
Unfortunately I have a cluster **** of a mess since the head unit will not enter the dash. It keeps hitting something.
I'm not sure why so much limited data is there for this. I can't find any information. Does anyone know if I'm supposed to trim the dash?
2008 Jeep Grand Cherokee CRD
GDE Hot Tune, DPF Delete, Turbo Res. Delete, Exhaust Res. Delete
plunix is offline   Reply With Quote Quick reply to this message
Unread 07-17-2015, 03:34 AM   #2
Marcus86GLHS
when my factory head unit failed in my 2008 I looked for months for an aftermarket unit that would be a true plug and play swap, but, such a unit does not exist. All aftermarket head units from my research either will require modifying the bracing under the dash by cutting away some sections and/or modifying the wiring harness to retain all the factory controls and features.
I said to heck with all that and just got a new factory unit.
2008 Grand Cherokee Limited 4X4, Light Greystone Pearlcoat, Hemi, Tow Group, 18" Chrome Clad Wheels. Original owner, 20,000 miles
2002 Wrangler Sahara, black, 4.0L, 5-speed, Dana 44 rear axle with Trac Loc LSD, duel tan tops, Canyon wheels with Wrangler Silent Armors. 75,000 miles, 2nd owner.
Marcus86GLHS is offline   Reply With Quote Quick reply to this message
