Quantcast 06 XK Differential Service Question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 06 XK Differential Service Question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 08-01-2009, 06:17 PM   #1
ciscore
1997 XJ Cherokee
Is front differential made to just use the drain plug and then refill without actually taking the cover off and cleaning it out? Also, does the front need the friction modifier? Thanks.
His - 97 XJ Sport
Hers - 06 XK
ciscore is offline   Reply With Quote
Old 08-01-2009, 06:20 PM   #2
Texas WJ
Texas WJ's Avatar
2005 WK
Is the Commander a Quadra-Drive model or not? If it is, then you'll need the friction modifier. Otherwise you don't.
And yes, just drain and refill.
Texas WJ is offline   Reply With Quote
Old 08-01-2009, 06:22 PM   #3
ciscore
1997 XJ Cherokee
Yep its the quadra drive. The dealer parts lady said she thought I only needed it in the rear, but from what I understood, my XK has ELSDs in both front and rear. Thanks!
His - 97 XJ Sport
Hers - 06 XK
Old 08-01-2009, 07:09 PM   #4
Texas WJ
Texas WJ's Avatar
2005 WK
Yep, the friction modifier is for both the front and rear.
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
