'06 Grand Cherokee V8 rough idle and erratic RPMs - Page 3 - JeepForum.com
post #31 of 32 Old 11-27-2013, 07:14 AM
DVB
2006 WK
Yeah, lately that's all I've been looking at (RPM's) It started bouncing at 500 and 300 right before it died this morning. The last 2 times it happen seemed to be shortly after starting up in the morning. The last time my wife took it to the store (about 3 mi away) and it died in the parking lot while she was waiting for a car to pull out of a spot. I'm certain there was no more than 1/2 tank of gas that time and this morning I have less the 1/4.
As for surges, yes, If I accelerate to like 40mph and then let off the gas, when it gets down to 1000rpms it'll surge to 1500 then quickly back down. There are other times when I'm 40-50mph and let off the gas and it doesn't slow down, it just hangs there for a while..
2006 4.7 Limited QD II, Stock
DVB is offline
post #32 of 32 Old 06-15-2017, 01:00 AM
viator
2008 WK
Originally Posted by caulk04 View Post
Do you hear any whistling (loud to moderate) that you can tell for sure isn't coming directly from the throttle body?
You could also spray a small shot of carb/brake cleaner at the hose connections or other suspect areas. If the idle goes up in relation, there would be a leak there.
I *DO* hear a (new) whistling noise. It's not terribly loud at city driving speeds, but ~40 and up -even at 80- I can hear it no prob in the cab.
Been getting slow cat response codes every couple hundred miles as well. Replaced a bank 2/2 O2 sensor that had been throwing a code non stop about a month ago, and that code has stopped. But now new issues.
NECROPOST, I know. Sorry. But at least I searched.
2008 WK Limited: 5.7L Hemi, QT2, stock.
RIP built '00 XJ
viator is offline
loss of power , rough idle , rpms , stalling at stop
