07 Commander problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 07 Commander problems
Stainless Steel Door Hinge PinsPoly Door Hinge BushingsFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 08-11-2014, 11:02 PM   #1
Puck81
Puck81's Avatar
My wifes 07 4.7 2wd limited Commander is having some kind of electrical issue. She will be driving then the dash lights will flick on and off and the hvac will flick on and off at the same time. The head lights flick on and off with the dash and the hvac as well. Now the motor is starting to die a the same time when this issue starts. It seems to be a random occurrence, but its getting worse. I have replaced the alternator and battery at the same time so far. I really need to get this problem resolved, so any insight would be greatly appreciated.
Puck81 is offline   Reply With Quote
Unread 08-13-2014, 11:28 AM   #2
Puck81
Puck81's Avatar
Bump.
So no one here has had this issue at all? There is no aftermarket parts installed. This is factory stock other than replacement parts on the motor.
Unread 08-13-2014, 11:34 AM   #3
colinzj
2006 WK
Ignition switch.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline   Reply With Quote
Unread 08-13-2014, 12:16 PM   #4
Puck81
Puck81's Avatar
Thanks for pointing me in the right direction. I got the info I needed from Chrysler.
