06 grand cherokee will not move - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 06 grand cherokee will not move
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiFree shipping on slip yoke eliminator kits New lower PriceNew! JK/U skid plate system.
Unread 05-12-2015, 09:00 AM   #1
trinjeep
wife parked it last night when she got home, next morning the shifter moves but just revs up, in drive and reverse. its a limited awd with 4.7
trinjeep is offline   Reply With Quote Quick reply to this message
Unread 05-12-2015, 09:01 AM   #2
trinjeep
i tried leaving it running for a few minutes and then tyrying it but still nothing
Unread 05-12-2015, 09:20 AM   #3
safe+fit
Any codes? Check engine light or service 4wd system on display? There's a trick you pull a fuse and engage trans pull forward and plug fuse in again. I haven't had to do it yet luckily...
Search for it.
safe+fit is offline   Reply With Quote Quick reply to this message
Unread 05-12-2015, 09:49 AM   #4
trinjeep
yes p0 0700 and a couple emission codes but dealer said there were 97 codes stored from radio, sunroof, rain sensing wipers, hvac, power seat, heated seat, tcm, ecm, cooling fan which did blow the fuse when i tried to replace it before it went to dealer, but everything else has no issues
Unread 05-12-2015, 11:06 AM   #5
joe989
2008 WK
I wonder if your transfer case is in neutral? 700 is a generic request from the TCM to turn the MIL on. Try pushing the vehicle while it's in park, if you can move it, chances are the transfer case went in to neutral, theres a recall called N23 that was enacted in response to the transfer case computer sending false signals to the shift motor, when damaged, to shift into neutral. The recall was designed to disable the shift motor should it sense improbable situations, a lot of people who had this recall done, had it done improperly and it was disabling perfectly fine transfer cases. At any rate, I would start there.
joe989 is offline   Reply With Quote Quick reply to this message
Unread 05-12-2015, 11:23 AM   #6
trinjeep
it is sitting at the dealer right now, they wanted to know how many hours we wanted them to spend so i put it on hold until i done some further research. what if it will not move while in park? When i did shift it i thought i could feel a light vibration in the brake pedal like most vehicles when the come out of park
Unread 05-12-2015, 11:52 AM   #7
yzjwk
2005 WK
If you have a P0700 code then you have other 700 series codes and they are more than likely not from history. If you haven't had any prior issues then I would say you're either low on transmission fluid or your electronic shift on ESM is dirty or defective. Does your display show [P][R][N][D] by chance ? That usually indicates a problem with the Electronic Shift Module .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline   Reply With Quote Quick reply to this message
Unread 05-12-2015, 03:08 PM   #8
trinjeep
not sure. i will find out, what if it does?
Unread 05-12-2015, 03:21 PM   #9
colinzj
2006 WK
A Jeep dealer asked that question?
Exactly how much rocket science do they think is involved in diagnosing a 545RFE? Cripes, basic diagnosis is flat rate at every dealer I've ever been to.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline   Reply With Quote Quick reply to this message
Unread 05-13-2015, 04:03 AM   #10
trinjeep
sounds like it might be a wallet full of rocket science!
Unread 05-15-2015, 01:44 PM   #11
Frozentoze
2006 WK
This same problem happened to my 06 wk 4.7. It would come in and out of park but all gears behaved like neutral. Confirm it goes into park and neutral - if it Stays in park only then it can be the shifter and there are manual overrides and cleaning threads online for that. But if it was like mine and went into and out of park / neutral, then read on. The dealership towed it at their expense (long story) and told me the filter inside the transmission had popped off. Fixed it free of charge, no recurrence in 20k since.
So it should cost the same as tranny fluid and filter service and have them replace both filters. One just snaps in I guess and they said it had popped out.
Frozentoze is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 01:32 PM   #12
JeepCares
FCA Customer Care
JeepCares's Avatar
Hey Frozentoze,
Thanks for providing input. Glad to hear your issue was resolved!
Andrea
Jeep Social Care Specialist
JeepCares is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 10:07 PM   #13
KSomes
2005 WK
I had the exact problem as well. Drove home fine, but the next morning would not move. Every gear acted as if it were neutral. Turned out to be what was said above, the spin on filter for the trans came loose so no fluid could be primed.
2005 Jeep WK 5.7L
Build: http://www.jeepforum.com/forum/f22/teen-work-jeep-wk-build-1573427/
KSomes is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 09:57 AM   #14
trinjeep
Thanks having the dealer look into it, but they cant for another week
