YJ with 2in shackle and SOA - JeepForum.com
post #1 of 8 Old 11-28-2013, 08:49 PM Thread Starter
Rapterlined
im courious on how it would look, thanks very much for anyone who has one
Rapterlined is offline
post #2 of 8 Old 11-29-2013, 07:29 AM
Carlos14
Very tall! I would imagine not many guys in here have that setup, but hey you're from Burlington! Small world. If you bet see an orange YJ around town that's me.
Luck Favours The Prepared
Carlos14 is offline
post #3 of 8 Old 11-29-2013, 09:45 AM
tjcj
The SOA alone will give you 5" of lift.
Sent from my XT881freeze ray gun using JeepForum
Yakima Valley Mountaineers.
tjcj is offline
post #4 of 8 Old 11-29-2013, 10:38 PM
The_Dealer
2003 KJ Liberty
Actually 5.5" on stock sagged springs. I went soa on waggy fronts, stock replacement rear with ask, and redrilled center pin and ran 38's. Long shackles look like ***. Make up for it somewhere else
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline
post #5 of 8 Old 12-02-2013, 04:50 AM
WidowYj91
Real small world, your the fourth member I know of on here from burlington. Anyway I think it will be hard to find a pic of that setup, being no one uses it.
WidowYj91 is offline
post #6 of 8 Old 12-02-2013, 05:47 AM Thread Starter
Rapterlined
It's all good just messin around, I think I'm going to get flat style front fenders. Yeah man small world
post #7 of 8 Old 12-02-2013, 04:53 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Not my Jeep....I repeat, not my Jeep. Poor set-up IMO.
IIRC this belongs/belonged to a guy named Rob. He was not happy with several things about it and was asking for advice. It's SOA on stock saggy leafs & ~1-2" lift shackles depending on which lower bolt hole of the day was being used.
Typically, shackles with that amount of lift will contribute to this:
Joe Dillard is online now
post #8 of 8 Old 12-03-2013, 06:49 AM
PeteYJTJ
So I'll chime in, but my shackles are a bit shorter.
SOA, stock YJ springs, extra main leaf in the rear.
1" longer-than-stock heavy-duty shackles, 5" center-to center, so 1/2" lift.
1" body lift, TJ flares, 35s.
I think it's the perfect combo. She flexes great and doesn't rub the body too bad when flexed. I suppose you could run longer shackles, but the rear driveshaft angle is pretty tight as it is, and longer shackles up front will hurt your approach angle.
Good luck,
Pete
88YJ:SOA/locked/35s/Superwinch=Wheeling Jeep.
04WJ:4.0/3"+10mm/Superwinch=DD & Expedition Jeep.
PeteYJTJ is offline
jeep build , YJ
