YJ W/ R.E. 4.5" & 33's - JeepForum.com
post #1 of 7 Old 03-25-2008, 01:27 AM Thread Starter
Matt87YJ
Matt87YJ's Avatar
1987 YJ Wrangler
Like the title says, looking for pics of YJ's with Rubicon Express 4.5" lift on 33's. I have a heavy jeep an want a little more lift.
'87 Wrangler, Stroked with a few other toys...
Matt87YJ is offline
post #2 of 7 Old 03-25-2008, 01:34 PM
PhilipJ
PhilipJ's Avatar
Click the link in my sig... there's a few in there of my 93 YJ with the 4.5" XD and 33x15x12.50 BFG's. When I did the lift the bump stops all fell off so near full flex it would rub just a little but not too much. Just enough to wear the plastic down some over time.
PhilipJ is offline
post #3 of 7 Old 03-26-2008, 12:17 AM Thread Starter
Matt87YJ
Matt87YJ's Avatar
1987 YJ Wrangler
Got anymore?
Matt87YJ is offline
post #4 of 7 Old 03-26-2008, 08:26 PM
PhilipJ
PhilipJ's Avatar
Here's a few more at 'rest' to give an idea on clearance.
PhilipJ is offline
post #5 of 7 Old 03-26-2008, 11:56 PM Thread Starter
Matt87YJ
Matt87YJ's Avatar
1987 YJ Wrangler
Thanks man, you may have sold me on these springs. Do they ride and flex pretty good?
Matt87YJ is offline
post #6 of 7 Old 03-27-2008, 01:03 PM
PhilipJ
PhilipJ's Avatar
They ride and flex great. They're a little stiff at first, but I didn't really 'break them in' right away on trails and torqued the frame and shackle bolts at max spec. If you torque them down around nominal or minimum spec, they should soften up a bit quicker. You can also park your Jeep on top of something to flex it out overnight (properly blocked of course) to soften them up quicker.
It's probably the best overall spring under kit you can buy. The only thing it doesn't come with (aside from shocks, unless you choose that option) is a SYE/CV kit, but that's only because of the difference in transmissions and axles found in YJ's and the variety of options for SYE. If I weren't planning on doing an SOA on my next YJ, I'd definitely go with the RE XD kit again.
Just a few things about the kit:
- The aluminum shims suck and so do the centering pins in the leafs. Get steel shims and grade 8 bolts to replace the centering pins before you install the leafs. It'll save you time and effort down the road. Don't even bother installing front shims, the driveline is long enough to accomodate the slight increase in angle.
- The track bars are worthless. They provide a relocating bracket for the front, but I just left it off and didn't notice any difference in the handling at all.
PhilipJ is offline
post #7 of 7 Old 03-28-2008, 12:16 AM Thread Starter
Matt87YJ
Matt87YJ's Avatar
1987 YJ Wrangler
What are these track bars you speak of? They have been off this jeep since I did the RC lift. I'm replacing the old drivetrain with a new motor, tranny, and sye'd tcase when I pull this apart again. Thanks for the help and advice.
Matt87YJ is offline
4" suspension lift with a 2" coil spacer on 33's trailheadjunky Jeep Picture Requests 10 11-16-2009 08:47 PM
2.5" Lift with 32's or 33's OR 2.5" w/ 1" BL with 33's MB98XJ Jeep Picture Requests 7 10-28-2008 01:44 PM
YJ with 4.5" Rubicon Express & 1" body lift on 33's Mud-n-Beer Jeep Picture Requests 0 10-27-2008 04:39 AM
Four door 3" lift with 35's vs. 2"BB with 33's youcanmakeit Jeep Picture Requests 4 02-16-2008 07:43 PM
YJ with 4" susp. and 3" body lift on 33's hogzilla Jeep Picture Requests 1 03-26-2007 06:03 PM
