06 WK front passenger power window - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 06 WK front passenger power window
Dana 30 Truss for your TJ, LJ, ZJ, and XJFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 08-20-2014, 03:36 PM   #1
mkmk
2006 WK
I'm going through my list of needed improvements before winter, and the front passenger window is a little wonky. It always works, but sometimes is a little uneven in motion, and occasionally the motor reverses and lowers back down an inch or so after closing it (you can then raise it with the switch, and it stays up).
Should I just go ahead and replace the whole motor/regulator assembly? Any preferred sources?
mkmk is offline   Reply With Quote
Unread 08-21-2014, 10:34 AM   #2
Mitkch
2007 WK
Try resetting it, first. There's a few threads floating around regarding the issue.
Edit: Here's one of the posts I mentioned: http://www.jeepforum.com/forum/f67/s.../#post11820661
Black WK Club #138
Mitkch is offline   Reply With Quote
Unread 08-21-2014, 10:48 AM   #3
mkmk
2006 WK
Ah -- thanks for the tip! I'll try that.
Tried it -- seems like the auto-reversing is better, but it still has an inconsistent, uneven motion going up (the motor sounds like it's straining ("err.. err... errr..."), so I'm guessing it's on its way out.
Unread 08-21-2014, 02:54 PM   #4
Mitkch
2007 WK
Mine also sounds like it strains. Though it's been doing it for the past three years so I'll just wait for it to go out before I do anything.
Black WK Club #138
Unread 08-21-2014, 03:29 PM   #5
Jaashua
2005 WK
I've been waiting for mine to die so I have an excuse to buy one.
Jaashua is offline   Reply With Quote
Unread 08-22-2014, 12:26 PM   #6
mkmk
2006 WK
With my luck, if I do that, the day it dies it will be 20 below.
