'05 WK Radio Posessed - JeepForum.com
post #1 of 5 Old 03-06-2009, 10:27 PM Thread Starter
walki600
2005 WK
Hey all,
First post here.
I have an '05 Grand Cherokee Laredo with the standard (I think) REF radio. Anyways, about a week my radio started changing station at random times all by itself. I'll just be driving along, and the radio will switch by 2 tenths. IE from 103.5 to 103.3, or 99.5 to 99.7. Sometimes it changes back to the correct station, sometimes not, it's completely random as far as I can tell. Has anyone ever had this issues, I searched "Radio" back to April '08 and didn't come up with anything...
I know this seems like a minor problem, it really is extremely irritating though. I have had the truck for about 5 months, this is the first hiccup it has given me.
Any Ideas?
-Mike.
walki600 is offline
post #2 of 5 Old 03-09-2009, 07:45 PM Thread Starter
walki600
2005 WK
Really?! No one has had this issue before?
I feel so special.
walki600 is offline
post #3 of 5 Old 03-10-2009, 01:54 AM
DarrylFlynn
2006 WK
Originally Posted by walki600 View Post
Hey all,
First post here.
Any Ideas?
-Mike.
Hi,
are you sure that this is not just the RDS and automatic tuning feature doing its job.
Example. In the Uk i have one of my preset buttons on the radio tuned to BBC Radio 2. This station operates between frequency 88 to 91 FM.
At home, one of my preset buttons is tuned at 88.5 to receive this station as that is where the signal is strongest. If i then set off on a journey i notice that my preset station will alter gradually ie go from my set 88.5 to 88.7 or even further apart depending on where i am as the radio is doing its job and seeking out the strongest signal for my chosen station. By the time i come home it WILL have returned to 88.5.
In your original posting you did not state whether you were loosing signal strength and drifting onto an entirely different station as the frequency shifts ( Faulty ) or if it is behaving like mine
(Correctly)
Hope this helps Darryl
DarrylFlynn is offline
post #4 of 5 Old 03-10-2009, 10:24 AM
colinzj
2006 WK
Are you tuning with the dial or the preset keys?
If you're using the dial, it's possible (and fairly easy) to turn it just far enough that it changes but doesn't lock into the next click. Hit a bump, dial will move, radio will decide you wanted to change stations. Been there, done that.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #5 of 5 Old 01-07-2010, 01:12 AM
803scdantes
Hey all,
First post here.
Any Ideas?
-Mike.
I just started a separate thread about this when I ran across your post. I have a '06 Laredo and my radio does the same thing- only with the addition of the volume changing. It started out slowly- like once a month or so- and now it does it every day. The volume turns all the way down or all the way up- it's a nightmare. I can't stand to drive the thing because there's no radio. When I try to turn it up- it'll turn back down or vice versa. I replaced the factory radio twice to no avail. I was told-that part of the computer could have gone bad and to install an aftermarket radio because the car's computer doesn't control an aftermarket radio like it would the factory radio. Otherwise it'd be very expensive to fix the main computer. I'll let you know how this goes.
803scdantes is offline
first i'll start with my gas guage i posessed hoosierdaddy0 ZJ Grand Cherokee Forum 3 08-08-2008 05:10 AM
HELP!! Jeep's posessed irate808 ZJ Grand Cherokee Forum 4 02-27-2008 09:46 AM
Posessed Vents fcknmaw ZJ Grand Cherokee Forum 8 07-18-2006 01:38 AM
My cherokee is demon posessed Stravalata ZJ Grand Cherokee Forum 11 10-22-2005 01:44 PM
93 Gr. Cherokee V-8 Posessed bullsprig ZJ Grand Cherokee Forum 1 05-26-2005 01:10 PM
