05 Grand cherokee Clunk/Pop from front left - JeepForum.com
post #1 of 7 Old 06-24-2013, 05:48 PM Thread Starter
subliminal
1997 XJ Cherokee
I just got a used 05 grand cherokee, when I bought it I found a couple issues that the dealer agreed to fix if I bought it. One of the issues I found was that the jeep pulled to the right and the steering wheel was off center. It also occasionally has a pop or clunk sound coming from the front left during spirited acceleration from a stop. It doesn't always make the pop sound but it does every so often. My question is does this sound like a balljoint issue? Anyway I can verify if it's balljoints or tie rods or anything? I would just like to verify myself before I take it in and have them possibly try to do a quick fix on it so they don't have to replace ball joints orbwhatever else it may be
1997 Jeep Cherokee 4.0 Automatic NP231
subliminal is offline
post #2 of 7 Old 06-24-2013, 10:06 PM Thread Starter
subliminal
1997 XJ Cherokee
Bump
post #3 of 7 Old 06-25-2013, 07:23 PM
viperman96
2005 WK
Sounds like a tie rod end or ball joint to me. They should be able to put it up on the lift and find the problem.
2005 WK Limited Hemi-Rough Country 2" BB,Spidertrax 1.5" spacers,Moabs w/ BFG Mud terrains 255/75/17,Mopar cai,Diablosport Predator tune,Taylor shortie wires,Monroe LL shocks,Monroe Reflex struts,Flowmaster Super 44 muffler w/ rolled tip(no res.)
viperman96 is offline
post #4 of 7 Old 06-26-2013, 07:38 AM
Jeepforthewin
2010 JK Wrangler
There are alot of threads on here about the front end pop and alot of different reasons why people get the pop/clunk. Could be anything like a bad CV shaft to bad bushings or a tie rod to a ball joint like Viperman said. Let us know what you find out!
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #5 of 7 Old 06-26-2013, 03:46 PM
oducks12
2005 WK
http://www.jeepforum.com/forum/f67/t...d-pop-1421373/
Worth taking a look at
2005 WK Laredo - SOLD
2015 WK2 Limited
oducks12 is offline
post #6 of 7 Old 06-26-2013, 06:05 PM
dmsfun
2006 WK
Sway bar end links need replacing. You cannot inspect them without removing them from the vehicle, and the mounting holes get gouged out, causing the clunk. My originals went bad in 35k. I would also replace the sway bar mount brackets and rubber bushings, and get the newer 06 and up brackets and bushings with the groove in the center.
2006 Overland QDII 5.7 BT catch can, Diablosport Intune, CMR tune by Hemifever tuning, Modern Muscle ported 85mm TB, Apexi super voltage regulator, SRT8 front and rear sway bars, Koni FSD shocks/struts, Cooper discoverer AT3's, Amsoil fluids.
dmsfun is offline
post #7 of 7 Old 06-27-2013, 05:58 PM
tom19511
2014 WK
You gotta wonder if dealers check out their cars before they sell them. I see a lot of posts on here that state the dealer will fix this or that problem if you buy it..Buyer beware.. Have a mechanic go with you, before you buy a used car... Buy from a dealer with a good reputation..
Tom
tom19511 is offline
