05 fog light help - JeepForum.com
post #1 of 4 Old 09-25-2017, 08:33 AM Thread Starter
foley_41
2005 WK
05 fog light help
I've got a 2005 grand Cherokee that did not come with factory installed fog lights. I purchased OEM replacement fog lights, & I've purchased a the OEM turn signal stalk(with fog light switch), put in a relay in fuse box under the hood & still not working.
what am I missing?
Also, is there a fuse under the dash that needs to be installed?
Thanks
foley_41 is offline
post #2 of 4 Old 09-25-2017, 09:25 AM
BeetleCamry
2007 WK
Not sure about the fuse under dash. I believe if relay and stalk are installed you just need the dealer to reprogram your car to recognize them. This also enables the cluster indicator light to illuminate as well.
2007 Grand Cherokee Rocky Mountain / 2wd / Red Rock Crystal
BeetleCamry is offline
post #3 of 4 Old 09-25-2017, 09:33 AM
Nejeep
Dealer or someone with a programmer is required to enable the fog lights to work like a factory setup.
Here is a link to another DIY fog light setup that does not use the stalk switch or require programming. Presumably it will work with your 05 WK.
http://www.jeepforum.com/forum/f67/2...ights-3773825/
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #4 of 4 Old 09-25-2017, 03:13 PM Thread Starter
foley_41
2005 WK
thanks for the info everyone. I will try to contact my local dealer to see what I can do. thanks again.
foley_41 is offline
