05 WK Airbag light on? WTF? - JeepForum.com
post #1 of 21 Old 07-09-2009, 02:14 PM Thread Starter
TiestoJeep
2005 WK
Hey all -
Let me start off by saying I did a search and while stuff came up on Airbag light, nothing helped. The search on this forum is weird!
I have a 2005 WK, the other day my airbag light chimed on and has stayed on since. When I start the car it chimes, goes away, then comes back on and stays on. I think this has happened to me before and after taking it to the dealer they said I had something stuck under my seat and that was it, talk about feeling like a moron Nothing under seat now, can I go to like pep boys and have removed or do I have to go to the dealer? On a budget and I know the dealer will charge me 100+ just to turn it off.
Any help would be great! Thanks
TiestoJeep is offline
post #2 of 21 Old 07-09-2009, 09:15 PM
Jbripps
Same happened to me as well. Did you check way under the seat? You might be surprised what you can find under there. Look under both front seats. Mine was caused a few times, sometimes by the smallest items that barely touch the underside of the seat. Good luck. Otherwise, you might have another issue. Get it checked, b/c whenever that light is on, the airbag will not deploy from what I understand.
J
Jbripps is offline
post #3 of 21 Old 11-01-2010, 06:17 PM
gradeigh1
2005 WK
Any solution for those/ what the dealer charged? Its happening to mine now. Its really annoying. At first I thought it was rain related, something shorting out. Then it did it today and it hasn't rained recently. Really annoying. Light comes on about dings, stays on thirty seconds or so and goes out comes back on a any where from 15 seconds to 2 minutes later.
gradeigh1 is offline
post #4 of 21 Old 11-02-2010, 09:48 AM
acort
2005 WK
I think the dealer chargers like $68 or atleast that was my dealership said when I went and asked about it
2005 Grand Cherokee Laredo | 2" Rough Country Spacer Lift | Saguaro4x 5/8" Shackle Mounts | Interior LED Lights | Tow Package | Uniden 78XL | K&N CAI
1998 XJ Classic | Optima Battery
C4C Victim: 1996 Cherokee Country | Viper Security System | Alpine Head Unit
acort is offline
post #5 of 21 Old 11-04-2010, 06:02 PM
gradeigh1
2005 WK
So I took it to the dealer. They pulled the code, found it was coming from a module under the center console. They pulled my center console cleaned everything reseated all the contacts, flashed the computer and put it back together. So far so good. We'll see if that's a permanent solution. Only cost an hour of labor.
post #6 of 21 Old 11-05-2010, 03:23 PM
brentwoodkris
2005 WK
Is this the passenger airbag light or the one in the gauge panel? My passenger airbag light has recently been turning on and it's pretty irritating. I heard someone say that I needed to get the seat weight sensor recalibrated or something.
brentwoodkris is offline
post #7 of 21 Old 11-05-2010, 07:41 PM
gradeigh1
2005 WK
My situation was the red light in the instrument cluster.
post #8 of 21 Old 11-08-2010, 07:54 PM
gradeigh1
2005 WK
So it came on again today. I pulled the center console apart and found a connector that was half off practically. I also found the plastic trim has some plastic wall hanging down that isn't really necessary and is rubbing on the connecter. I taped the connector in and the light hasn't come on. I plan on getting the roto tool and cutting a section out of that. I'll take pics and post.
post #9 of 21 Old 11-08-2010, 09:25 PM
BAD68GTO
2006 WK
You can also zip tie connections, I do it on high vibration applications like race cars and anything flimsy :-) Run the zip tie between the wires on each connection pulling the connections together. Also use some dielectic grease if it would ever possibly get wet.
06 WK Limited, Hemi, QD II, 4" Superlift on 33"s, fully Armored with 4XGuard, M8000 on Cradle, Superchips
08 WK 4.7, QTII, OME HD, Full Armor, BURNED TO THE GROUND
2005 Viper, Vert, DLM SE #27/50, Paxton (w/intercooler) 946 RWHP
2000 Viper GTS, 10 LB Roe+GG heads/intake+Solid Roller, near 800 RWHP on pump gas+WM
1968 GTO 467 CID Fully Ported, Roller, 5-speed
2000 E350 Van with a ZILLION miles
2009 Votes thanks to ACORN
If a conservative is down-and-out, they think about how to better their situation.
A liberal wonders who is going to take care of them.
BAD68GTO is offline
post #10 of 21 Old 11-12-2012, 03:27 PM
jpm6621
My 2009 Jeep Grand Cherokee air bag light was coming on as well and staying on. I was told by a Non-Chrysler garage that it was something to do with the passenger seat belt safety retraction or something. Well that was a bunch of B.S. because all i did was got under the passenger seat and wiggled the wire connection and that solved my problem.
jpm6621 is offline
post #11 of 21 Old 11-12-2012, 04:53 PM
modette
2005 WK
I sold my airbags on the black market *shrug* Who needs them.
modette is offline
post #12 of 21 Old 11-14-2012, 01:06 PM
IndyBlueWK
2005 WK
my light comes on and off all the time.. Had the dealership reflash it twice now and the can't explain it..
IndyBlueWK is offline
post #13 of 21 Old 11-14-2012, 05:25 PM
LDB93
You have to reset the passenger airbag. Had the same problem on my 06 wk fixed it after
LDB93 is offline
post #14 of 21 Old 12-29-2012, 02:33 PM
asas
2005 WK
Where is the exact location of the airbag module on 2005 wk 5.7L ? I need to take it off for resetting . Thanks
asas is offline
post #15 of 21 Old 01-07-2013, 05:12 PM
skrach77
2005 WK
Bump
Mine has starte coming on while accelerating. Then goes back off about 15-30 secs later. Only thing I've done lately is change profiles with my Flashpaq from Econ to 87 perform. I don't think it's that, but just to eliminate the possibility I'm gonna change it back to Econ when I get home.
Without fail- I accelerate from a stop or low speed, and ding! Annoying little light isn't it!
skrach77 is offline
airbag light 95ZJ ZJ Grand Cherokee Forum 1 02-22-2008 10:16 PM
Airbag Light 06limited4.7 WK Grand Cherokee & XK Commander Forum 0 02-18-2008 07:30 AM
airbag light sandman ZJ Grand Cherokee Forum 3 12-09-2007 05:46 PM
Airbag Light nskeates ZJ Grand Cherokee Forum 5 05-30-2007 05:56 AM
Airbag light.. How bad? slick2570 ZJ Grand Cherokee Forum 1 07-10-2006 02:18 AM
