YJ's with 2.5" springs SOA on 35's - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > YJ's with 2.5" springs SOA on 35's
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! April Instant Rebate: Up to $75 off Flowmaster Products!
Unread 05-22-2009, 06:00 PM   #1
OneCleanYj
As the title says, looking for pics of rigs with a 2.5
' spring SOA on 35's, preferably w/o a body lift, but if you've got a 1" BL post up too. An axle swap is quite possible in the very near future for my rig, so I'm thinking I might go SOA at the same time. And for the price on Qtec, the 2.5" Standard RE springs are hard to beat! Thanks in advance!
92 YJ. Lifted, rubbered, geared, and more
OneCleanYj is offline   Reply With Quote Quick reply to this message
Unread 05-22-2009, 07:34 PM   #2
jeep95xj
1995 XJ Cherokee
You cant out a 35 on a yj with a 2.5" lift
jeep95xj is offline   Reply With Quote Quick reply to this message
Unread 05-22-2009, 07:47 PM   #3
ridnonboggers
Read ALL of what he said! SOA + 2.5" springs = 5.5 to 7 inches of lift (depending on axles used) so yes 35s would fit, he could actually clear 37s.
ridnonboggers is offline   Reply With Quote Quick reply to this message
Unread 05-22-2009, 09:23 PM   #4
Goobersbro
with a highline kit and some other things you can but besides he said SOA so he would be around 8 inches of lift which i think is more than enough most guys use stock to 1.5" springs for 35s
My marshmallow build
http://www.jeepforum.com/forum/f12/m...-build-873442/
Goobersbro is offline   Reply With Quote Quick reply to this message
Unread 05-22-2009, 10:09 PM   #5
Brads_nky_yj
get the 1.5 rubicon express springs, or some OME 2.5 springs.
93 YJ - SOLD
Brads_nky_yj is offline   Reply With Quote Quick reply to this message
Unread 05-22-2009, 10:55 PM   #6
OneCleanYj
RE standards are very reasonably priced, which is why I'm thinking about getting them. The SOA Re's are a bit more expensive, but I noticed the OME springs are even cheaper than standard RE's! Even cheaper than stock replacements, which is why I'm considering them. But I think it'd be a little high for 35's, and that's as tall of a tire as I'm going with the 4 cyl...
Unread 05-22-2009, 11:23 PM   #7
Brads_nky_yj
Then why not just buy some replacement springs. You wont gain any lift except for the (5-6") of the SOA plus your BL and TJ flares, you will have plenty of room for 35s.
93 YJ - SOLD
Unread 05-22-2009, 11:32 PM   #8
Goobersbro
lol I just realized it was you Dolan... So does this mean putting your 9" in
Unread 05-23-2009, 02:25 PM   #9
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
2.5" old man emu springs, 5/8" more boomerangs. 8.8 rear/hp 30 front. here is a rig i built for a good friend, on 35's, and my old junk on 37x14.50's. exact same setups, i built his exactly the same as mine (if it aint broke, dont fix it right?). a shot side by side, and then a shot of each rig. again mine is on 37's.
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
leftlanetruckin is offline   Reply With Quote Quick reply to this message
Unread 05-24-2009, 12:41 AM   #10
OneCleanYj
More than likely... But my health insurance sort of became my financial responsibility recently, so I've gotta make sure that's covered before I decide what to do with the 9"
Martin- that looks pretty good! Not as tall as I'd thought a rig would be with those springs.
Unread 09-26-2012, 10:45 AM   #11
konadubrock
I lifted mine with the 2.5 standard duty lift kit from RE. I'm getting a set of waggy axels this weekend and going SOA in the near future which means Im planning on 35s. My questions were what did you do with your brake lines (i have the braided ones for up to 4" of lift but did you need longer ones or move them under the frame etc), what kind of shocks did you go with, where did you find a good driveshaft for something that tall, and did you do anything to lengthen the wheelbase? sorry for all the questions (I'm kind of a newb at this stuff).
konadubrock is offline   Reply With Quote Quick reply to this message
