'05 WK Laredo Liftgate Unlatches but Won't Open - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > '05 WK Laredo Liftgate Unlatches but Won't Open
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 02-23-2010, 12:07 PM   #1
carhink24
2005 WK
Recently began having problems with my 2005 Grand Cherokee liftgate. I can unlatch it, and it opens about 2 inches, but acts like it is jammed and won't open any further. Glass opens just fine, no problems. Any ideas what could be causing this, and how to fix it? Thanks!
carhink24 is offline   Reply With Quote Quick reply to this message
Unread 02-23-2010, 12:45 PM   #2
maxst2
2006 WK
Can you manually open it?
I'm going to bet that the lift motor is failing or has gone.
maxst2 is offline   Reply With Quote Quick reply to this message
Unread 02-23-2010, 12:50 PM   #3
carhink24
2005 WK
No, can't open manually. If I pull up on liftgate, it feels like it will break. Any ideas cost associated with replacing lift motor?
Unread 02-23-2010, 01:25 PM   #4
Texas WJ
Texas WJ's Avatar
2005 WK
Lift motor?
I'd check for interference along the top of the gate. Perhaps it's stuck on something. Has the door recently had any body damage?
265/70-17 BFGoodrich All-Terrain T/A KO, 2" lift, JK Wrangler Moab wheels, Spidertrax Spacers, Rola Roof Rack.
Texas WJ is offline   Reply With Quote Quick reply to this message
Unread 02-23-2010, 02:05 PM   #5
maxst2
2006 WK
lol frozen shut?
Unread 02-23-2010, 02:42 PM   #6
carhink24
2005 WK
I considered it being frozen shut since we've had heavy snow/ice in the past week. However on the day I tried it, temp was above 40 degrees. No body damage to vehicle that I'm aware of. I climbed up to see if anything was interfering with open motion. Don't see anything from outside, or inside. I'll try again after work and report back. Appreciate the help!
Unread 05-19-2010, 06:21 AM   #7
nillie10
2005 WK
I'm having exact problem, before it completely failed it would be hard to lift all the way open, you would hear a pop. Now it only lifts about 2 inches and feels as if it would break to lift all the way up. Did You ever find out how to fix this problem?
Thanks
nillie10 is offline   Reply With Quote Quick reply to this message
Unread 05-19-2010, 08:55 AM   #8
carhink24
2005 WK
Yes. It was my lift shocks - they had gotten fairly rusty and weren't allowing the liftgate to open. If you keep rocking it back and forth, it should lift all the way. You can either replace the lift shocks (about $15 each at Auto Zone) or you can use some WD-40 to keep it lubricated enough to open until you can replace the lift shocks. Hope that helps!
Unread 05-19-2010, 06:52 PM   #9
nillie10
2005 WK
Thanks!! It did help, I was already gonna use the wd 40 today but it was the rocking it that helped open it. I was scared to before, thought it would break. I sprayed it for now, guess I by the parts later...... Thanks again
liftgate
