07 GC 3.0L CRD Transmission Problems. - Page 2 - JeepForum.com
post #16 of 31 Old 01-29-2013, 07:48 AM
DieselDevotion
2007 WK
Originally Posted by sfsocal
When I try to drive, the engine revs, but, the truck barely moves, like a bad clutch if it was a manual. Any suggestions? I guess I'm at the point that I need to tow it to a repair shop.
I haven't heard of it on these trannys but I have seen a couple guys with hemi's have their trans filter come off and cause the same problem. Is the problem something that has been slowly getting worse or did it happen all of a sudden?
07 Grand Cherokee Limited 3.0L CRD QDII
89 5.9 Cummins powered F350
98 TDI Jetta
DieselDevotion is offline
post #17 of 31 Old 01-29-2013, 09:11 AM Thread Starter
sfsocal
2007 WK
It was sudden.
sfsocal is offline
post #18 of 31 Old 01-29-2013, 10:00 AM
Radcrd
2007 WK
Originally Posted by sfsocal View Post
I got the Miller dipstick today, but, not the scanner, yet. I put the dipstick in with the engine cold just to see if there was any fluid. I was hoping there wasn't, so it would be easy to diagnose
As it turns out, it read 60. So, it isn't low transmission fluid causing my problem.
Your level seems low, see this thread for more info: http://www.jeepforum.com/forum/f67/c...l#post14383948
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #19 of 31 Old 01-29-2013, 10:37 AM Thread Starter
sfsocal
2007 WK
That was the reading without even running the engine. It was completely cold. Since I can't read the temp yet, I just wanted to see if it had any fluid. I figured that if it had all leaked out, it would be easy to figure out.
sfsocal is offline
post #20 of 31 Old 01-29-2013, 11:06 AM
Radcrd
2007 WK
My level NOT running car sitting overnight was between 80 and 82mm. Temp 60* ambient. I increased it to 85mm and it has been better. Not perfect but better.
At 60mm I think you are WAY low. Add a bit at a time and re-check.
3 VW TDI's (sold)
Radcrd is offline
post #21 of 31 Old 01-29-2013, 11:48 AM Thread Starter
sfsocal
2007 WK
Good feedback. Thanks! This morning, my serpentine belt broke. This thing is killing me!
sfsocal is offline
post #22 of 31 Old 01-29-2013, 12:56 PM
Radcrd
2007 WK
LOL! Mine slipped off a few days before New Years... Tensioner had failed, had to wait till after holidays to get parts! Was down for almost a week.
3 VW TDI's (sold)
Radcrd is offline
post #23 of 31 Old 02-23-2013, 08:42 PM
bugsybdb
2007 WK
First off I dont want to jack this thread, so if I need to move this question please let me know. I have a 07 Grand Cherokee CRD. Today I drove to the mountains without a problem. Climbed the mountain like a champ. While coming down I was using a lower gear to conserve the brakes. I upshifted to 5th gear when the terrain leveled out, and it sounded like it was still in 4th gear. All of a sudden I heard a bang and the transmission went to fith gear, but there was a rattling noise from under the jeep. I went into Neutral and then back in drive gear. It sounded fine for about 30 seconds then the rattling noise with a feel of loss of power. It felt as though something was bogging me down. It sounded like the rattle was up front but not sure. I had to pay $200 dollars to tow it to my house. First does anyone know what this is, and second would the mercedes dealer be the best to take it? Third would this be covered under power train warranty?
bugsybdb is offline
post #24 of 31 Old 02-24-2013, 04:04 PM
Nejeep
My NAG1 transmission level runs about 80mm after sitting overnight, so I agree your level is too low. Be careful not to over fill.
Some common leak points are the electrical plug on the passenger side of the transmission and the rubber cooling lines near the radiator. Several threads on here if you need more info.
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #25 of 31 Old 02-24-2013, 04:22 PM
SSF556
2008 WK
Not sure what the issue is, but I would advise against the mercedes dealer...they will tell you to take it to the Jeep dealer....just tow it there.
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #26 of 31 Old 02-24-2013, 06:26 PM
fishinbama
2007 WK
The fifth gear means you are in limp mode. Don't drive it far at all in limp mode, it will tear up more stuff. If you can hear a noise, maybe you could try to pinpoint from where? Also, you could get a scanner to read the codes.
2007 limited crd 2wd, 3.07 ratio, GDE eco tune, dpf delete, tnadanzig resonator delete
fishinbama is offline
post #27 of 31 Old 02-25-2013, 08:27 PM
bugsybdb
2007 WK
Well I threw it in neutral and coasted down the hill to a business and called a tow truck. $200 later I had it home. I called the Mercedes dealer (before I received your reply) and they told me to take it to a Jeep dealer. The jeep is there now and the service guy stated he will look at it today or tomorrow and try to diagnose it for me. We will see how good the extended warranty is, and I will post a reply of what the out come was.
bugsybdb is offline
post #28 of 31 Old 02-25-2013, 08:29 PM
bugsybdb
2007 WK
Oh yeah, sorry but I have the Green Diesel Tune, and checked for any codes. None showed up. I also tuned the Jeep back to stock before delivery to the dealership.
bugsybdb is offline
post #29 of 31 Old 02-27-2013, 06:41 PM
bugsybdb
2007 WK
Ok so the dealer has had the jeep GC for two days now and they think they diagnosed the problem. First they say they found a broken front differential I think it was an issue on another thread. http://www.jeepforum.com/forum/f67/h...ft-r-n-824555/
Which was not covered under the Chrysler powertrain warranty, but luckily I purchased the extended warranty and that covered it. Second they said they found that the Yolk was loose and needed to be replaced. That was covered under the Chrysler powertrain warranty. I should get the truck back in a about two days and we will se if that fixes the problem. All in all with the extended warranty it will cost me about $50 for the deductible. I sure am glad I bought the extended warranty. I will post another reply when I pick up the jeep to see if that fixes the problem.
bugsybdb is offline
post #30 of 31 Old 02-27-2013, 09:47 PM
Tuco
Tuco's Avatar
2007 WK
That is great that your warranty will cover most. But why did it break in the first place and what exactly broke?
07 WK CRD Limited
Tuco is offline
