0321Nick's Build Thread - Page 5 - JeepForum.com
post #61 of 222 Old 07-29-2013, 05:26 AM Thread Starter
0321Nick
2006 WK
Originally Posted by BoraBora
Hmm, still a bit confused. I'm having a shop install all of my modified OME. Are there any pictures of what you did? I'm guessing I have to mod the rear spacer before I give the items to the shop.
No, you won't need to do that. The lower spring isolator is this very thin flimsy rubber donut. It sits on/around a puck-like post that is large enough to fit inside the spring. The 1.5" Rusty's spacer fits over that puck. It's just a really tight fit and the spacer is very hard rubber, so its difficult to get it on by hand, over that puck, without beveling the inside to make it easier on you, using only brute strength.
You won't need to mess with it before it goes to the shop. They'll either do that themselves or they will have some tools that will make it easier for them.
Sorry no pictures, I was working in 95* heat with 65% humidity. I was super focused on getting it done and where my ice water was. Haha.
KHAKI CLUB #65
2006 WK 4.7L V8 - Modified OME HD with Bilstein 5125s (28" length); JBA UCA; JKS Rear Discos; K&N CAI; PowerStop Discs; HyperTech; TOYO Open Country AT IIs 285/70/17; + some other goodies
0321Nick is offline
post #62 of 222 Old 07-29-2013, 08:16 AM
BoraBora
2015 JK Wrangler
Ah, got it. Thanks a bunch man.
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #63 of 222 Old 07-29-2013, 09:32 AM Thread Starter
0321Nick
2006 WK
Tested out the new mods this weekend. Only rubbed the front-left fender once. Didn't get a chance to disconnect the rear sway-bar however. . . Next time.
KHAKI CLUB #65
0321Nick is offline
post #64 of 222 Old 07-29-2013, 08:47 PM
WieSeL
Do any bilstein 5125's fit. I found some for $160 new in the box out here in Cali. Do they have to be wk specific? Is that a good price? He has 2 in 12" travel and 2 in 14" travel. Valving is 255/70
WieSeL is offline
post #65 of 222 Old 07-29-2013, 10:42 PM Thread Starter
0321Nick
2006 WK
I got this sku number from Autoplucity for about $130 ($60/shock) BIL-33104652.
They are 28" travel and require some spacers to fit snugly in the shock mounts. I just used some grade 8 washers big enough to fit over the factory shock mount bolts and shimmed the mounting locations. I believe I used 2 on each side up top and 1 on each side of the shock mount on the bottom.
KHAKI CLUB #65
0321Nick is offline
post #66 of 222 Old 07-29-2013, 11:08 PM Thread Starter
0321Nick
2006 WK
Forgot to mention. Saw this little furry creature (aka a bear) while 4x4 camping this past weekend.
KHAKI CLUB #65
0321Nick is offline
post #67 of 222 Old 07-30-2013, 03:33 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Lets see if this helps. As you can see in the pic the inner edge of the spacer is beveled so that it sits flat on the spring perch.
Omelet is offline
post #68 of 222 Old 10-18-2013, 09:17 AM Thread Starter
0321Nick
2006 WK
Finally got a used 285/70/17 for a spare when off-roading. Now I can leave my 265/70/17 "doughnut" at home when wheeling.
Since I have the big spare now, I test fit my new spare tire carrier that mounts to the hitch. I had it fabbed at Detours Off-road. Works great an fits great! Later on I'll paint over it with some truck bed liner.
KHAKI CLUB #65
0321Nick is offline
post #69 of 222 Old 10-18-2013, 09:19 AM
Jeepforthewin
2010 JK Wrangler
Nice!! Tire carrier looks really good!
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #70 of 222 Old 10-18-2013, 09:48 AM Thread Starter
0321Nick
2006 WK
Thanks. It's nice to finally get it all together.
KHAKI CLUB #65
0321Nick is offline
post #71 of 222 Old 10-18-2013, 10:38 AM
K9SAR
Great looking tire carrier...Nicely done!
May "borrow" your design there...
'06 Overland 5.7 Hemi / QDII / Silver WK Member #59, LED Backup lights, AEV Argent Pintlers, Floor liners. Gibson 3" Stainless Steel Exhaust, 6" Hybrid Superlift / OME lift, 6" JBA rear springs, JBA UCA's, JBA rear track bar, 35x12.5/17 Goodyear MTR's, Steel Armadillo Rock Sliders, 4xGuard Bash Plates
K9SAR is offline
post #72 of 222 Old 10-18-2013, 01:57 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Since I have the big spare now, I test fit my new spare tire carrier that mounts to the hitch. I had it fanned at Detours Off-road. Works great an fits great! Later on I'll paint over it with some truck bed liner.
Attachment 767434
Attachment 767442
Attachment 767450
I. Like. This.
Very simple. Very practical.
Only thing I would add is have a tab welded to the bottom of the elbow coming out from the receiver for a d-ring shackle.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #73 of 222 Old 10-20-2013, 05:34 AM Thread Starter
0321Nick
2006 WK
I. Like. This.
I asked the guy about that, but he said it would compromise the tire carrier. I even asked if he could fab me up one of his secondary recovery points - but the factory WK receiver hitch sits up to high into the body/molding.
His suggestion was to just throw a shackle in one of the 'chain' hoops next to the receiver. In reality, the spare-tire carrier is so easy to take apart because the tire mount plate is a separate piece that it would take no time to throw my shackle mount back into the receiver.
KHAKI CLUB #65
0321Nick is offline
post #74 of 222 Old 10-20-2013, 09:42 AM
JeepN4KC
JeepN4KC's Avatar
The problem with that is you might not get a shackle through those loops - not a proper size one anyway.
I don't understand how it would compromise the tire carrier.
~Mike~
WK
XJ
JeepN4KC is offline
post #75 of 222 Old 10-20-2013, 01:10 PM
BoraBora
2015 JK Wrangler
WOW! I need one of those tire carriers. Have any more picturs from further away? How's the tire carrier effect the rear visibility?
BoraBora is offline
My '05 WK build thread. ogie WK Grand Cherokee & XK Commander Forum 36 02-12-2015 08:42 AM
MossyOak711 Build Thread johncsmith711 ZJ Grand Cherokee Forum 42 05-13-2012 11:19 PM
chargold98's Build Thread. chargold98 ZJ Grand Cherokee Forum 5 12-27-2011 09:15 AM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
