1986 Jeep Cherokee Laredo 2.5l TBI Auto rwd - JeepForum.com
post #1 of 12 Old 02-18-2009, 02:26 PM Thread Starter
TwistedEvo8
1986 Jeep Cherokee Laredo 2.5l TBI rwd auto. 159,6XX miles.
I just picked this up for $500 cash! It was running vary bad. It had sat for over a year. Would barley start and would run on 3 cyl or less. It has Power windows locked and seats! Everything works in the interior. Its fugly red interior but I want to pull the carpet and rubber line it! Came with a alarm and remote for alarm/locks. I picked it up and changed the plugs on the spot. They were so fouled. They were the worst plugs I have ever seen! After that she started right up! It had vary bad gas so I put some 93 in it to help boost the octane and run better. I put some oil in it and drover her home.
There was some oil leaking from under the motor. It was hitting the crank pulley and getting slung all over the engine bay and hood. This had been going on before it was taken off the road, so a lot of oil buildup in the motor and on the suspension. I drained well over a gallon of oil out of it and it was like water... The oil psi was under 20 at warm and at 3000rpm before. Since then I have flushed the oil and replaced it with high mileage oil and a Bosh filter. I used some engine bay cleaner (3 cans) and removed most of the dirt and oil! She is running 10x better! Oil psi is above 40 at idle and go's up as rpms rise. The oil leak seems to stop since I tightened the oil pan bolts a little. Its only been a day so we will see. The motor needs some love. Needs some motor mounts and a real clean. I love sea foam so I will run that through her!
Im thinking about getting a new injector and pulling the throttle body off and giving it a good clean! The idle is 1100 rpm and when I rev it up to about 4k and let off it sometimes stalls. I will replace all vacuum lines and check for leaks. And replace the rotor and cap and test the coil.
If anyone has some tips or idea to help her run better please let me know! This is my first jeep. But I love working on cars I also own a 2005 Evo 8.
Pics!-----The day after I picked her up!---- I will post updated pics after weather clears up!
http://img.photobucket.com/albums/v2...PIC_0016-4.jpg
http://img.photobucket.com/albums/v2...PIC_0017-5.jpg
http://img.photobucket.com/albums/v2...PIC_0018-4.jpg
http://img.photobucket.com/albums/v2...PIC_0019-6.jpg
http://img.photobucket.com/albums/v2...PIC_0020-4.jpg
http://img.photobucket.com/albums/v2...PIC_0023-3.jpg
http://img.photobucket.com/albums/v2...PIC_0024-4.jpg
http://img.photobucket.com/albums/v2...PIC_0021-3.jpg
http://img.photobucket.com/albums/v2...PIC_0022-3.jpg
TwistedEvo8 is offline
post #2 of 12 Old 02-18-2009, 09:51 PM
Mike318_
Click free & Welcome to the forum.
Originally Posted by TwistedEvo8 View Post
~ Mike
Originally Posted by soul_Less View Post
"Mike318: Where there's a problem, he's the solution." :rofl::rofl:
Mike318_ is offline
post #3 of 12 Old 02-18-2009, 10:46 PM
TedderX_
Boy that's red!
Welcome to JF
-Tedder
TedderX_ is offline
post #4 of 12 Old 02-19-2009, 12:08 AM Thread Starter
TwistedEvo8
Thanks
Yes its to much red for me. Im really thinking about taking the carpet out and rubber coating the floor and pulling all the red interior parts out and painting them. But for 500 bux its worth it.
post #5 of 12 Old 02-19-2009, 12:23 AM
Mike318_
Thanks
I have to agree, for $500 interior color doesn't matter. An good luck with your project you got there.
~ Mike
Mike318_ is offline
post #6 of 12 Old 02-19-2009, 12:25 AM Thread Starter
TwistedEvo8
Thanks! Its not going to be a offroad beast but im sure it will drive me for a long time. Im planning on saving for a older 4x4 jeep to build up. This will give me time to research and learn more about jeeps. But I am trying to buy a set of Interco super swampers 29" to put on it.
post #7 of 12 Old 02-19-2009, 12:36 AM
Mike318_
Good plan. and check out 4wd.com & summitracing.com.
They got good prices on tires.
If you need any help finding something, just PM, i'm pretty good at finding stuff.
~ Mike
Mike318_ is offline
post #8 of 12 Old 02-19-2009, 01:23 AM Thread Starter
TwistedEvo8
Well i want this set im looking at because the guy is asking 80 obo for 2 never used or installed tires so its all i need for now since i have 2 good tires in my garage.
post #9 of 12 Old 02-19-2009, 01:30 AM
Mike318_
Ok 1 more time, that was a little confusing.
~ Mike
Mike318_ is offline
post #10 of 12 Old 02-19-2009, 01:56 AM Thread Starter
TwistedEvo8
ahah Im good on tires! The one's im looking at are new, never installed! I only need two tires because I have two good tires in my garage I can use. This guy is only asking 80 bux Or best offer for the 2 new tires I can put on the rear.
Sorry I get sloppy when its late and im tired
post #11 of 12 Old 02-19-2009, 02:00 AM
Mike318_
Alright. If you need help with finding anything else, drop me pm.
~ Mike
Mike318_ is offline
post #12 of 12 Old 02-19-2009, 02:03 AM Thread Starter
TwistedEvo8
ok thanks!
new 1986 cj7 bobsalotto Introductions 8 05-31-2009 09:35 PM
New Jeep owner 96 Cherokee 2 door deziner Introductions 3 11-19-2008 07:21 AM
jeep cherokee sport help Nicole Introductions 1 02-26-2008 06:00 AM
1992 Cherokee Laredo 5spd/4wd comming from Louisville KY Th3 Cavalry Introductions 4 11-03-2007 06:40 PM
New Old Jeep Cherokee owner scottca Introductions 4 11-17-2006 09:53 PM
