06 Cherokee, HEMI, Rear end noise? - JeepForum.com
post #1 of 9 Old 04-19-2011, 08:47 PM Thread Starter
midgetracer56
2006 WK
I have a 06 Grand Cherokee Limited, HEMI, QDII. I am experiencing a whine coming from the rear when I am on the accelerator. Noise is only present when it is under a load, let off the gas and coast the noise goes away. Shop I took it to started with the pinion bearings in the rear diff., no change. Did find some "tight" spots in the u-joints on rear shaft, sent the shaft to the driveline shop and had shaft balanced and it checked ok. Removed the complete rearend and sent it to driveline shop and had everything gone thru, ring and pinion mesh pattern and backlash and so forth, shop said everything fine. Replaced front driveshaft, Have put close to 5k miles since all that work and problem still there. Called driveline shop again and they stated another Cherokee had come in with the same symptoms. They balanced the rear shaft on that one and said it checked fine also, but admitted that there machine does not check balance while the shaft is under a "load". My thinking is that since the noise is only produced while under a "load" that the problem is with the rear drive shaft. I have done a lot of research on the web and this seems to be a common problem, but I have not yet found where someone has found a cause for or a solution to this problem. Can someone please point me in the right direction. Thank you.
midgetracer56 is offline
post #2 of 9 Old 04-20-2011, 07:35 AM
meep
2008 WK
gears whine. an out-of-balance shaft shakes. different symptoms. assume you are out of warranty? you've put a lot of $ into this problem already.
If the mesh pattern is fine on the R&P then there's not too much to worry with... that's where whine comes from. I'd lift the rear, grip the input shaft and try to wiggle it for play. if it's out of mess or tensioned wrong or the bearings are going, you should feel it. if it doesn't budge and is rock solid, I'd just drive it. make sure you have the 140 weight lube in there, a good synthetic-- may mask the noise some.
I just bought some amsoil for my 2wd 3.7 last week and the shop told me they've had problems with the axles in the WK and no longer works on them. They will buy Jasper remans but find that if a jeep rear end comes in broken, and they rebuild it, it usually returns later with problems. This is a highly-regarded shop-- I tend to trust their advice, especially since it's so consistent among their different staff.
M
meep is offline
post #3 of 9 Old 04-20-2011, 07:36 AM
meep
2008 WK
hey are you certain it's not the t-case?? Chain-drive EATS fluid. Pour something good in there....
M
meep is offline
post #4 of 9 Old 08-15-2013, 08:21 PM
ChuckDodge
2006 WK
Same Whine had it fixed
ive got a 06 4.7 4x4. the dealer told me the whine I was hearing was the pinion bearing, so I had the guts of the thing yanked out and replaced, fixed it for a few months. I actually have the pinion bearing and the thing had pits out of it. however the people who did it didn't also put the wheel and axle bearings in, therefore it is whining again. you can order a rear end for between 700 and 1600 depending on what you have from auto parts fair.
If you can't four wheel it, race it, mud bog it, and use it as a Mercedes, I don't want it.
ChuckDodge is offline
post #5 of 9 Old 08-28-2013, 10:59 AM
Xmind
2007 WK
Interesting. I have noticed a distinct whine from the rear (well possibly transfer case area) under acceleration. Most noticeable around 35-50 MPH, but then road noise drowns it out. I don't know when this noise really started, but I don't recall hearing it when I first got the Jeep 4 months ago. I did change all driveline fluids (front/rear diffs and transfer case). The rear end fluid looked very clean and definitely no particles that I could see. I put in the right weight oil Lucas oil + Redline friction modifier for the diffs, and 2 quarts of the Mopar spec'd fluid for the transfer case.
Jeep seems to drive fine, no binding, no "dragging" feeling, just an almost annoying whine under acceleration...even light acceleration. I guess I can say I only noted the whine about 1500 miles ago....but only noted because a passenger mentioned how loud it was for them in the back.
I checked the rear end fluid and it is still topped up to the fill plug.
Is there anything else I can before replacing parts or taking it to a dealership?
'07 GC CRD QDII, EHM, GDE ECO, DPF & intake rez delete, Paramount Perf Valve Body, Roof drain mod
Xmind is offline
post #6 of 9 Old 03-25-2014, 11:35 PM
2007jeepwk
Rear end noise
I drive a 2007 5.7 hemi Cherokee and have had the same problem. The noise is almost deafening and I have been advised to use ear plugs while driving. I had the transfer case, transmission, and differential fluids all check and they were all fine. I finally took it in to the Mazda dealer where I bought the vehicle and the head mechanic was sure it was either a pinion or wheel bearing. He told me that the rear end was sure to fall out soon. I have driven the vehicle around 5,000 miles since the problem started.
Anyone had the problem fixed completely?
2007jeepwk is offline
post #7 of 9 Old 03-26-2014, 07:24 AM
Ariont
2009 WK
I just hard mine's rear end rebuilt to the tune of $2000 at the dealer. Thankfully it was 300 miles before my extended warranty expired. Had a really loud whine at the rear end under almost all driving conditions. They replaced the entire differential and associated parts. Mileage was 129,000.
Mine - 2009 Grand Cherokee Overland, 5.7 Hemi, QD II, K&N Air Filter, Headlight Beauty Covers, Cabin air Filter
Wife's - 2004 Grand Cherokee Special Edition, 4.0 L, 4x2
Proud Member of the Black WK Club - MEMBER #128
Ariont is offline
post #8 of 9 Old 03-26-2014, 08:20 AM
ISUzj
2005 WK
there.
This is exactly what is happening to me, but I had the dealer check pre-load and such and they said it all looked fine. Can I add more slip-additive to see if that quiets it at all?
Do we just have whiny rear ends?
They also said i needed a rear wheel hub... but that would be a constan whine not a intermittent, correct? I have the hubs and I am going to try replace them this week or next and report back
Can't wait to get started, but my wallet can......
~~~_______oooo_
~~ / ../...\...\_____\
~~[_---_____---_\-\\\\\\-\
~~~(o) )-o---(o) )-o---) )
94ZJ 5.2 Red; Rusty's 3" Coils,Skyjacker hydro's, Brush Guard, Custom Rear Bumper, Custom Roof Rack, KVG Quick Discos, 31-10.50-15's DAYTON TIMBERLINE A/T OBA 2 Gallon tank
Can't buy it? BUILD IT!! Do it cheap too cuz your in college
ISUzj is offline
post #9 of 9 Old 03-26-2014, 02:03 PM
road_tripper
mine rear end was howling like a banshee, had the bearings in the rear replaced.
reduced the noise by 90%. there is still a whine from the gears under load, only audible above 40, but gets louder under load and at higher speeds. driveline shop (whom I trust) said the gears 'looked' OK, and I believe them.
I'll probably fork out the $$$$ for a mopar ring and pinion and have them install it. If it lasts 100K miles, that's only a little over $1 for every 100 miles (or 50 cents a mile).
Otherwise, I can't hear the wife complain over the rear end whine
road_tripper is offline
Ticking noise from 5.7 Hemi cheef0216 WK Grand Cherokee & XK Commander Forum 22 09-02-2009 02:06 PM
Hemi ticking noise garsarno WK Grand Cherokee & XK Commander Forum 3 07-17-2007 04:58 PM
Strange New noise under 05 Hemi HurriJeff WK Grand Cherokee & XK Commander Forum 5 03-15-2007 07:04 PM
2006 V6 Grand Cherokee Laredo Rear Differential Noise strdotmatt ZJ Grand Cherokee Forum 5 07-25-2006 01:26 PM
