05 occasional hard starting - JeepForum.com
post #1 of 4 Old 12-24-2015, 03:43 PM Thread Starter
LA2
my 05 WK recently became hard to start occasionally. new battery and diagnostics show no problem. it will start fine for days then wont. cranks and acts like a fuel problem. after 3-4 tries it starts. changed the fuel relay with no difference. once started it runs perfectly. of course when in the shop it starts fine. I am new to the form but desperate to find a solution. I will check back but if you know of this problem please email me lad@ladart.com
LA2 is offline
post #2 of 4 Old 12-25-2015, 06:59 AM
RCS1300
2005 WK
Connect an oscilloscope to the crank and cam sensors and check to make sure that they are operating correctly. Also, connect a fuel pressure gauge to the fuel rail and see if the fuel pressure is within specification.
RCS1300 is offline
post #3 of 4 Old 12-25-2015, 08:50 AM Thread Starter
LA2
I know the fuel pressure was checked but thanks for the tip on the crank and cam sensors - will try that
LA2 is offline
post #4 of 4 Old 12-25-2015, 07:44 PM
92JEEPWRANGLERY
Sounds exactly like the symptoms on our 05 5.7. I put a fuel pump in it and all is well!
92JEEPWRANGLERY is offline
