yj flex shots - Page 2 - JeepForum.com
post #16 of 48 Old 11-07-2010, 01:37 PM
RecklessXJ
1991 XJ Cherokee
RecklessXJ is offline
post #17 of 48 Old 11-07-2010, 01:41 PM
RecklessXJ
1991 XJ Cherokee
stock flexin
cant really see any flex but i just like this one
post #18 of 48 Old 01-09-2011, 10:02 PM
TomTheft
Stock
TomTheft is offline
post #19 of 48 Old 01-10-2011, 08:19 AM
GrimJeeper91
GrimJeeper91's Avatar
A couple of poser shots after a bath...
On the trail (at TDS)...
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
post #20 of 48 Old 01-10-2011, 09:40 AM
ncreptile
Refreshing to see stock YJs still. The sahara stocks are extremely hard to come by now.
I love you CM <3
What goes around comes around, thats why my weapon of choice is a boomrang.
ncreptile is offline
post #21 of 48 Old 01-10-2011, 09:45 AM
onelow1ton
1983 FSJ Wagoneer
here are some crappy drive way flex shots of mine i was just checking to see what will rub and clearly i need to open the rear fender up some
NEW BUILD 1983 wagoneer bagged and bodydropped Click here for build -->
onelow1ton is offline
post #22 of 48 Old 01-10-2011, 11:06 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #23 of 48 Old 01-10-2011, 11:09 AM
E_ROCK
I can almost flex out a 14" shock in the rear.
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #24 of 48 Old 01-10-2011, 06:40 PM
jorp
Still under construction
jorp is offline
post #25 of 48 Old 01-10-2011, 09:08 PM
flipper1
About two years ago. Need to get some pictures with the waggy leafs
"If it Ain't broke, fix it until it is broke."
My
Score: 1099RRv1.0 with a BOA of 30.41
flipper1 is offline
post #26 of 48 Old 01-10-2011, 10:32 PM
baritone_mike
THREAD JACK
Is there any way to tell if tires will rub at full flex with out flexing it out? I still have the track/sway bars hooked up with the relocation brackets and bumpstop extensions and stock flares. http://www.quadratec.com/products/16207_015.htm this is the kit I got, I got the heavy duty even though I have 2.5 to prolong sag.
I just installed a 3.5 inch superlift sus lift and 1/2 inch shackle lift. I put 33x12.50 duratracs on a 15x8 rim with 3.75" backspacing.
baritone_mike is offline
post #27 of 48 Old 03-10-2011, 12:45 PM
xtremescootr
Would anyone mind telling me if this is a decent amount of flex considering its a 2.5" procomp, stock shackles and track bars removed???
The photos are all of the same pose from different angles.
1991 Jeep Wrangler S 2.5L, AX-5, Ford 8.8 LSD 4.10 gearing, 48" hi-lift jack, 16" rubicon Moabs wrapped with 31" Goodyear MTR's, 2.5" pro comp explorer lift and 1" BDS rear shackle lift.
xtremescootr is offline
post #28 of 48 Old 06-16-2011, 08:43 AM
4G64
4G64 is offline
post #29 of 48 Old 06-16-2011, 11:39 AM
xcnick38
SOA with 2" body lift and full width axles HPd44 front and 9" rear
91' YJ wrangler,4" rc lift, 5/8" M.O.R.E boomerang shackles, 15x8 pro comp wheels, 33x12.5 BFG KM2
xcnick38 is offline
post #30 of 48 Old 06-16-2011, 05:50 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
Flex Shots bigblacktyj Jeep Picture Requests 4863 07-07-2017 08:37 PM
rubicon express flex shots joe's_yj Jeep Picture Requests 4 11-07-2010 06:59 AM
Flex shots my Jeep mic6 Jeep Builds 4 05-13-2008 11:20 PM
Some flex shots timothy_1987 Jeep Builds 23 03-31-2007 08:03 PM
Detailed my YJ today. See the so-far transformation, I got flex shots too! OneCleanYj Jeep Builds 10 03-07-2007 07:35 PM
