'05 ESP Woes - JeepForum.com
post #1 of 23 Old 01-08-2014, 07:42 PM Thread Starter
RedWagon1006
2005 WK
'05 ESP Woes
Alright, I want to disable the ESP to see how much It may be hindering my WK. I read that you hold the traction control button for five seconds and some such nonsense, but all I get is a traction control disabled message and a sore finger. Any ideas?
'05 Grand Cherokee Limited packing a 287. K&N FIPK II | Fastman 68.5mm throttle body | Borla ProXS muffler
About 260 horsepower, 320 ft. lbs. of torque. She's no race car, but tons 'o fun nonetheless.
RedWagon1006 is offline
post #2 of 23 Old 01-08-2014, 07:48 PM
ttusqrl
2005 WK
This approach doesn't work with the 05 -- you can only "half way" disable it on our models.
2005 WK 5.7 ORT | Mod SL (OME struts & 990s) | JBA UCAs & Discos | Saguaro Front Bumper | Warn Zeon 10s | 285/70/17 BFG TA KO | AIRAID CAI | Gibson 3" Exhaust | DiabloSport Intune | JL Stealthbox
ttusqrl is offline
post #3 of 23 Old 01-08-2014, 08:04 PM Thread Starter
RedWagon1006
2005 WK
Well, nards. And how is that done? Just took a couple of passes with just pressing the TC button, and it went from bogging badly to barking the tires until the AWD kicks in.
post #4 of 23 Old 01-08-2014, 08:04 PM
tjkj2002
2002 KJ Liberty
You gotta pull the ABS fuse,then you loose ESP and ABS.Only way to do it and if you get in a accident and they dig into your vehicle and find it's been disabled your out of luck for any insurance coverage and maybe sued by your insurance company for fraud since your getting a ABS/ESP discount.
tjkj2002 is offline
post #5 of 23 Old 01-08-2014, 08:06 PM Thread Starter
RedWagon1006
2005 WK
Ah, okay. Yeah, I think I'll avoid that. I like my ABS.
post #6 of 23 Old 01-08-2014, 08:07 PM
muddyjgc
2005 WK
Actually ESP was not standard on '05 models. So if you can't turn it off then most likely you don't have it. I think it became standard in 06. A build sheet will tell you if you have it or not.
muddyjgc is offline
post #7 of 23 Old 01-08-2014, 08:20 PM Thread Starter
RedWagon1006
2005 WK
Ah, okay. That actually makes a good bit of sense.
post #8 of 23 Old 01-08-2014, 08:24 PM
muddyjgc
2005 WK
Also I would not pull the ABS fuse because you would loose the traction control. The Jeep uses the ABS to modulate the brakes to transfer the power the the wheels with traction.
muddyjgc is offline
post #9 of 23 Old 01-08-2014, 09:25 PM
94jeepman
2005 WK
I have esp on my 05 and it says esp disabled but it hits the brakes to try and straighten it out. But I do think k you can shut it off or else I'm just imagining things
94jeepman is offline
post #10 of 23 Old 01-08-2014, 09:26 PM
tjkj2002
2002 KJ Liberty
All WK's have ESP,traction control,ABS,and that brake lock junk(SRT's excluded).
tjkj2002 is offline
post #11 of 23 Old 01-08-2014, 09:46 PM
muddyjgc
2005 WK
No, all WK's DO NOT have ESP. All 06's and up DO HAVE Traction control and ESP. All 05's have traction control, but ESP was optional that year. So if you can only turn off Traction Control that means you don't have ESP. My WK only has Traction Control and I have the build sheet to confirm it. My owners manual also states that Traction Control as standard and ESP as optional. Go to this link.... http://www.wkjeeps.com/wk_whats_new.htm and scroll down to 2006. You will see that it states " Electronic Stability Program with Electronic Roll Mitigation and Brake Assist standard on all models". So those were not standard in 05.
muddyjgc is offline
post #12 of 23 Old 01-08-2014, 10:10 PM
ttusqrl
2005 WK
I have ESP on my WK, but I still can't turn it off. What's that say?
ttusqrl is offline
post #13 of 23 Old 01-08-2014, 10:24 PM
muddyjgc
2005 WK
I would ask you how you know you have ESP then. Is ESP specifically listed on your build sheet? Or how are you attepting to turn it off?
muddyjgc is offline
post #14 of 23 Old 01-08-2014, 10:51 PM
ttusqrl
2005 WK
Yes, it is on my build sheet when I looked up my VIN. Holding down the traction control button does not turn it off though.
ttusqrl is offline
post #15 of 23 Old 01-08-2014, 10:59 PM
jjt250
2007 WK
You can not turn it fully off on 05's, only partially by pressing the button once.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
