05 Grand cherokee Air box question - JeepForum.com
post #1 of 4 Old 07-26-2012, 09:38 AM Thread Starter
mmarine58
I have an 05 grand Cherokee, love the truck. Today i was looking at the air box and i came across a thin hose that is connected to the side of the box, I opened it and there was oil in it. I'm wondering if this is normal or something is up? Much help would be appreciated!
mmarine58 is offline
post #2 of 4 Old 07-26-2012, 09:41 AM
JRLT
2010 WK
Think that's the hose you would install a catch can to.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #3 of 4 Old 07-26-2012, 09:47 AM Thread Starter
mmarine58
but is it normal to have oil in it?
post #4 of 4 Old 07-26-2012, 03:38 PM
Walt
2008 WK
I believe that it is the makeup air line to the crankcase (replaces air sucked out by PCV valve). On my '08 5.7L HEMI, it goes from the air box to the side of the oil fill tube. No, it should NOT have any oil in it.
This is likely an indication that your PCV valve is not functioning correctly, i.e., not pulling a vacuum in the crankcase. If you have not changed the PCV valve within the last 60K miles, it's probably time. On the HEMI, pull the valve (1/4 turn counter-clockwise and lift out) to verify it is internally clean and that the valve assembly "rattles" when shaken. After a while, the internal spring probably relaxes and the valve doesn't function correctly. The other engines tend to have them on the driver's side rear and just pull out.
I try to inspect mine every other oil change or when I empty the oil catch can.
They are $25-$30 for the HEMI (and much cheaper for the other engines), depending on where you buy. Should be a 15-min. fix.
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
1995 grand cherokee limited question,another question turnerboy1 ZJ Grand Cherokee Forum 9 03-16-2012 04:15 PM
pcm/ecm question for 96 grand cherokee hartnagle ZJ Grand Cherokee Forum 8 10-04-2011 07:53 PM
Newbiee Question?? - grand cherokee thumping question geoff6194 ZJ Grand Cherokee Forum 2 03-23-2011 01:59 PM
96 grand Cherokee question taly6 ZJ Grand Cherokee Forum 8 01-20-2011 01:17 PM
Question About '01 Grand Cherokee saltybeef ZJ Grand Cherokee Forum 4 04-02-2007 07:45 PM
