0321Nick's Build Thread - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 0321Nick's Build Thread
Unread 11-16-2013, 11:02 AM   #91
0321Nick
2006 WK
Got a cheap paper towel holder from Walmart to relocate them off of my bunker cords. Now to deal with the duct tape and first-aid kit.
KHAKI CLUB #65
2006 WK 4.7L V8 - Modified OME HD with Bilstein 5125s (28" length); JBA UCA; JKS Rear Discos; K&N CAI; PowerStop Discs; HyperTech; TOYO Open Country AT IIs 285/70/17; + some other goodies
0321Nick is offline   Reply With Quote Quick reply to this message
Unread 11-18-2013, 02:53 PM   #92
0321Nick
2006 WK
Trunk LEDs.
Step 1-17 complete.
KHAKI CLUB #65
Unread 11-18-2013, 05:21 PM   #93
0321Nick
2006 WK
Step 18-57: Well I got the lights out to the car and they suddenly would not light up anymore. So that was frustrating. I decided rather than suffer through the agony of soldering three sections together again (probably why they failed) - I would just cut one length and run it across the entire Tim piece. This option limited my weak-a$$ soldering skills to just one set of +/-.
I like how it turned out, and considering how little the spools of LEDs cost, I'm not concerned about using so much. Very happy to have light on the trunk.
KHAKI CLUB #65
Unread 11-23-2013, 09:02 AM   #94
0321Nick
2006 WK
I noticed that the chrome trim was starting to chip and crack on my 4Lo T-handle. I thought about just getting some chrome spray paint and painting it, but then I got an idea for a small accent.
I picked up some Duplicolor Metalcast in Red. Applied it and am pleased with the little pizzaz it adds to the 4Lo handle.
The chips are still there, but at least its all one color now.
KHAKI CLUB #65
Unread 11-23-2013, 12:54 PM   #95
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
You'll have to let us know how the grill holds up over the winter. I looked into doing that to mine, but the only guy on here who had tried it wasn't having the best experience with it. The Jeep is looking good
See How It Was Made
Omelet is offline   Reply With Quote Quick reply to this message
Unread 11-23-2013, 12:57 PM   #96
0321Nick
2006 WK
Built the DBOX wiring harness I found on YouTube. Now I just need to get my current Rigid Industry Lights and my upcoming Rock Light LEDs wired through it.
If you plan on following the YouTube videos and build one yourself, keep in mind that the relays you buy may not color coordinate with the ones in the video.
To make things simple, here are the wire-colors and corresponding relay pin #'s from the video.
BLUE: 30
WHITE: 85
BLACK: 86
YELLOW: 87
RED: 87a
KHAKI CLUB #65
Unread 11-23-2013, 01:02 PM   #97
0321Nick
2006 WK
Will do. First I'll have to see what kind of winter is in store for Northern Virginia. Hopefully some snow at some point.
KHAKI CLUB #65
Unread 11-23-2013, 01:02 PM   #98
ca07wk
2007 WK
Where are you mounting this?
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline   Reply With Quote Quick reply to this message
Unread 11-23-2013, 01:32 PM   #99
0321Nick
2006 WK
I'll put it on the passenger side of the engine compartment against the firewall. Then I'll run all the cables along the edge of the engine bay. With the 4.7L that's the only space I could see.
KHAKI CLUB #65
Unread 11-23-2013, 02:03 PM   #100
ca07wk
2007 WK
Thats where my ARB compressor is... Im really thinking of mounting mine inside.
Unread 11-23-2013, 02:54 PM   #101
0321Nick
2006 WK
Oh yeah, I think Omelet has his there too. Hmmm. There might be some room behind the knee panel under the steering wheel.
KHAKI CLUB #65
Unread 12-11-2013, 04:38 PM   #102
0321Nick
2006 WK
Ok. Busy day today. Finally installed the DBOX into the Jeep and re-wired my Rigid Industries Duallys through the DBOX and wired in my LED Rock lights.
First I fit the DBOX on the passenger side of the firewall in the engine compartment. Couldn't really find a place to put an "L" bracket in the secure the DBOX - so I zip tied it to some the large insulated wire bundle behind the coolant reservoir. It didn't need to be really tight, just secure from bouncing around - The 6 conductor wire keeps it in place pretty well on its own.
Common ground for lights.
Ran the 6 conductor cord and battery wires along the firewall.
Was super lucky with passing the 6 conductor through the firewall. Since I already had the duallys installed, I duck-taped its wires to the 6 conductor and used the wires as a leader to yank the 6 conduct. through the firewall.... That saved soooo much time!
KHAKI CLUB #65
Unread 12-11-2013, 04:45 PM   #103
0321Nick
2006 WK
I put the LED strips along the frame rail and secured them with zip ties. Just had to drill a few small holes so I could use the existing frame holes for the zip ties.
For the rear, I had to take my 265/70 "donut" out to better access the hitch-frame-rails where I was putting the rear split-strip.
Of course, in the middle of the project... the daycare center lost power and I picked up the kiddo early today. Well, I turn my back for one second and he finds my Torque Driver and decides to play "Bob the Builder".
Oh well, I guess that will be my evening project.
KHAKI CLUB #65
Unread 12-11-2013, 04:49 PM   #104
0321Nick
2006 WK
I had originally drilled a small hole for a round rocker switch when it was just the Rigid Industries lights. I heard through the grape vine that Steel Armadillo now has a rocker panel mount for the driver side cubby on the WKs. I checked them out, and unlike Aspen Creek Offroad's design, they will offer a round rocker panel too! So for now I have my switches 'frankenstein'ed'.
And now the LED rock lights are all setup.
I didn't put a strip up front because I couldn't decide on a good mounting location and most other WK folk who have done this are rocking the 4xGuard Front Skid, which has a really great mounting location.
KHAKI CLUB #65
Unread 12-13-2013, 08:02 AM   #105
0321Nick
2006 WK
Picked up some Quick Fist clamps to accommodate my axe and shovel when wheeling.
KHAKI CLUB #65
