06 Jeep Grand Cherokee Engine Replacement ? - JeepForum.com
post #1 of 9 Old 03-19-2017, 07:35 AM Thread Starter
pete2833
I just picked up a 2006 Jeep Grand Cherokee 3.7 4x4 for my son who is turning 16. It needs an engine so we are going to pull it and replace it. Great project for the 2 of us and he will learn some valuable skills. Question is, I know I need an 05 and newer engine but will other models work? Will 3.7's out of Libertys, Commanders, Dakotas etc work ? Up to what year also ? Any help would be great.
Pete
pete2833 is offline
post #2 of 9 Old 03-19-2017, 03:46 PM Thread Starter
pete2833
Will an 06 3.7 out of a Jeep Liberty work ?
pete2833 is offline
post #3 of 9 Old 03-19-2017, 05:13 PM
Nejeep
Yes I believe a 3.7 Liberty engine will "work" but a number of parts will need to be swapped over from your WK engine (oil pan, mounts, etc). Here is a link to an older discussion on a 3.7 engine swap.
http://www.jeepforum.com/forum/f67/a...-time-3875833/
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #4 of 9 Old 03-19-2017, 05:40 PM
TwoBobsKJ
2003 KJ Liberty
Any 3.7 block from '05 and later will work with your GC - the cam sprocket timing ring and the crankshaft reluctor ring (also a timing ring) will be the correct ones for use with your computer.
As mentioned by Nejeep the external components are what you'll need to swap over if the engine didn't come from a GC from the same year. So if you grab an engine from a Dakota for instance, look closely at the exhaust and intake manifolds, oil pan, and oil filter drain trough to see if they're different from your GC. The A/C, alternator, power steering pump and serpentine belt tensioner will just swap over from your GC engine to the replacement.
Kudos for taking on this project with your son. The project is not complicated but requires attention to detail so make sure everything is reassembled property. Attention to detail and focus are good things to teach 16 year olds - LOL!
I swapped a 2009 3.7 from a Dodge Dakota into my '03 Liberty and had to change out the things I listed above - plus break down the '09 engine and put in the correct cam sprocket and reluctor ring so they matched my computer. Even with that I did the project in my two car garage over 4 days while doing my sales calls and working evenings. Couple of buddies and my dad helped out - still have fond memories of the project and the Liberty is still going strong after 106,000 miles on the replacement engine.
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
post #5 of 9 Old 03-20-2017, 06:19 AM Thread Starter
pete2833
Thanks for the advice. I have pulled engines and put them in old muscle cars when I was in high school. No electronics then !!! I agree, I think my son will learn some valuable lessons working on it with me. Most 16 year olds now a days don't even know how to change a tire, at least where I live.
I found several Jeep Liberty Engines that are a little cheaper than the Grand Cherokee engines. Will I have to change the Intake and Throttle Body ?
Pete
pete2833 is offline
post #6 of 9 Old 03-20-2017, 06:55 AM
Nejeep
Your 06 WK throttle body (and computer) is not drive by wire, so if your replacement engine is drive by wire you will have to change the throttle body at least.
I expect you will need to closely inspect the intakes to see if your donor will work or need to be changed to the 06 WK intake. The 06 WK does not use an EGR valve but it can be removed and blocked off if thats the only difference.
Nejeep is offline
post #7 of 9 Old 03-20-2017, 06:14 PM Thread Starter
pete2833
Ok. I found a 06 3.7 from a Jeep Grand Cherokee so I should be good to go.
Thanks
Pete
pete2833 is offline
post #8 of 9 Old 03-21-2017, 05:08 AM
Nejeep
Yes, finding a matching WK 3.7 engine should greatly simplify the swap. Any history on the "new" engine?
Keep us posted on the progress of the swap and the "training program".
Nejeep is offline
post #9 of 9 Old 03-21-2017, 06:59 PM Thread Starter
pete2833
My son and I worked on it some today after he got home from school. Nice thing is we have plenty of time and can take our time. We drained the antifreeze and not much came out. Couldn't get the petcock open either. Next drained the oil and found the missing antifreeze. It was like a river coming out of the crankcase. So my theory is the head gasket was blown and the previous owner ran it and smoked the main bearing. Got all the fluids out and got the engine to spin by hand. Must have been hydro locked. We got the fan and shroud out. The A/C compressor moved out of the way along with the Power Steering pump. Removed the belt, the intake tubing, the throttle body, the strut brace and bunch of plugs. We labeled all plugs and bolts. everything is organized. Next will be the starter, intake, bell housing bolts, torque converter disconnect, exhaust pipes, and motor mounts. The hood also. Sure there as some little things I'm missing. More to come.
Pete
pete2833 is offline
