05 WK w/ P0430 Right Bank Cat code - JeepForum.com
post #1 of 9 Old 05-28-2009, 09:12 AM Thread Starter
Last Boyscout
1979 CJ7
My Boss has parked his 05 WK due to the quotes he got to fix a P0430 code. If I fix it cheap itíll be mine as a company car. My motivation is that my current company car is a 00 Chevy Astro w/ 249,xxx.
He has replaced the down stream O2 sensor on the Right Bank when he first got the code. No resolve. Took it to a dealer ship and was quoted $1,500 to replace from the manifold back. Then took it to a garage the company uses and was told the cat was bad. I took it to the guy who does my custom exhaust on my rigs. He took temp readings in front of and behind the cat. The reading was with in tolerances showing the cat was not over working. I ran Seafoam through the intake and gas tank. I didnít think it would completely resolve the issue, but I needed to check for exhaust leaks. None were visible.
There is no noticeable in performance at highway speeds a telltale sign of a bad cat. Could that be due to the fact there are 2 cats on a 4.7 WK?
But, on newer MPI vehicle is a temp check a reliable method to check a cat? Or, should I do a backpressure test at the up stream O2 sensor bung? When replacing O2 sensors should both the up and down steam be replaced at the same time if one fails?
My guy quoted me $200 (parts and labor) to replace the cat. But I donít want to just trough money at this problem.
STEP 1: BUILD IT!
STEP 2: BREAK IT!
STEP 3: REPEAT!!!!!
Last Boyscout is offline
post #2 of 9 Old 05-28-2009, 12:45 PM
merlinTec
merlinTec's Avatar
Hi
Have the TSB check first I know you have been to the dealership but I would go back again to recheck if you are unsure http://www.wkjeeps.com/tsb/tsb_wk_1803405.pdf
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #3 of 9 Old 05-28-2009, 02:51 PM Thread Starter
Last Boyscout
1979 CJ7
CORRECTION
It is a 06 WK.
I read the manufacture date of 11/05. It was sold and licensed as a 2006. Any chance there was a TSB for the same issue for a 06 WK.
STEP 1: BUILD IT!
STEP 2: BREAK IT!
STEP 3: REPEAT!!!!!
post #4 of 9 Old 05-28-2009, 03:56 PM
rocks00tj
2005 WK
i got the p0430 code 7 or 8 months ago. had tsb to reflash, still there. replaced both o2 sensors, light still on. quoted $1400 + to replace cars. no performance issues, just that *%$#@ light on. may take it to an exhaust shop because i suspect a slight exhaust leak at right manifold, or just have the one cat cut out and replaced.
rocks00tj is offline
post #5 of 9 Old 05-28-2009, 04:17 PM
robpp
exhaust leak. take it to the bank.
If under warranty, go back to the dealer, tell them to bring a Chrysler tech in. They'll do a smoke test and find your leak. most likely the ex manifold. even a pinhole throws that CEL.
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline
post #6 of 9 Old 06-01-2009, 09:11 AM Thread Starter
Last Boyscout
1979 CJ7
I couldnít find a TSB for a Cat issue on the 06.
Itís no longer under warranty. Iíll talk to my exhaust guy and see if he can ďsmoke testĒ for leaks. Any other ideas keep them coming.
STEP 1: BUILD IT!
STEP 2: BREAK IT!
STEP 3: REPEAT!!!!!
post #7 of 9 Old 06-01-2009, 02:39 PM
merlinTec
merlinTec's Avatar
Hi
No but there is a software update for the 06 and I always like things up to date latest is for TSB 18-014-09. get the smoke test done if no fault I see what else I can find.
post #8 of 9 Old 02-16-2013, 03:36 AM
silentknight
1967 CJ5
Bump for more never news/fixes?
i'm looking to buy a 05' GC Limited 4.7 WH(RHD export version of WK).check engine light is on so hooked up a generic scanner - its got the same trouble code.
wondering if its an easy fix or a deal breaker
thanks in advance
Sorry sonny,..that Jeeps gonna take a bit more than some buffing to fix!
build in progress -> 67' CJ5, stretched 110" WB, widened 5" /ISUZU C240/TF727/NP203/D300/D44HD & D60 from a 74' IHC 200/38.5 GROUND HAWGS/10X15 DIY BANDED STEELS
silentknight is offline
post #9 of 9 Old 08-30-2013, 07:08 PM
Amoros
2005 WK
Anyone want to revisit this topic? Got this code along with p0304. Cylinder 4 misfire.
Amoros is offline
Code P0430 - Help me please!!! cajuntec WK Grand Cherokee & XK Commander Forum 17 08-05-2015 09:45 PM
4.7HO P0171 will not go away (lean bank 1) - gas out exhaust Reiver ZJ Grand Cherokee Forum 18 05-18-2014 09:43 PM
code p0138 bank one sensor 2 leechris ZJ Grand Cherokee Forum 3 01-13-2010 11:08 PM
Labor cost of replacing Bank 1 Sensor 1 OS jeepingtom ZJ Grand Cherokee Forum 15 01-11-2010 02:06 PM
99 Jeep Grand Cherokee 4.7 P0432 Bank 2 Code JEEPCD ZJ Grand Cherokee Forum 5 02-12-2008 02:41 PM
