05-08 Grand Cherokee WK Service Manual - Page 6 - JeepForum.com
 2Likes
post #76 of 119 Old 01-21-2014, 07:51 PM
Blown7
Originally Posted by yzjwk View Post
part and owners manuals for various years can be downloaded here
http://wkjeeps.com/wk_brochures.htm
Thanks Got it!
I'm gonna try running the basic Laredo P/N to defeat ESP and totally eliminate it.
The Dunning–Kruger effect is a cognitive bias in which unskilled people make poor decisions and reach erroneous conclusions, but their incompetence denies them the meta-cognitive ability to realize their mistakes.
Blown7 is offline
post #77 of 119 Old 01-21-2014, 07:56 PM
ttusqrl
2005 WK
Wouldn't this eliminate ABS as well? I know I can disable my ESP/Traction Control with my intune, but this will also disable ABS.
2005 WK 5.7 ORT | Mod SL (OME struts & 990s) | JBA UCAs & Discos | Saguaro Front Bumper | Warn Zeon 10s | 285/70/17 BFG TA KO | AIRAID CAI | Gibson 3" Exhaust | DiabloSport Intune | JL Stealthbox
ttusqrl is offline
post #78 of 119 Old 01-21-2014, 08:01 PM
Blown7
Nope the standard P/N had ABS but not ESP.
Blown7 is offline
post #79 of 119 Old 01-22-2014, 01:40 PM
yzjwk
2005 WK
Yes , but isn't it actually "traction control " that you want to disable , not ESP ? In which case i believe traction control is standard on all WK's . ESP is an option though.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #80 of 119 Old 01-22-2014, 03:52 PM
Blown7
No traction control is good for the application I'm reworking. Eliminating ESP has multitudes of benefits, namely disabling throttle control.
Blown7 is offline
post #81 of 119 Old 01-22-2014, 07:16 PM
yzjwk
2005 WK
i'm not sure what your doing , but as per the fsm , it seems the traction control that controls the ETC not the ESP system.
ALL-SPEED TRACTION CONTROL
Traction control systems sense impending wheel spin based on a model of the rate of change of wheel speed under
normal traction conditions. The All-Speed Traction Control uses signals from the same wheel speed sensors as ABS
to determine when to apply the brakes to one or more wheels and when to reduce engine torque output using the
electronic throttle control (ETC) to prevent wheel slip during acceleration
. Throttle control makes the vehicle less
reliant on brake application alone to maintain traction, increasing the operating speed range and more closely modulates
speed, resulting in smoother operation. With All-Speed Traction Control reducing engine torque as well as
applying the brakes, it is possible to achieve almost seamless torque application at the wheels.
If the wheel slip is severe enough to require throttle intervention, All-Speed Traction Control will reduce engine
torque and sometimes upshift the transmission to avoid the condition. In milliseconds, All-Speed Traction Control
interrogates the engine control system to determine the current torque output, determines how much the torque
output the current conditions will allow, and signals this requirement to the engine control system, which reduces the
torque by partially closing the throttle. With execution of the torque reduction, the brake system reduces brake pressure
to make the transition smooth, while maintaining forward progress. By reducing engine power, braking effectiveness
is maintained and the system can operate throughout the normal vehicle speed range. That is why the
system is identified as providing “all-speed” traction control.
With AWD, where front-wheel slip can occur, the degree of throttle intervention is relatively less than with rear-wheel
drive. The difference in speed capability and the degree of throttle intervention between rear-wheel drive and allwheel
drive is due to the fact that non-driven front wheels on a rear-wheel drive vehicle give the system an accurate
vehicle speed reference on which to base responses. With AWD, the possibility that the front wheels may also be
slipping makes appropriate corrective action more difficult to determine, thus limiting the effective speed range. Offsetting
this is the fact that loss of traction is less likely with AWD because torque is transmitted through all four
wheels to begin with. In actual driving situations on snow or ice, the rear-wheel drive and AWD systems respond in
essentially the same way up to the 45 mph (72 km/h) limit of the AWD system.
When severe wheel slippage is detected (as on snow-covered roads), the Winter Mode feature of All-Speed Traction
Control causes the transmission to up-shift to higher gears at lower speeds than normal. Once a slippery launch
condition is detected, the transmission will remain in Winter Mode for a minimum of three minutes. After that, if the
road is providing normal traction, the system returns to providing normal up-shifts.
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
post #82 of 119 Old 04-29-2014, 12:33 AM
XJtoWJ
any chance you can repost this? says no longer avail
XJtoWJ is offline
post #83 of 119 Old 04-30-2014, 10:03 AM
dsjr2006
2006 WK
Service Manual:
https://mega.co.nz/#!I0QhEaRK
Key: pURk1x6J0jWzmHzv7lVTGS87FhWgg3DaCdoUp84qF-Q
Parts Manual: https://mega.co.nz/#!YwIhFIiB
Key: GlMztUIRghbyvICZKDs5EfapOHSB3GqZ_-yO4phfBtg
1Lonestar likes this.
'06 Limited Hemi QDII - Icon Coilovers - OME Lift w/Bilsteins - 32" 265/65R18 Goodyear Duratracs on JK Sahara 18s - Smittybilt XRC10 Comp X20 Winch
05-08 WK Service Manual PDF:
dsjr2006 is offline
post #84 of 119 Old 04-30-2014, 07:04 PM
MDchanic
Thanks! Great to have.
- Eric
MDchanic is offline
post #85 of 119 Old 04-30-2014, 08:05 PM
XJtoWJ
d/l now. thanks
XJtoWJ is offline
post #86 of 119 Old 05-01-2014, 12:04 PM
grywlfbg
Thank you!
Chris
Current: 2007 WK CRD Limited
Past: 2005 KJ CRD Limited, 2000 TJ
grywlfbg is offline
post #87 of 119 Old 05-18-2014, 02:32 PM
Knightdulac
Thank you
Originally Posted by dsjr2006 View Post
Service Manual:
Thank you
Heaps
Knightdulac is offline
post #88 of 119 Old 08-02-2014, 04:52 PM
ZWilson07
2008 WK
Is this still working for anyone?
Says I need the key code to get it.
Needing service manual and such for my 08.
2008 WK Overland 5.7 Hemi 4x4 QD2
Everything I need, plus a lot more I don't.
Black WK Club Member #154 || Hemi Club Member #89
ZWilson07 is offline
post #89 of 119 Old 08-02-2014, 11:22 PM
DeChache
2003 WJ
Just enter the key he put beneath the link and it will let you download it.
His 2003 Limited 4.7 QD 151 K
Hers 2008 Laredo 3.7 QT1 131 K
DeChache is offline
post #90 of 119 Old 08-02-2014, 11:43 PM
willis08
2008 XK Commander
Hey, I'm new to the forums and just recently bought my 08' XK that's powered with the Hemi. I'm looking for an exhaust that will open it up a little. Not screaming line 1 chambers, but a low bellow with deep tone on acceleration. Any suggestions??
willis08 is offline
05 Grand Cherokee Service Engine Message Elmar66 ZJ Grand Cherokee Forum 5 01-21-2012 06:50 AM
98 jeep grand cherokee 5.9 service manual venom204 ZJ Grand Cherokee Forum 10 09-10-2011 07:06 PM
04 Grand Cherokee Perform Service tazcu812 ZJ Grand Cherokee Forum 4 05-18-2008 04:18 PM
service help grand cherokee 01 jeepmum ZJ Grand Cherokee Forum 4 06-28-2007 06:16 AM
