05 3.7 wont start buzzing sound coming from fuse box - JeepForum.com
post #1 of 6 Old 05-21-2012, 06:57 AM Thread Starter
ramthis426
2005 WK
My jeep won't start this morning .I don't know what could be wrong when I try and turn the key I don't hear anything no fuel pump started just a buzzing sound coming from the fuse box plz help
ramthis426 is offline
post #2 of 6 Old 05-21-2012, 07:30 AM
vwgtipowr
Could be a neear dead battery?
Do you have a volt meter to test it?
You could try jumping it. Does it click at all when you try to stat it?
Maybe the starter relay is what is buzzing?
vwgtipowr is offline
post #3 of 6 Old 05-21-2012, 08:47 AM Thread Starter
ramthis426
2005 WK
the battery was low im charging it now i hope thats the problem. it started last night fine and i drove it then put it in park for the night with no luck
post #4 of 6 Old 05-21-2012, 09:11 AM
vwgtipowr
I would use the meter to test if there is any drain on the batter when it is parked and off.
have you installed an aftermarket radio or anything like that recently?
Could also just be time for a new battery.
Probably worth testing alternator too just in case it is not putting out a charge.
post #5 of 6 Old 05-21-2012, 09:33 AM Thread Starter
ramthis426
2005 WK
no i have nothing after market other then lift and max energy
starter is less then a year old im hopping it just the battery
post #6 of 6 Old 05-22-2012, 03:30 PM
JKM
2005 WK
although starter is new, the terminal on the solenoid may have corrosion on it where the terminal crimps the wire. A few people here have had similar issues. I described in a thread over a year ago how to address this problem.
If you battery is the original then first thing I would do is replace that
JKM is offline
98 grand 5.9 wont start. keeps blowing fuse 98SilverBullet ZJ Grand Cherokee Forum 23 03-22-2012 08:17 PM
Buzzing Sound From By My Glove Box steveridesli ZJ Grand Cherokee Forum 20 02-19-2010 01:08 PM
Buzzing sound !! WJ sontog ZJ Grand Cherokee Forum 5 07-17-2009 11:10 AM
Jeep wont start something to do with asd fuse i think jappa1 ZJ Grand Cherokee Forum 4 05-02-2009 07:21 AM
2005 WK - "buzzing" coming from rear after initial start --chris-- WK Grand Cherokee & XK Commander Forum 10 03-26-2009 11:38 PM
