07 GC Sunroof Won't Close All the Way! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 07 GC Sunroof Won't Close All the Way!
Engo winches available at www.rockridge4wd.com! Free shippSwag Off Road BIG-HIT TJ-YJ Rear BumperCyber Sale on RUBICON EXPRESS - Short Arms, Long Arms, Tra
Unread 05-24-2009, 06:44 PM   #1
sost1sg
Today, I noticed that the factory sunroof on my 07 GC does not close all the way. When "closed," the glass no longer meets flush with the roof. It is sunken about 1/4 inch. Naturally, we had thunderstorms roll through this evening. Looks like it fared ok, but we've got a few days of rain ahead. Any ideas on what may be wrong or how to fix it? I've checked the tracks and there doesn't seem to be anything that would block the roof from closing. Anyone else have this problem?
sost1sg is offline   Reply With Quote
Unread 05-24-2009, 06:51 PM   #2
chadhargis
2008 WK
One of the many reason I hate sunroofs. Never have figured out what the attraction to them is. The compromise head room, and eventually, the WILL leak. Not if, but when.
I make every attempt to never use mine for fear of the day when it stops working.
Chad Hargis
Nashville, TN
2008 Grand Cherokee CRD
chadhargis is offline   Reply With Quote
Unread 05-24-2009, 10:20 PM   #3
warrenhaynes
2006 WK
This happened in my 06 the other day. It rained and my garage and sunroof unit was dripping wet. Fortunately, everything still works fine. I open and closed my sunroof a few times (and did the upward tilt/ or vent, whatever its called) and now it works fine.. weird but its all back to normal. Hope this helps.
06 Jeep WK Limited 5.7L HEMI
OME HD 3", 265/70 BFG A/T, AEM Brute Force CAI, Gibson Cat-back Exhaust, Rola Rack, Stainless Brushguard, PIAA 520's, 4xGuard Front Guard
warrenhaynes is offline   Reply With Quote
Unread 05-25-2009, 03:47 AM   #4
merlinTec
Hi two bulletins you might want to look at. http://www.wkjeeps.com/tsb/wk_rapid_response_05-027.pdf http://www.wkjeeps.com/tsb/tsb_wk_2304006.pdf
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline   Reply With Quote
Unread 05-27-2009, 11:34 AM   #5
DavidinHartford
2005 WK
My power sunroof has a mind of its own as well. I usually wait until I'm parked to close the roof, this way I can make sure to give it a push up by hand to make sure it sits flush.
I don't even use the vent feature anymore.
2005 Grand Cherokee Laredo, Inferno Red, Chrome grille, Export taillights, Front windows tinted to match.
DavidinHartford is offline   Reply With Quote
Unread 05-27-2009, 12:30 PM   #6
konarider94
2005 WK
mine does the same thing but it doesnt leak. it is noisy on the road though. sometimes it wont even close. it will go to the end and return to half open. its very annoying
do dealerships have to perform this tsb free of charge?
1994 XJ 2 Door SOLD =(
3"AAL 31x10.5 BFG AT AX-15 NP231
2005 WK Limited 5.7L
245/75-17 goodyear silent armors
no lift, spacers, or cutting required
konarider94 is offline   Reply With Quote
Unread 05-27-2009, 01:50 PM   #7
Texas WJ
Texas WJ's Avatar
2005 WK
No. Could they? It's possible, but doubtful.
Texas WJ is offline   Reply With Quote
Unread 05-27-2009, 01:54 PM   #8
konarider94
2005 WK
well im at 68,000mi so i better get in before 70k.
Unread 05-27-2009, 04:17 PM   #9
merlinTec
The RRT yes the TSB no.
Unread 05-27-2009, 05:42 PM   #10
konarider94
2005 WK
well i have the 2005 and that rrt says it only affects 2006. but it sounds like the exact problem i am having
Unread 09-15-2011, 11:17 AM   #11
JeepGC07
2007 WK
I had this issue on my 2007 GC and it's a simple, free fix. You just need to reset the sunroof. This link spells out the full process, but all you need is steps 7-12 and this should solve the issue. Then slide it open and enjoy the sunshine!
JeepGC07 is offline   Reply With Quote
Unread 09-15-2011, 11:34 AM   #12
Jeep_Country
I have the same exact problem, called the stealership within a week of buying it and they told me to blow out the drain tubes with some compressed air. Lots of help, not.
Jeep_Country is offline   Reply With Quote
Unread 01-15-2012, 09:41 AM   #13
land234
Just had this issue myself, did steps 7-12 and worked perfectly!
Thanks for that!!
land234 is offline   Reply With Quote
Unread 01-15-2012, 02:15 PM   #14
GrilledJeep
2005 WK
I walked through sunroof hell this summer, with rain every other day.
Finally I reset it by having it open halfway, pulling the battery, the fuse....plugging it all back in after 2 min and have not had one issue since last august.
GrilledJeep is offline   Reply With Quote
Unread 04-06-2013, 09:52 PM   #15
jk_jim
I have a 2004 Grand Cherokee and mine was not coming up flush when it closed. Check this simple fix first. Close the sunroof to where it naturally stops when it is shut. Check on the outside it should be about 1/4 inch down on the back side. Push gently up on the glass until it stops (at the back of the glass). Locate the 4 torx screws (2 on each side). They are between the headliner and the sunroof (these screws run horizontal). Just tighten these torx screws (size 25). It fixed mine. Free and simple just they way I like it.
jk_jim is offline   Reply With Quote
