07 GC 3.0L CRD Transmission Problems. - JeepForum.com
post #1 of 31 Old 01-16-2013, 04:27 PM Thread Starter
sfsocal
2007 WK
I need advice. I am having transmission issues. Should I take it to the dealer, or to someplace like AAMCO? I have an 07 GC 3.0L CRD. Every dealer I take it to, asks if I bought it in Europe. I took it to a dealer to have a glow plug changed. They had it 10 days because they ran out of fuel, and then had to vent the engine, which resulted in covering the entire engine with diesel fuel. They also broke something that had to be ordered, and on and on and on.
I suspect that the tranny isn't unique, but, still wonder if transmission folks are better than dealer techs.
sfsocal is offline
post #2 of 31 Old 01-16-2013, 04:32 PM
jjt250
2007 WK
The CRD uses the same transmission as the 3.7 V6 and the SRT8 so any dealer should be able to service it.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #3 of 31 Old 01-16-2013, 06:46 PM
fishinbama
2007 WK
I wouldn't go to aamco. Personally, I had bad luck with them(long ago) and now equate them with somewhere between scam/honest dealer. Don't let Aamco tear your transmission down, they will charge you to put it back together.
2007 limited crd 2wd, 3.07 ratio, GDE eco tune, dpf delete, tnadanzig resonator delete
fishinbama is offline
post #4 of 31 Old 01-16-2013, 07:24 PM
90grandoneer
90grandoneer's Avatar
2006 WK
I believe the CRD's have the NAG1 transmission (no dipstick), which is a Mercedes transmission. They should be able to work on them reliabily and without screwing it up. I don't think too many of the Jeep dealers are equipped (knowledge, technicians, tools, etc.) to the best job possible. The first thing I'd do is take it somewhere that has the correct equipment to check the fluid level. It has to be a certain level at a certain temperature. When was the last time it was serviced? Do you have any trans. shops in your area that are trustworthy, reliable and knowledgeable? Personally, I would stay away from the chains, like Aamco. Seems as though that's the same type of thing as going to Jiffy Lube for an oil change. Remember, these things a controlled electronically, and if serviced in a timely manner and fluid level is properly maintained, they seldom have problems. I have a NAG1 in my Hemi LX and it's worked flawlessly for over 7 years. Good luck and let us know what you end up finding.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #5 of 31 Old 01-16-2013, 07:47 PM
BAH101
2008 WK
You could look for a dealer who services sprinter vans, they will have more qualified techs with CRD experience
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #6 of 31 Old 01-16-2013, 11:10 PM Thread Starter
sfsocal
2007 WK
Thanks for the great advice. It is the Trans w/o a dipstick. 90grandoneer, is your recommendation to take it to a Mercedes dealer for the transmission work?
sfsocal is offline
post #7 of 31 Old 01-17-2013, 10:03 AM
90grandoneer
2006 WK
Yes, it wouldn't be a bad idea to ask them if they can help you, if your tranny is substantially the same as the ones in the Benz's. They probably wouldn't be able to do much IF you need to have the TCM updated though. That would require the Starscan, which they probably don't have. Also, don't know who makes the diesel in the WK, but the MB folks are also diesel knowledgeable. I know one of the main reasons I bought my Hemi LX is because of the Benz association, plus I've been a Benz owner for almost 30 years. My LX also has quite a few Benz components.....seats, transmission, suspension, etc.
post #8 of 31 Old 01-17-2013, 12:15 PM
jjt250
2007 WK
The diesel is a Benz engine so they should be able to service that too.
jjt250 is offline
post #9 of 31 Old 01-17-2013, 06:29 PM Thread Starter
sfsocal
2007 WK
I had thought about taking it to a MB dealer for the engine, but, I read in another thread that some of the parts are Jeep. I think it is still a better idea. Thanks!
sfsocal is offline
post #10 of 31 Old 01-18-2013, 04:41 PM Thread Starter
sfsocal
2007 WK
How do I put fluid in? Do I remove the cap on the dipstick tube and feed it in there?
sfsocal is offline
post #11 of 31 Old 01-18-2013, 05:14 PM
DieselDevotion
2007 WK
Yes but don't overfill. You'll need a scan tool capable of reading trans temp to properly measure the level. They make funnels specifically for filling the trans.
07 Grand Cherokee Limited 3.0L CRD QDII
89 5.9 Cummins powered F350
98 TDI Jetta
DieselDevotion is offline
post #12 of 31 Old 01-18-2013, 08:44 PM Thread Starter
sfsocal
2007 WK
OK. I've ordered the Miller 9336a dipstick and an 'INNOVA 3160B ABS/SRS+ Professional CanOBDII Diagnostic Code Scanner with Enhanced Live Data'. My current scanner can't do live data. It's new, so I'll return it. Do I need a special tool to take that cap off?
sfsocal is offline
post #13 of 31 Old 01-18-2013, 08:52 PM
Radcrd
2007 WK
no just pull it off. the Miller tool will not go in all the way. this is normal. Just be sure it touches bottom of pan ( you will feel it )
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #14 of 31 Old 01-28-2013, 07:16 PM Thread Starter
sfsocal
2007 WK
I got the Miller dipstick today, but, not the scanner, yet. I put the dipstick in with the engine cold just to see if there was any fluid. I was hoping there wasn't, so it would be easy to diagnose
As it turns out, it read 60. So, it isn't low transmission fluid causing my problem.
When I try to drive, the engine revs, but, the truck barely moves, like a bad clutch if it was a manual. Any suggestions? I guess I'm at the point that I need to tow it to a repair shop.
sfsocal is offline
post #15 of 31 Old 01-29-2013, 12:52 AM
FrenchXj
1992 XJ Cherokee
if you are lucky it is Probably the same problem they have on WH, the actuator stay stuck... need to pull it appart, clean it, flush the transmission and go
FrenchXj is offline
