'06 Won't start after it heats up - JeepForum.com
post #1 of 8 Old 06-27-2013, 08:26 PM Thread Starter
Drew2675
2006 WK
Here's my dilemma. I have an 06 grand limited hemi. Lately it's been not wanting to restart after it gets to temp. Turn the key and nothing happens. The dash and radio fire up and I can hear a click which I assume is the relay but nothing else. It'll start fine when it cools back down. It's been running fine and no other problems. I've done the usual searches to check on remedies for this issue and have found a couple possibilities like yellow wire on solenoid and having the battery checked. It just seems this problem is more predictable than an intermittent not starting issue. Just wanted to pick some brains before I tackle this. Any info is much appreciated. Thanks.
Drew2675 is offline
post #2 of 8 Old 06-27-2013, 11:39 PM
WieSeL
Do you hear the starter click?
WieSeL is offline
post #3 of 8 Old 06-28-2013, 08:48 AM Thread Starter
Drew2675
2006 WK
No. Nothing but a faint click from what I'm guessing is the relay.
Drew2675 is offline
post #4 of 8 Old 06-28-2013, 09:25 AM
ehron
Electrical resistance increases with temperature. I wonder if your starter is getting an appropriate amount of current from the battery when warm. Could your starter solenoid be bad?
The starter has a heat shield over it. Is that still in place?
If your Jeep is 2wd it's pretty easy to pull the starter. If it's 4wd it's a colossal PITA. If you are able to pull it you could have it tested at a place like Autozone.
ehron is offline
post #5 of 8 Old 06-28-2013, 09:25 AM
jamie1131
2003 WJ
This could be as simple as a flat battery. A hot engine can harder to turn over than a cold engine as component expand and compression improves. Normally though the engine will turn half a revolution then baulk.
jamie1131 is offline
post #6 of 8 Old 06-28-2013, 09:26 AM
WieSeL
Check power to the starter at the starter solenoid signal wire. If it's getting power but nothing happens it's the starter
WieSeL is offline
post #7 of 8 Old 06-28-2013, 09:59 AM
ehron
Dur. Tha'ts the easiest thing to check. What's your batteries resting voltage? Carry a volt meter, and check it when it's hot and won't start.
ehron is offline
post #8 of 8 Old 06-28-2013, 12:47 PM Thread Starter
Drew2675
2006 WK
Just went and checked the battery. 12.48 volts resting. I'm leaving here in a bit to tear the wheel well out to access the starter. I'll check the other things then. And yes, the heat shield is still around the starter.
Drew2675 is offline
