05 Jeep GC limited ABS Light Problem - JeepForum.com
post #1 of 9 Old 07-24-2009, 08:39 PM Thread Starter
sammy29926
Hi everybody,
My wife has a 05 Jeep GC limited with 4.7 with 55.000 miles. Couple of months ago everytime it rained ABS light came on but after a while it turned itself off. Now Abs light is and On VIC screen it says service ABS system. I am about to buy a Code reader but before I do that i decided to post here any see if anybody has gone through this.
Thank you for your helpand your time.
Sammy
sammy29926 is offline
post #2 of 9 Old 07-25-2009, 12:48 AM
jerrym_7758
check the abs fuse under hood and check electrical conection behind tires
2005 LJ Unlimited, 4.0 I6, Dana 30/44,
3" Suspension Lift, 1.25 BL, Discos, 35" MTR, Flowmaster
Exhaust, Power Door Locks With AutoPage Remote Start, XRC8 Winch,
Custom Bumpers, Front And Rear Tube Fenders, Alpine CDE-123 Head Unit,
13W1V2 JL Audio Subwoofer, A1400 JL Audio Amp
jerrym_7758 is offline
post #3 of 9 Old 07-25-2009, 01:55 PM Thread Starter
sammy29926
Thank you..
Sammy
post #4 of 9 Old 09-24-2009, 07:26 PM Thread Starter
sammy29926
hi Everybody,
I bought a Actron CP 9449 ABS Brake Scan Tool on ebay For $60 shipped and just checked my wifes Jeep's ABS codes. This is a nice tool to have / invest because dealership wanted $90 just to look up/read the codes. This thing can read ABS codes and OBD diognostic codes. Following is the list of codes showed up and I really would appreciate your help.
Code 1 : U0100 Lost Communication With ECM/ PCM
Code 2 : C1044 Right Rear Tone Wheel Performance
Code 3 : C1035 Right Rear Wheel Speed Comparative Performance
Code 4 : C1049 Right Rear Wheel Pressure Phase Monitoring
Code 5 : C1032 Right Rear Wheel Speed Sensor Signal Erratic Performance
So What I am thinking is Jeeps Right Rear Wheel ABS sensor is bad and causing all these codes.
Thank you For your help
Sammy
post #5 of 9 Old 09-25-2009, 12:40 AM
merlinTec
merlinTec's Avatar
Hi
Code 2, 3 and 5 yes possible sensor fault or you have something wrong relating to the tone wheel (half shaft bearing/ seal). Did you clear them and see what came back?
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #6 of 9 Old 09-26-2009, 02:54 AM Thread Starter
sammy29926
I have not cleared them yet... where is the tone wheel ( Hlaf shaft ) i slocated at..?
I am planing to take the wheel off of the jeep and do a visual inspection..
Sammy
post #7 of 9 Old 09-26-2009, 08:53 AM
merlinTec
merlinTec's Avatar
Hi
Will need to pull the rotor off, Is there any sounds of a leek on the axle on that side?
post #8 of 9 Old 09-27-2009, 12:47 AM Thread Starter
sammy29926
Hi Merlintec,
First thank you for your contibituion to this forum and definetly thank you for your help to me.
I will be looking at ti on monday or tuesday and will take some pictures and post them here..
Thank yo u
Sammy
post #9 of 9 Old 06-24-2010, 08:55 PM Thread Starter
sammy29926
hi everybody,
These codes are back.. Her car did not have any ABS codes thrown for a while and ABS ligth came on 2 days ago. I am in a process of doing front struts. rear shocks and brakes.. i will check the rear wheel tone asap..
hope to hear any advice from yuo guys.
Sammy
01 Jeep GC Limited WJ Starting Problem DJHile WJ Grand Cherokee Forum 15 12-14-2013 09:14 PM
Engine light on-2001 Jeep GC Limited 4.7L Jayzee ZJ Grand Cherokee Forum 1 09-07-2007 03:05 PM
01 Jeep GC Limited - New User with Problem hockeysc23 ZJ Grand Cherokee Forum 3 03-28-2007 06:06 PM
99 Limited: Check engine light on + shifting problem jaharris ZJ Grand Cherokee Forum 2 12-18-2005 10:09 AM
96 GC Limited light problem cudajon ZJ Grand Cherokee Forum 0 11-01-2001 08:50 AM
