05 WK single speed x-fer case to two speed? - JeepForum.com
post #1 of 11 Old 02-09-2007, 01:14 PM Thread Starter
tednelson83
hi all, I just got me an 05 Jeep Grand Cherokee Lorado 4x4 yesterday and I noticed that that it didn't have a hi-lo sellector. turns out that I goofed and got the one with a single speed. got me thinking is it possible to convert it to a selectible one? if so can someone give me some ballpark figures on the conversion?
another question, how capible is this vehicle as is? is it worth it, or would it be best to turn it back in it to the dealer? I have that option untill 9pm on the 10th. I do plan on off roading in it, and I will deffinately want to run the 4x4 trails, that was the whole point of this purchase. (seems like someone may not have done enough research)
thanks guys!
tednelson83 is offline
post #2 of 11 Old 02-09-2007, 02:59 PM
JPCCDD
how difficult of a trail? i've taken mine to some pretty remote places but if you're planning on some hard core stuff, trade it back in and get a wrangler.
JPCCDD is offline
post #3 of 11 Old 02-09-2007, 03:05 PM Thread Starter
tednelson83
thats what i was affraid of, thanks.
post #4 of 11 Old 02-09-2007, 03:30 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
If you have the single speed, your transfercase is only 4hi and doesn't have the 4lo capability.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 11 Old 02-09-2007, 03:34 PM
nierace
nierace's Avatar
2003 WJ
You really want LO range if you're going to hit trails that are considered moderately challenging...
I would bring it back if you have that option...to convert it will run you up around 1k would be my guess on a WK at least.
It would be wiser to find one with it already IMO.
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #6 of 11 Old 02-09-2007, 05:09 PM
drewman141
Gas Guzzler
drewman141's Avatar
1994 ZJ
$1K would probably be if you got junk yard parts and did the swap yourself. Definately easier to trade it for a model that has the QT-II or QD-II.
[SIZE="1"]2008 WK Overland HEMI - Modern Blue Pearlcoat
Fully loaded with slush mats of course.
MUST GO! 1994 Limited ZJ 5.2L V8 - Light Driftwood Satin Glow
It's a 94 5.2L Limited - trxus 33's on 15x7 steelies, 4.56s w/ front OX and rear trutrac, NP242 swap, novak shift kit, Kevin's ultimate 4.5" lift + ACOS, ARB front bumper w/warn M8000, rear tomkin machine bumper w/ tire carrier, kevin's hardore railz, kevin's ultimate tc skid, kevin's trackbar conversion, rusty's gas skid, flexalite efan, Kolak's performance ignition and brake upgrades. ViAir OBA, custom storage/sub box and I'm sure there's a bunch of other things I'm missing. Everything is a little over 3 years old with less than 10K miles. Looking to get around $4k.
drewman141 is offline
post #7 of 11 Old 02-09-2007, 08:06 PM
jeepgaffer
2006 WK
Well, here's an idea on what some parts might cost...
NV245 Transfer Case
Transfer Case Switch
...I'm sure that there would be more parts involved, plus fluids, and obviously labor...not to mention some PCM/ECU reprograming! I wouldn't even attempt something like this unless I had alot of mechanical experience. I'd bet that you'd be looking closer to $2000. It may be cheaper to install it after the fact, all depends on what they'd charge you to upgrade/trade/return.
I wonder, would changing out the transfer case--if the dealer did it--affect the warranty? Would the new transfer case be covered under the original warranty?
Let us know what you end up doing!!!
jeepgaffer is offline
post #8 of 11 Old 02-18-2007, 06:25 AM Thread Starter
tednelson83
after a bit more digging around, i found the 245 x-fer case for between $400 and $450. say $50 shipped on the switch, $50-100 on the bezel provided i cant modify the one i have, and it looks like i can do it for under $600. that is provided the wiring is in place, and the ecm needs no programing.
Verdict:... Yup, doable, feasable, and reasonable. once thats done i look into the ELSD's and i will have the QD2 system in my factory QT1 3.7!
Sacramento Alumni. ASE A6, A8, and L1 Certified. CA Smog License.
1993 Jeep Grand Cherokee Limited 5.2 4x4, IRO 3.5" lift, Spidertrax adapters, 32" BFG M/T's on 17" cragar soft 8's, Flowmaster muffler.
1987 Pontiac Fiero GT 2.8
Liberalism stems from the notion that it's entirely possible to pick up a turd by the clean end.
post #9 of 11 Old 02-18-2007, 06:53 AM
JeepCollector
I think you forgot a few parts - module to control the 245 transfer case (and ELSD's if you get them), wiring to transfer case (and ELSD's), front and rear driveshafts, and transfer case adapter to transmission. There might be other things too. And you still have 3.07 gears in the axles.
Better to trade for what you want than to have a vehicle half converted and figure out it costs a lot more than you thought. Good luck if you decide to tackle it though!
JeepCollector is offline
post #10 of 11 Old 02-18-2007, 03:25 PM Thread Starter
tednelson83
are the axels different? i knew i was forgetting a bunch of electronic stuff, but what i really need is a factory shop manual, and part interchange manual. know where one can find these? this will help in researching a lot of my plans.
post #11 of 11 Old 02-18-2007, 08:27 PM
gornoman
2006 WK
Yes, the final drive ratios are different. QTII uses 3.57 gears.
'06 Grand Cherokee Laredo 4X4 (26E), Steel Blue Metallic. 3.7, QTII Trail Rated, Factory Skids, Tow Package, RRO Rock Rails, 245-65-17 Bridgestone REVOS
Ipod, CB, Leather Steering Wheel, Fog Lights. Black Bear Road Alumni, Elephant Hill Alumni.
Blue WK Club Member #15
My other passion -
gornoman is offline
Transmission Input Shaft Speed Sensor, Output Shaft Speed Sensor CaRJoE0220 WJ Grand Cherokee Forum 12 10-29-2014 06:47 PM
242 T-Case, What Speed Should I Be Going When I Shift to 4WD? CrazyIvan888 ZJ Grand Cherokee Forum 8 12-07-2009 11:33 AM
What is top speed of 4.7 wk kiesha WK Grand Cherokee & XK Commander Forum 11 06-10-2009 11:31 AM
ZJ 5 speed dodgetk81 ZJ Grand Cherokee Forum 0 12-24-2005 10:53 AM
93 318 5-speed?!?!?!? skier123 ZJ Grand Cherokee Forum 5 07-12-2005 02:55 PM
