05' GC Sunroof Stuck ALL THE WAY Open - Please Help! - JeepForum.com
post #1 of 6 Old 02-01-2012, 08:46 PM Thread Starter
KLHBrown
2005 WK
I know there are other threads on here about sunroof issues, however, mine's a bit different. I've heard to pull the fuse while the roof is in motion and I've heard the "put it in the vent position" to reset trick, but my problem is that my sunroof will not move at all, therefore I can't make it move to pull the fuse or put it into the vent position. It is stuck completely open. There is nothing in the tracks. The buttons light up but don't function, except for when I push the open button I hear a click or noise which indicates power is still going to it.
This just happened out of the blue today. It worked fine this morning and then just died mid-afternoon.
I am the second owner of my Jeep and found out that the sunroof is a Webasto Hollandia 735 inbuilt- factory installed. Since it came this way off the assembly line, I'm guessing all Jeeps have Webastos, but I'm honestly not sure?
Here's an image of the control panel . . .
This image does not match the image of the control panel my owners manual shows.
A couple of months ago I noticed my buttons were acting goofy. The open button would still open it, but the close button would not work and neither would the slide forward/vent button. To close it I had to hit the position 1 button for some reason. Now I've heard that these things can have programming issues, so I tried to reset it by disconnecting the battery - didn't work. I also checked the fuses, which were fine.
I took it to AutoZone - they had no clue. I took it to the local Jeep dealership for a free opinion - they wouldn't give me one even though they have before. Poopy.
So, I don't know what's wrong. I don't know if I need to reset the thing or what. All I know is that I can't afford to take it in, so I'm hoping to find a solution here. Honestly, I don't care if it doesn't work anymore. I just want to get it closed because it's supposed to rain all week and I don't have a garage. It's pretty heartbreaking to see it sitting in the driveway with a dirty brown tarp over it.
Thanks in advance.
KLHBrown is offline
post #2 of 6 Old 02-02-2012, 03:26 AM
w1pf
Who, me?
w1pf's Avatar
2007 WK
I don't think it came from the factory with that setup, but I don't know 05s that well. The parts catalog does not show a switch like that.
2014 WK2 Overland 5.9L
2007 WK Limited 5.7L
And some past Durangos
Red WK #19, Hemi #68.. I think..
Durango Owners Club DOTY 2011
"Must have been that yesterday was the day that I was born"
w1pf is offline
post #3 of 6 Old 02-02-2012, 06:32 AM
eprovenzano
2005 WK
I have an 05 and the switich on mine is different than yours. Look in the owners manual, as there has to be a way to close the sunroof manually.
2012 Grand Cherokee Limited Wk2 (Momma's)
2005 Grand Cherokee Limited, WK, 4.7 V8 currently rolling on Cooper Discovery 265 70 17's, with 1.25" spacers.,installed an OME HD lift sourced through Kolak.
1996 XJ 6 inch lift on 33's (Son's)
eprovenzano is offline
post #4 of 6 Old 02-02-2012, 07:33 AM
w1pf
Who, me?
w1pf's Avatar
2007 WK
What makes you think it was factory installed?
The more I nose around, the less I believe it. This is an aftermarket sunroof.
w1pf is offline
post #5 of 6 Old 02-02-2012, 08:33 AM
yzjwk
2005 WK
This is an aftermarket sunroof http://webastoshowroom.com/.
Should be easy to pop off the cover and jumper the switch to make it close .
Check on the website for owners or install manual .Good luck .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #6 of 6 Old 02-02-2012, 11:32 AM Thread Starter
KLHBrown
2005 WK
Thank y'all for the quick replies!!!
I thought it was factory installed because I found a Webasto flyer stating it was a factory option when you ordered one from a dealer back in 05'. With a bit more thought, my Jeep has some hail damage on the roof from the previous owner. Now I'm thinking they might have replaced the original sunroof after hail bashed it out, as my hood has been replaced as well.
Good news . . . PROBLEM SOLVED!
Yesterday I disconnected the battery for about 20 minutes and it didn't fix anything. Out of frustration this morning I disconnected the battery again and left it that way for well over an hour. Hooked it back up and VOILA! Sunroof closed! Thank God! It's starting to rain as we speak!
KLHBrown is offline
2005 , cherokee , moonroof , stuck , sunroof
ZJ Sunroof Stuck Open Orvis97 ZJ Grand Cherokee Forum 11 02-20-2015 04:20 PM
Zj Sunroof Wont Open rednecktrucker ZJ Grand Cherokee Forum 10 04-02-2013 05:12 AM
02 WJ Sunroof won't open jnajacob ZJ Grand Cherokee Forum 1 06-29-2009 12:40 AM
WJ sunroof - will not open - off track VinoTJ ZJ Grand Cherokee Forum 4 01-02-2008 06:50 PM
1999 WJ Sunroof Stuck Open Help avwood ZJ Grand Cherokee Forum 1 04-30-2005 05:44 PM
