Do not Abuse Tags! - JeepForum.com
Go Back JeepForum.com > Jeep Forum Site Help & Support > JeepForum Announcements > Do not Abuse Tags!
Stainless Steel Door Hinge PinsPoly Door Hinge BushingsSavvy/Currie Aluminum Control Arms
Unread 03-10-2010, 03:31 PM   #1
Keith
Admin
Keith's Avatar
Do not Abuse Tags!
Tags are extremely helpful if they are used correctly. Tagging threads with very relevant keywords help both search engines and our own search to find threads for people.
Do not abuse tags!
They are not to be used as a joke. People blatantly abusing them will be banned.
Beer Forum - Commercial Beer Discussion Forum
Glock Forum
Keith is offline   Reply With Quote Quick reply to this message
Unread 07-20-2010, 12:44 AM   #2
MilitaryJK4455
2010 JK Wrangler
How do you tag?
MilitaryJK4455 is offline   Reply With Quote Quick reply to this message
Unread 07-20-2010, 02:32 AM   #3
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
A lot of the time, I'm getting a message that says it's not an approved tag, even though it's relevant to the thread.
Derpy Hooves for President in 2012
Matt Gertsch is offline   Reply With Quote Quick reply to this message
Unread 07-20-2010, 02:33 AM   #4
Matt Gertsch
www.lp.org
Originally Posted by MilitaryJK4455 View Post
How do you tag?
If you scroll down below the 'post reply' button, you'll see a small link that says 'tags'. If you look on the right side of that block, you'll see a link that says 'edit tags'. Click on that and you'll see from there.
Unread 07-20-2010, 11:42 AM   #5
Keith
Admin
Keith's Avatar
No one but Moderators should be able to tag threads. Permissions just aren't setup correctly right now.
Glock Forum
Unread 07-20-2010, 03:51 PM   #6
Matt Gertsch
www.lp.org
Might wanna check into that. I've tagged a couple of threads in the members' areas.
Unread 07-20-2010, 04:47 PM   #7
MilitaryJK4455
2010 JK Wrangler
All that I cant seem to tag are some tech threads or any of my own threads.
Unread 01-09-2011, 09:20 PM   #8
havasu
On permanent vacation
havasu's Avatar
Tonight I saw a thread which was not tagged, and proceeded to add some necessary tags. Once the thread was tagged, I hit "enter" and got a warning that I did not have the permissions necessary to be able to tag, but then it said that the tags I added were successful, and it worked. I just thought I would help out a tag moderator and was unaware we were not suppose to do this until I read it in the announcements area tonight. Sorry!
havasu is online now   Reply With Quote Quick reply to this message
Unread 11-05-2011, 08:10 AM   #9
jamescody
thanks for the info hope i wnt di that mistake
jamescody is offline   Reply With Quote Quick reply to this message
Unread 12-26-2011, 08:53 PM   #10
CJ_Rick
1978 CJ5
Never really understood the whole tagging thing.
78CJ5, 304, 4" BDS lift 1"body, Wide track axles, Powertrax noslip locker front & Detroit locker rear,4:56, 35s, Tera Low, Warn 9.5ti Winch, TKHFAB Rock Angles, Rock bumpers front & rear...
2012 JKU.
2012 JK, 2"lift, 32"BFG's, JCR Dagger stubby front bumper, Warn 9.5cti winch.
CJ_Rick is offline   Reply With Quote Quick reply to this message
Unread 10-04-2012, 11:42 PM   #11
ad12345
how do i make a new post?? tryin to get help with jeep thank you.
ad12345 is offline   Reply With Quote Quick reply to this message
Unread 05-18-2014, 02:22 PM   #12
AngryRedBird
Same here.. Upon entering the forum.. I took it upon myself to enter tags because none have been done.. However.. even if I or other enter tags.. I do not see an designated area (tag window/box) with all said tags.. Most sites have this type of tag system which is used for quick reference when searching for a specific topic or category.. So tagging the threads (unless there is a tag thought block) is a bit pointless.
AngryRedBird is offline   Reply With Quote Quick reply to this message
Unread 05-18-2014, 02:26 PM   #13
Anticanman
Follow me
Anticanman's Avatar
To search through them
http://www.jeepforum.com/forum/tags/
And to answer your other question:
Luck Favours The Prepared
[SIGPIC][/SIGPIC]
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 05-18-2014, 02:28 PM   #14
AngryRedBird
That it (Tag Cloud) Thanks Anticanman
tag , tag abuse
